Bees. The punchline to the title is bees carrying sensors like little baby bee backpacks. We would run out of fingers counting the robots which emulate naturally evolved creatures, but we believe there is a lot of merit to pirating natural designs, but researchers at the University of Washington cut out the middle-man and put their sensors right on living creatures. They measured how much a bee could lift, approximately 105 milligrams, then built a sensor array lighter than that. Naturally, batteries are holding back the design, and the rechargeable lithium-ion is more than half of the weight.
When you swap out brushless motors for organics, you gain and lose some things. You lose the real-time control, but you increase the runtime. You lose the noise, but you also lose the speed. You increase the range, but you probably wind up visiting the same field over and over. If your goal is to monitor the conditions of flowering crops, you may be ready to buy and install, but for the rest of us, dogs are great for carrying electronics. Oh yes. Cats are not so keen. Oh no.
