We all have our childhood heroes, which in the case of [Hrvoje Cavrak] was the 1985 AT&T UNIX PC. This 18 kg behemoth of a workstation computer boasted a 10 MHz Motorola 68010 CPU, up to 4 MB of RAM and dozens of megabytes of storage in addition to endless expansion options, making it a powerhouse of a personal computer for the discerning professional. Now, many decades later [Hrvoje] has an FPGA-based version to tinker with.
This project targets the MiSTer project, meaning that this softcore with SystemVerilog, Verilog and VHDL components should synthesize and run on any MiSTer-compatible FPGA system, such as the DE10 Nano. For that board the SDRAM add-on board is required due to the DE10 Nano Cyclone V SoC’s FPGA side only having access to a fraction of the 4 MB required by the softcore.
Obviously the boot ROM and disk images for AT&T UNIX are still under copyright, so although you can download both you should be wary of provoking the current copyright holder. With that in place, however, you now have got access to a very complete UNIX PC experience, as can be seen in the demonstration video.
Some aspects of the code were written and validated by LLM coding chatbots, so this is still a ‘works on my MiSTer board’ project. In lieu of getting access to the real hardware – meanwhile priced at unobtanium levels – this seems like a fair enough trade-off if old workstations like these are your thing.
The UNIX PC obviously didn’t make it into mainstream computer as we covered previously, with the IBM PC with MS-DOS, CP/M and Apple’s systems quickly cornering the home market along with Commodore, Atari, etc. This possibly makes these AT&T UNIX PCs even more rare than 1990s SGI and Sun systems.
Expensive TV stand or design blunder? Apple squeezed out a similar monstrosity years later. What is the difference between the Xenix-running stock PCs running commercial bookstore software written in BASIC (Reiter’s and the Olsson “chain” in DC) and this AT&T thing For Dummies? Obviously the processor to start.
The 80’s saw two or three major philosophies about computers: 1: We don’t need standards because OUR design is so brilliant that everyone will buy it, 2: We’re just selling computers here – we don’t really know what they are. 3: We’re making really cheap computers. They’re not exactly useful for any practical purpose but you can play frogger and dig dug – the kids will love it.
In the early 80s I interviewed for a job at Sears assembling PCs at the store, not for the staff to automate their work, but to be sold at that store. This surprised me. Didn’t take the job because I didn’t dig the “sometimes you’ll have to come in at 5 am” part so not sure how that business strategy worked out.
I suppose my question boils down to “Why would I splurge on a brand name box when there’s a commodity that’ll do the same thing?”
IBM’s proposed plan at the end of the 70’s was to reduce cost by using standard off-the-shelf components, off-the-shelf operating system, and then have the re-sellers manufacture and service the actual PCs. The executives rejected it. Then:
And that became the success story of the PC, plus the convergence on a single OS that everybody could use instead of a gaggle of mutually incompatible and balkanized camps.
Wasn’t the Apple II some sort of role model, too?
The edge connector used by IBM was similar to the one used by Apple.
The CGA’s NTSC artifact colors were similar to Apple II color graphics, too.
Both platforms were using off-the-shelf parts and had numerous clones, as well.
Woz had to trick Jobs into having more expansion ports in the Apple II because Jobs said the users should only have a choice of a modem and a printer card and that’s all they’d ever need. The clones and off-the-shelf expansion cards came later.
Many different electronic devices had to be made with a back plane and card design with circuitry on multiple boards, so those connectors were simply available and not custom made by IBM or Apple.
The idea wasn’t new, and each machine had a different bus design and spec so they weren’t “standard” in that sense. The breakthrough was the mindset that you should be able to pick e.g. a modem card off the store shelf and it would fit all IBM machines regardless of make and model (to an extent) – not to have different and bespoke add-ons for each.
“Dude” said it better than I would have. They both plug into the wall as well.
People need quality
https://techxplore.com/news/2026-11-devices.html
Nice and retro
https://techxplore.com/news/2026-11-team-large-scale-fourier-analog.html
I just sold mine the other day. He also took a sun 3/60 and HP 715/33.
“You should be wary of provoking the current copyright holder” isn’t the very existence of this a provocation??? or was that sarcastic? I mean, this was well before linux so I don’t think any distros can be run as an alternative. You HAVE TO violate copyright rules just to run this with AT&T Unix. Although maybe you’re specifically referring to selling these FPGA things with their Sys V installed? Is there a real present-day owner that can be tracked down? Is it owned by Caldera? Isn’t it abandonware? There’s been an emulator around for a while, that also requires the original operating system. There’s was also a AT&T 1985 “Unix PC” that came with a 286@8MHz , the AT&T PC 6300, and another 1985 AT&T 286 PC that came with DOS, but could be upgraded with Unix… even referring to it as “’85 Unix PC” is a bit misleading. It was the PC 7300, different from PC6300. Unlike many others, this isn’t a fun rabbit hole to go down and I would have appreciated some journalistic effort to find out these questions. I’m not clear whether research was done confirming that it’s still under copyright or just that the copyright date hasn’t run out? If the holder doesn’t take measures to sue and defend it’s copyright, it’s forfeit, isn’t that likely here? But if provoking the owner is even possible, I’d like to know who the owner is, you can’t just leave it at “play nice”, and if Maya was making a joke or attempting levity, I need that spelled out for me.
Surprisingly, Linux can be run (work/port still in progress). Check the README in the demos section…
Linux on 4 MB of RAM? Since when does a house pig fit into a hamster cage? 😮
I loved my 3b1. I’ve still got it and a spare. I tried to boot it the other day, but alas the drive doesn’t work. The stepper motor for the head seek may just need some lube. The drive still spins up making its usual horrific noises. Just no head chunking. I bought David Gesswein’s excellent MFM disk backup and emulator thingy in case I can get the drive working again even for a little while.
I’m new to the 3b1 and had fun restoring one this year. I also wrote a new FUSE-sysv file system https://codefloe.com/mk2s/FUSE-sysv and a syscall emulator https://github.com/mk2s/att-unixpc-syscall-emulator Also this year the sources for the os 3.51 were uploaded https://archive.org/details/unix-pc-src-v-3.51
