Quick and easy Thermic Lance is hot Enough to melt Rocks
Heat can be a hacker’s best friend. A little heat can help release a stubborn nut cleanly, and a lot of heat can melt a rusty bolt clean off. An oxy-acetylene torch is handy for these applications, but if you need a more portable setup, and you want enough heat to melt rocks, you might want to look into this field-expedient thermic lance.
Thermic lances have been around a long time in the demolition industry, where cutting steel quickly is a common chore. Commercial thermic lances are just a bundle of steel fuel rods which are set on fire while oxygen is blown down a consumable outer tube. The resulting flame can reach up to 4500°C with impressive results. In need of a similarly destructive device, [NightHawkInLight] came up with a super-simple lance – a small disposable tank of oxygen and regulator, a length of Tygon tubing, and a piece of 5/8″ steel brake line. No need for fuel rods in this design; the brake line provides both fuel and oxygen containment. As you can see in the video below, lighting the little lance without the usual oxy-acetylene torch is no problem – a “wick” of twisted steel wool is all that’s needed to get the torch going. The results are pretty impressive on both steel and rock.
You say you’re fresh out of brake line and still need some “don’t try this at home” action? No problem at all – just hit up the pantry for the materials needed for this tinfoil and spaghetti thermic lance.
Continue reading “Quick and easy Thermic Lance is hot Enough to melt Rocks”
