Folding Wings Could Be The Future For Air Travel
Folding wings have a long history in aviation. Particularly in the military world, where the ability to fit more fighting planes on a boat made a very real difference to the outcomes of a combat situation. In civil aviation, though, particularly at commercial scales, the idea has been less popular.
As unattractive as complexity can be, the push for ever greater efficiency and performance may be changing things in this space. In coming years, you might find yourself boarding an airliner and watching the wings fold out prior to take off, in a way that once unthinkable for a conventional commercial aircraft.
Know When To Fold ‘Em
The folding wingtips allowed Boeing to fit a far longer, mor efficient wing to the 777X while still allowing it to operate in a wide variety of airports and gate configurations. Credit: Dan Nevill, CC BY 2.0
Longer thinner wings, subject to the laws of physics, are more efficient. But commercial air travel, and the planes we all fly on, are subject to an endless list of strict human rules. There are regulations for safety’s sake, mostly written in blood, but also a whole bunch of details that are locked in due to simple practical considerations. Airliners can’t be too heavy, because they’d destroy the runway, and they can’t be too large, or they wouldn’t fit at the gate. As engineers work to make each generation of aircraft better than the last, they have to stick within these limits, lest they accidentally build a plane that physically can’t access real-world airports.
A great example of this issue is the Boeing 777X. The cutting-edge widebody airliner has the widest wingspan of any model Boeing has introduced, at 71.75 meters. Engineers chose to design a larger wing for the sake of its ability to generate lift with less induced drag, along with other related factors to efficiency and performance. Fuel savings and increased range are on the table with a larger, longer, more efficient wing, but it comes with a tradeoff—size. At that wingspan, the plane would fall into ICAO aerodrome size F, putting it in the same category as heavy aircraft like the Airbus A380 and Boeing 747-8. This would restrict the 777X to operating only at select airports that had facilities suitable for such large aircraft. However, Boeing made the design choice to give the 777X folding wingtips. In the retracted state, the 777X’s wingspan becomes just 64.85 meters, allowing it to remain in the size E category along with existing 777 models.
Boeing didn’t need to equip the 777X with an extreme folding wing to get by. Whereas classic military aircraft like the Voight F4U Corsair had wings that folded right near the root to save the maximum amount of space on a crowded carrier deck, such measures aren’t necessary when it comes to the airliner market. Instead, just folding the tips away is enough to get the plane back into a more convenient size category. The wingtips are retracted and extended via hydraulic actuators, with the process taking roughly 20 seconds to complete. Once in place, the wingtips are locked in position prior to takeoff, to ensure the wing operates as one complete unit in flight.
Flapping In The Breeze
Boeing isn’t the only one playing in this arena, either. Airbus has been working on its own aircraft concept with folding wingtips, with even more interesting possibilities. The AlbatrossONE demonstrator is a small-scale, remote controlled aircraft that is being used to test an altogether different type of folding wing. Specifically, it is fitted with a set of semi-aeroelastic wingtips that are hinged such that they can freely flap to and fro during flight.  The idea is that these wingtips can reduce the effects of turbulence by allowing the tips to freely move rather than transmitting the disruption to the rest of the aircraft. There’s also the hope that they could avoid wingtip stalls during landing, and even increase roll rate for improved handling.
The AlbatrossONE was reportedly inspired by the way the albatross can “unlock” its shoulder during flight to better manage different wind speeds.
The Airbus demonstrator’s wingtips can freely flap in the breeze, or be controlled to varying degrees, such as to fold for taxiing and parking at the gate. Credit: Airbus
The wingtips are not allowed to flap freely at all times. They can be locked flat for climbing and cruising regimes where it is desirable to minimize drag. In conditions where greater maneuverability is key, or when it’s desirable to limit the impact of turbulence, the wingtips can be allowed to flap freely upwards in response to prevailing conditions. The wingtips can also be locked into a 10-degree raised position to minimize the risk of tip stalls during landing. Much like the Boeing design, the wingtips can also be stowed in a fully upright position to minimize the space the aircraft takes up at the gate.
The AlbatrossONE concept showed potential aerodynamic benefits of folding wingtips on a commercial aircraft. However, thus far, Airbus hasn’t pursued the concept to quite the same level of commercial availability as the Boeing 777X. Nevertheless, the work has fed into further projects, such as the eXtra Performance Wing demonstrator of more recent years. It could be that a future Airbus offers folding wingtips, either simply to boast a longer wing or to add better control and turbulence management in flight. But for now, it’s not something that is ready to hit the company’s mainstream offerings.
Bending The Rules
Ultimately, folding wings on commercial airliners are only going to become a thing for one reason—there’s an engineering benefit to be had. If there were other, cheaper ways to get the same efficiency gains without introducing additional mechanical complexity, they’d be the low hanging fruit that engineers attacked first. The fact that the Boeing 777X is heading in this direction suggests that the easy wins have been had, and that dodging around typical wingspan limits with a fancy folding mechanism is the way to go. If the technology proves fruitful and reliable in practice, expect it to spread in time to other aircraft in time—because if there’s fuel costs to be saved and profit margins to be padded out, you can bet the airlines will be champing at the bit for it.
Featured image: “777X” by Dan Nevill, CC BY 2.0
15 thoughts on “Folding Wings Could Be The Future For Air Travel”
  1. Soon, on the top of the plane, outside the resistence hull, will be placed a sack along the spine filled with helium (or hidrogen for those who want to travel fast, no matter the direction), so the total density of the plane will decrease. Next, geese will be tied on the wings to further increase the fuel efficiency. While 1/4 of the plane will be reserved for the spare geese, the luxury class will have swans near their windows.
    Aaand, when all politicians promises will become true, the birds will be replaced with pigs.
    1. In the meantime I’m waiting for my purple friend from Betelgeuse to deliver the solid state, no moving parts, all cold fusion electric FU101 (Flying Undercup) Aerial Vehicle, that easily does 0-60 ⁠mph in 0.000 000 1 ⁠s with the 1.1325G grav-stat engaged to prevent minor tissue damage to pilot and passengers during take-off.
      1. Your friend got pulled over by the Great Galactic Ghoul for speeding.
        He’ll be out in an eon or two—but if you’d like to wait here in the lobby, the yearly Starlog will be mailed shortly.
        1. Awg darn!
          There’s always problems with triple-G … The back passages into our solar system used to be safe but I guess they’ve put up new USV (Unidentified Space Vehicle) signature readers near Pluto where my friend planned to sneak past at a fairly low speed of just 374 ⁠740 ⁠572.5 m/⁠s, but triple-G seems to insist that anything faster than 299 ⁠792 ⁠458 m/⁠s is a big no-no.
          And about the Starlog, I wonder if they are sending it via the mail sorting facility on Antares after they unionised on Alpha Centauri — I haven’t received the May 2009 edition yet, you see, or, indeed, any other after that.
    1. Good point, but my first concern is that a distracted or unaccustomed pilot will forget to fold the wingtips. Not so much for flight, because as others have pointed out below, planes can fly with parts of the wing “missing” – but more for docking at airport gates. I hope the mechanism is foolproof and has sensors/warnings, before a fully-extended wingtip collides into a skybridge. I wonder if the folding mechanism is completely automatic – “land, wings fold; taxi, wings unfold”?
  2. The B777 was originally designed to include a variant with a more extreme wing fold (bigger folding section) when it debuted in the mid 90’s, but it was removed from the model range due to a lack of interest.
  3. When I was stationed at Clark in the mid-80’s, we lost a F-4E due to an unlocked wing folding during take off. The backseater punched out, but by the time it was the pilot’s turn, the aircraft rolled too far and he was killed. Another occurred at George AFB a few years earlier.
    The point there is the USAF version of the F-4 was still based on the original USN version, so the heavy tailhook and folding wings were retained. And while unnecessary, they were still a point of failure.
    So my concern with this feature is there is eventually going to be a failure. And nobody on a 777 has an ejection seat, even if it only gave you a 50% chance to survive.
    1. One plus of the Boeing design is that it’s like 10% of the wingspan rather than 60%, as with the Phantom, and it also doesn’t carry any control surfaces. Very large aircraft have managed to land safely missing significant parts of one wing from various causes, if most of the wing is still there, as long as the asymmetric lift is still within the control range of the remaining control surfaces.
      People have landed large jets with essentially no functional control surfaces, just differential control of the engines, although that’s very rare. But if you still have most of a wing, you have a prayer.
      1. But this is (post merger) Boeing…so I fully expect that if the wing tip unlocks in mid-air, in true Wily E. Coyote-fashion, the tip would keep flying while the rest of the plane crashes into the ground and makes the little dust cloud!
  4. Still unthinkable, just one more thing that can go disastrously wrong all in service of increased profits. “Fuel savings and increased range….” don’t benefit the traveller.
    1. If I want to fly from Florida to Australia, I basically have to go to LAX or SFO and transfer to another plane. Meaning I have a higher chance of missing my flight, having my baggage lost, and just being bored while I have to wait for the next flight.
      A longer range could open up more direct flights to more airports, saving time and money for the passengers.
      I just checked, straight line from MCO to SYD is ~9340 miles, MCO-LAX-SYD is ~9700. Granted, I don’t want to have to sit on a plane that long, but it would be better than a 360 mile diversion. That amounts to at least an extra hour in flight, plus however long the layover is.
  5. I don’t understand the point.
    Many airports already have a “terminal-less” terminal area, where you have to ride a bus or walk on the tarmac and ascend a stairway to board. No gangway limitations, there.
    I have had to do this at Moscow, Warsaw, O’Hare (Chicago), and Inverness, Scotland.
