Engage Tinfoil Hat: Samsung Note 7 Battery Theory
For the most part I believe things are as they seem. But every once in a while I begin to look at notable technology happenings from a different angle. What if things are not like they seem? This is conspiracy theory territory, and I want to be very clear about this: what follows is completely fictitious and not based on fact. At least, I haven’t tried to base it on facts surrounding the current events. But perhaps you can. What if there’s more to the battery fires in Samsung’s Galaxy Note 7 phones?
I have a plausible theory, won’t you don your tinfoil hat and follow me down this rabbit hole?
Continue reading “Engage Tinfoil Hat: Samsung Note 7 Battery Theory” →
Could Solid-State Batteries Last A Lifetime?
Researchers from MIT and the Samsung Advanced Institute of Technology have been developing a new material that could potentially revolutionize the battery industry. A solid electrolyte that won’t wear out, lasting exponentially longer than current battery chemistry.
It also has the possibility to increase battery life, storage, and the safety of batteries — as liquid electrolytes are the main reason batteries catch on fire.
Sound too good to be true? The idea for solid-state batteries has been around for awhile, but it sounds like MIT and Samsung may have figured it out. The current materials used for solid electrolytes have difficulty conducting ions fast enough in order to be useful — but according to the researchers, they’ve discovered formula for the secret sauce. They’ve published their findings on Nature.com, which is sadly behind a pay wall.
Another great benefit of solid-state batteries is they would be able to operate at freezing temperatures without a problem. What do you think? Is Samsung blowing smoke, or will they actually release a battery you never have to replace?
