Microsoft has just announced a way to disable JScript in Internet Explorer. This would have been very useful a few years ago, to proactively prevent problems found in the now-ancient JScript engine, which ran their own slightly different version of standard JavaScript. Even though IE is no longer under active development, it still receives security updates. JScript, on the other hand, is basically done. If you’re one of the 1.06% that still use IE, then go flip the switch to protect yourself from additional JScript vulnerabilities.
Zerologon and Samba?
Samba is an open source re-implemenation of Microsoft’s SMB protocol. There’s a clever term that describes the reality of this situation: “Bug for bug compatibility”. Remember Zerologon, the flaw where a security token’s generation could be manipulated to vastly reduce the key space? Samba follows the specification, and therefore suffers from the same issue, though it seems to be unusual to actually run Samba in a vulnerable configuration.
Other implementations cannot say the same. QNAP in particular has been bitten by Zerologon when configured as a domain controller. What’s not clear is whether QNAP is running Samba on the NAS products, or if this is yet another vulnerable implementation. Either way, go update your devices. Continue reading “This Week In Security: Too Little Too Late, And Other Stories”
