Twelve Days Of Christmas As Performed By 1980s Speech Chip
In a curious historical twist, the “Twelve days of Christmas” are actually the days of revelry that followed the 25th. The preceding period, Advent, was traditionally a fast, not unlike Lent. When and why a fast became an excuse for chocolate calendars we cannot say, but this historical information is presented to explain that this great hack by [Kevin], making a vintage speech synthesizer chip sing the classic carol will remain relevant at least until January 5th — or perhaps even the 19th, for the Orthodox amongst us.
The chip in question is an SP0256A-AL2, which you may remember from various speech projects for 8-bit computers back in the day. It can talk, after a fashion, by reproducing 56 “allophones” — the sounds that make up English speech — from ROM. Singing, though? We cannot recall much of that back in the day, but then, a talking computer was impressive enough.
As it turns out this is building on an earlier hack [Kevin] did in which he used an Arduino to make the venerable speech chip MIDI controllable. In that project’s write-up it is revealed that a Si5351 programmable clock module is used to give a variable pitch signal to the speech synthesizer. In this way he’s able to get about an octave an a half, which is good enough when the carol in question only spans one octave.
Of course the pitch signal needs to be varied by something and for that the venerable Arduino once again takes the place of an 8-bit computer. In this case it’s pre-programmed, but can also be set up for MIDI control.Of course nothing says you can’t use true retro hardware or a more-capable RP2040 instead of the Amtel chip.
It’s sad to think how much compute power has been wasted this year on AI-generated novelty carols when a little bit of 1980s silicon and some ingenuity can do nearly as good — or better, depending on your tastes. Continue reading “Twelve Days Of Christmas As Performed By 1980s Speech Chip”
Talking DIY Z-80 Retrocomputer Complete With Dev Tools
[Scott Baker] wanted to take on a new retrocomputing project. He decided to build an RC2104. Lucky for us, he documented everything along the way. In addition to the main board, [Scott] built bus monitoring and debugging tools, a front panel, a real time clock, an analog to digital converter, and a speech synthesizer.
You can follow along in the 8-part post that includes videos. He started with the basic kit:
  • CPU – The Z80
  • ROM – 27C512 64 KB ROM, selectable in 8KB banks
  • RAM – 62256 32 KB RAM
  • Clock – 7.3728 Mhz crystal that drives a 74HC04 hex inverter (for the CPU and the UART)
  • Serial I/O – MC68B50 UART
In addition, he picked up a digital I/O board.
Continue reading “Talking DIY Z-80 Retrocomputer Complete With Dev Tools”
