This Week In Security: Java4Shell, Optimizely Malware, Shrinking Disclosure Deadlines, Unpatchable Freezers
Last month, the details of PHP2Shell leaked before the embargo lifted, and PHP had to scramble its release out early. This week, the same research firm, Calif, had it happen again, this time with Java. Java4Shell (CVE-2026-114938) is a heap overflow in OpenJDK’s hardware-accelerated Base64 decoder, and on November 17, Calif said it was going public early because the vulnerability had leaked. Oracle and OpenJDK pushed fixes that afternoon, and Calif followed with its write-up.
Java normally runs virtual bytecode inside the Java virtual machine, but when a function gets called often enough, the HotSpot JIT compiler turns it into native code. For some common operations it goes a step further, and swaps in hand-tuned machine code which uses special CPU instructions. On x86-64 CPUs with AVX-512 instructions, Base64 decoding is one of those, chewing through 64 bytes at a time with a mask that decides which output bytes actually get written. When the last chunk of input is a short, malformed tail with “=” padding, the calculated output length underflows below zero, the mask ends up with every bit set, and the decoder writes 64 bytes where it should have written at most two. Java then correctly throws an exception for the bad input, but by then, 62 bytes past the end of the output buffer have already been overwritten.
The overwritten bytes are fixed; the attacker controls when and where the write happens, but not what is written. Calif turned that into a working exploit anyhow. The overflow overwrites the length field of a nearby array, which allows for overwriting more of the heap with chosen values, and then into a way to read heap memory back in a response, which may hold keys, tokens, and other secrets. From there, Calif escalated to code execution, grooming the heap remotely by carefully timing the pieces of the HTTP request. Calif is holding back the exploits for specific applications for now, and points out that every target needs its own custom setup.
Not every Java server is vulnerable. The bug needs OpenJDK 17.0.6 or newer, and an x86-64 processor with AVX-512 VBMI, which in practice means Intel Ice Lake or newer server chips, or AMD Zen 4 or newer; ARM servers are safe. The decoder also has to be JIT compiled first, which Upwind found took about 10,000 decodes, so a busy server qualifies and an idle one may not. Unfortunately, Base64 shows up everywhere attacker input arrives. i’IUpwind found that the standard HTTP Basic authentication handling in Spring Security, Tomcat, and Jetty, as well as Auth0’s java-jwt library, feed attacker-supplied data to the vulnerable decoder before checking any credentials. If you can’t update yet, starting Java with “-XX:-UseBASE64Intrinsics” disables the vulnerable code. Unlike Log4Shell, this is a bug in the Java runtime itself, not in a library, so dependency scanners won’t find it, and the fix means replacing the runtime everywhere it lives, including inside every container image.
Continue reading “This Week In Security: Java4Shell, Optimizely Malware, Shrinking Disclosure Deadlines, Unpatchable Freezers” →
This Week In Security: More Linux Bugs, Biggest Crypto Theft Ever, Prusa Printers, Residential Proxies
Linux kernel bugs which can be triggered remotely, without any login, are rare. Most kernel vulnerabilities need an attacker to already be running code on the machine. CVE-2026-98432 is one of those: a use-after-free in the IPv4 TCP handshake code, rated CVSS 9.8, which Atlas has written up in detail. It goes all the way back to Linux 4.4.
A use-after-free is exactly what it sounds like: the program releases a chunk of memory, but some other code keeps using it. If an attacker can get their own data placed into that freed memory before it’s used again, they can influence what the kernel does next. In this case, when a server accepts a connection whose SYN packet carries IPv4 header options (a rarely used feature of IPv4), the kernel hands those options from the half-open connection to the full connection without copying them, then frees them while another CPU core may still be reading them. The fix is a four-line change, from “kfree()” to “kfree_rcu()”, which waits until every reader is done before freeing the memory. A lost race simply fails the handshake, so an attacker can keep trying.
The bug was reported by Xinyang Ge at Anthropic, and Anthropic says its Claude model wrote a working proof-of-concept that gets root on “Linux servers with a multipath TCP listener.” Multipath TCP (MPTCP) lets a single connection use several network paths at once, like WiFi and cellular, and you might assume almost nobody runs it on servers. Unfortunately, as Marcus Hutchins points out, Debian kernels enable MPTCP by default, and Go 1.24 and newer open MPTCP listening sockets by default when the kernel allows it, so anything built in Go (including the Caddy web server) is potentially exposed. Hutchins’ scans found about 2.1 million servers reachable over MPTCP on port 443, and he’s already seeing scanning from residential proxies and Russian VPNs which looks like it’s specifically hunting for this bug.
Upstream stable kernels were fixed in mid October, but as of October 31, Ubuntu and Red Hat were both still listed as vulnerable, with fixes in progress. If you can’t patch yet, you can check for MPTCP listeners with “ss -Mlnp”, and disable MPTCP with “sysctl net.mptcp.enabled=0”, but note that this doesn’t affect sockets which are already open, so you’ll need to restart any services using them. Red Hat and AlmaLinux have also published firewall rules which drop TCP packets carrying IPv4 options, which basically no legitimate traffic uses.
We haven’t seen bulk exploitation of this vulnerability yet, which might hint that it’s less trivial to trigger than the severity might indicate, but it’s a great time to get servers up to date. “Not exploited yet” has a nasty habit of turning into “every vulnerable server exploited in a day”.
Meanwhile, on the local side, OpenAI has published the results of pointing an automated pipeline, built on an unreleased “cyber-focused” model, at the kernel. In a run in mid October, it found 2,300 candidate bugs, reproduced 1,700 of them, and produced 948 working local privilege escalation exploits against a stock desktop Linux distribution, for about $1.2 million in API credits, or roughly $1,279 per root exploit. That’s not cheap, but for comparison, Pwn2Own has historically paid $20,000 for a single Linux kernel privilege escalation. Local privilege escalation is the step after an attacker gets a foothold: turning an ordinary user account, a compromised web app, or a sandboxed process into full control of the machine. Coupled with even a basic vulnerability in other code, it can allow an attacker to take full control of the system and hide the compromise much more effectively.
OpenAI says it’s working with the kernel community to report the bugs and submit patches, starting with the most critical, and that during the ten days the scan was running, more than 100 other kernel privilege escalation bugs were patched by other contributors, with about 300 more being discussed publicly. The most sobering line in the report is that, for now, a low-privileged account on an unpatched system “should be considered functionally equivalent to root access for a well-resourced threat actor.” It’s been quite a week for kernel developers, and it’s not going to slow down any time soon.
The flood of AI discovered vulnerabilities seems to continue unabated, and it’s easy to feel under attack from them. Consider, however, how often the open source community has called for companies using open source tools and libraries as core elements of their business to help support those tools and community. There’s still a significant burden placed on the community maintainers when almost 2000 bug reports land in a week, but over $1 million investment in securing Linux isn’t nothing, and the patches at least appear to be reasonably scoped and accurate. I’m pretty sure we’d see an article covering Linus’s response if they weren’t.
Continue reading “This Week In Security: More Linux Bugs, Biggest Crypto Theft Ever, Prusa Printers, Residential Proxies” →
This Week In Security: New Spectre Attacks, Crushing Quantity Of Linux Vulns, Google Gets Too Much AI, And Hacking Lawnmowers
Just-in-time, or JIT, compilation could be considered a fundamental backbone of modern computing.  JIT compilation turns scripting languages like JavaScript or intermediary binary forms like Web Assembly into native code on the fly, giving web apps, and things that are web apps under the covers like Electron-based tools, near native speed.  A new paper explores leveraging JIT systems to revive Spectre-v2 attacks against processors.
Most modern processors gain performance by using a trick called “speculative execution”.  The processor guesses the likely result of a compare, and begins executing some of the next instructions before the results are actually known.  If the processor guessed right, things continue and there is a speed gain because it can jump ahead, but if the processor guessed wrong, any instructions that were run and any side effects of running them are discarded and execution resumes on the actual path.  In theory, anyhow.
In practice, the Spectre class of attacks targets branch prediction. It was discovered that when the wrong branch was chosen, not all of the results were truly hidden; Patterns of failures in guessing branches can be used to leak behavior processing encryption keys and other activities. The attacks evolved with the research dubbed Spectre-V2, which showed that non-privileged contexts, like non-root users and virtual machines, could poison the instruction prediction and use it to read arbitrary memory.  Fixes to the Linux kernel and other platforms were required to mitigate the worst of the effects.
The paper shows that by using self-modifying code in the JIT, the processor can be tricked into loading cached versions of the instructions.  The fixes to the kernel to prevent Spectre attacks include identifying malicious code patterns that attack the branch prediction, and stopping or changing them:  By causing the CPU to execute the cached copy of instructions instead of the live copy, the attack ignores the fixed instructions entirely and can attack the branch prediction algorithm.
To prove the attack is feasible in the real world, the researchers targeted several JIT compilers, including the SpiderMonkey JavaScript engine used by Firefox, the eBPF JIT found in the Linux kernel, and GraalVM, the JIT used in Python.  They found success with each, demonstrating that the attack is at least plausible.
Research like this is unlikely to be an instant world-melter, and will help find possible mitigations in the future to prevent these sorts of attacks.  Operating systems that support a high-security “lock-down” mode, like macOS and iOS, often disable JIT entirely, out of concern about these sorts of attacks.  There’s probably no need to start disabling JIT on every system, but attacks like these have a tendency to evolve.
Continue reading “This Week In Security: New Spectre Attacks, Crushing Quantity Of Linux Vulns, Google Gets Too Much AI, And Hacking Lawnmowers” →
This Week In Security: Android Malware, VOIP Hijack, Signal Contact Discovery, And TeamPCP Arrests
On GitHub, [AyaanB] details buying a cheap Android TV streaming device, looking for, and finding, baked-in malware.
Multiple warnings have been issued by the FBI and CISA regarding malware on media box Android devices. Many devices have been caught participating in botnets providing residential proxies, ad-click fraud, and DDOS services. [AyaanB] sets out to discover if a $30 set-top streaming box is pre-infected with malware, and extracting it – without ever letting the device talk to the Internet or access other devices on the local network.
Picking a device named in the advisories, [AyaanB] discovered that it was, indeed, preloaded with multiple app stores and applications that wouldn’t typically make sense on a set-top TV box. After identifying the serial port test pads and obtaining a low-voltage serial adapter, they were able to gain access to the bootloader and from there dump the contents of the MMC over TFTP.
With the entire filesystem accessible out-of-body, proving it was infected with malware at the factory becomes simple: the malware is signed as a system application, baked onto the system partition of the MMC, granted SELinux exceptions to mark it as a system binary with shell privileges, and has multiple launch scripts to make sure it is executed even if partially removed. With the malware identified, [AyaanB] continues to dig through to uncover the capabilities.
By installing hooks into the low-level Android process spawning system, the malware installs hooks into every application as it is launched: even if an application isn’t trojaned already, by the time it finishes executing, it’s definitely been subverted. The functions patched and the methods used match the Vo1d botnet, which is used for account takeovers, residential proxies, free “VPN” services, and other unfriendly behavior.
Further digging into the system showed hooks for ad-click fraud, where hidden browser windows are allowed to run unthrottled and display overlays are configured to obscure ads below where the user may click. Other included tools bid in real-time ad auctions, claiming to directly publish ads to the user which may or may not be visible. To cap it all off, a root level backdoor allows botnet operators to access the systems directly and install additional tools.
Be sure to check out [AyaanB]’s writeup for more details on exfiltration methods and other malware found on the devices. Continue reading “This Week In Security: Android Malware, VOIP Hijack, Signal Contact Discovery, And TeamPCP Arrests” →
This Week In Security: Apple Warns Users, Stripe Merchants Leak Keys, Copilot Helps Hack Itself, And Comcast Senses Movement
Apple has started sending some users push notifications warning that they have been targeted with specific malware. No specific information about the threat Apple detected is available. While multiple iOS attacks were released in spring of 2026, they all target much older versions of iOS and older hardware versions.
Users in 110 countries have received notifications recently, warning them they may have been targeted or already impacted by malware such. Apple typically uses the crash reporting mechanism for system apps to track new attack trends. The majority of users will likely never see an alert from Apple because malware with state-level capabilities like the Pegasus family is extremely expensive to develop. However, commercial availability means that some governments have deployed them against political opponents, protesters, human rights lawyers, and journalists.
If Apple pushes a security alert, it will show up as an email and a standard system notification, but also as a notification inside the Settings application. While email and notifications can be spoofed as part of phishing attempts, to date there is nothing which can generate false alerts inside Settings.
Almost universally in these cases, Apple recommends enabling “Lockdown Mode“, which adds extra protection to devices at the cost of decreased battery life and slower performance. Lockdown mode disables custom fonts on web pages, accelerated JavaScript, restricts message attachments over SMS and iMessage, and disables other common paths used by malware to steal data. Android devices offer a similar feature since Android 15 that is less comprehensive but can still provide additional safeguards for users directly at risk.
Attacking Airplane Networks
With research that will surely result in some breathless reports, researchers presented at Usenix 2026 an attack against the communications bus of a Boeing 737.
The ARINC 429 bus is a communications architecture for planes, similar to the CAN bus used in cars. Once you are connected to that bus, it can be vulnerable in the same ways cars can be vulnerable to data manipulation. In the Usenix paper, researchers discovered that one access port to the airplane communications system is easily reached from the outside of the plane, though “easily” in this context means “by airplane maintenance technicians”. The paper represents over a decade of work by the team in obtaining and building a test lab of avionics equipment to represent an actual airplane, culminating in an embedded device described as “the size of a quarter” that plugs into the communications port and provides remote access over WiFi.
It needs to be emphasized, given other recent news, that this is a piece of hardware being added to the plane which communicates over WiFi, and not a way to attack an unmodified plane via passenger WiFi!
Once part of the ARINC bus, it seems access is basically unfettered: the team describes being able to reprogram the autopilot, feed the pilot displays false data, and being able to modify the temperature and weight data shown, which could lead to miscalculations in take-off speeds with obviously catastrophic results. Fortunately, the researchers have also been working with Boeing since 2020 to address the issues being found, and the practicality of the attack in the wild remains largely theoretical. The research team has recommended removing the external ports in future aircraft, and blocking access to them physically, like with epoxy, in the current designs.
If reading security research papers is your kind of fun, be sure to check out the rest of the papers that were part of Usenix 2026.
Continue reading “This Week In Security: Apple Warns Users, Stripe Merchants Leak Keys, Copilot Helps Hack Itself, And Comcast Senses Movement” →
This Week In Security: BugTraq, AI Hacks, And Being Dumb On Planes
After a multi-year hiatus, the venerable BugTraq mailing list is back!
For decades, BugTraq was the place where vulnerabilities were disclosed, from the early days when nearly all vendors viewed all security research as a hostile force, through to the modern era of working with vendors to coordinate disclosing bugs. With the rise of bug bounty programs and other social changes, the mailing list slowly died: what started in 1993 ended in 2021 is returning. The new maintainer, Jonathan Brossard, says in his announcement “The mission is unchanged: full disclosure, researcher-first, no corporate filter.”
Don’t Be Dumb on Planes
In the unlikely event anyone here needs to be told: Don’t do dumb things on planes.
It seems that someone coming home from from the DEF CON hacker conference in Las Vegas decided to mess with the in-plane WiFi, and is likely now in the “find out” phase of doing something dumb. There hasn’t been any public followup beyond the original reports: a passenger on a Delta flight leaving Las Vegas brought up a fake WiFi hotspot named “Delta WiFi FAST” to trick other passengers into connecting, and attempted to disable the in-flight WiFi using a denial of service attack.
Continue reading “This Week In Security: BugTraq, AI Hacks, And Being Dumb On Planes” →
This Week In Security: Claude Gets Hacking, Hotel WiFi, And NPM Compromised Again
kMaybe feeling left out from the questionable hype train of “Our AI models can’t be trusted”, Anthropic has released reports that their Claude model has “reached the Internet” and accessed the systems of other companies on at least three occasions during testing.
It appears that the model was restricted from accessing the Internet because (and wait for it) the prompt told it that it didn’t have Internet access, and was inside a simulation. It seems like Anthropic counted on the same trick that users try to convince a model that Grandma really wanted to pass on her life-long love of hacking services, it’s all pretend. Like the OpenAI incident, the models were tasked with completing a capture-the-flag style challenge, a common hacker challenge format where vulnerable systems are provided and contestants try to hack them the fastest. Anthropic says that a misconfiguration of the test environment left the models with Internet access, so the model succeeded in accessing the Internet at large once it ignored the prompt.
In some instances, Anthropic says the model proceeded under the “misconception” that it was still in a simulation, listening selectively to some of the prompt, while in others it continued regardless. In once incident, the test model generated malicious PyPI packages, which were uploaded to the public PyPI repository and downloaded 15 times. Further clouding the issue, one of the downloads of the malicious PyPI module was by a security auditing company that was then infected by the package during analysis, allowing the Claude agent to access credentials of the security company via a poorly designed malware analysis pipeline. The company essentially deliberately infected itself with a malicious package, while lacking protections against malicious packages!
Anthropic promises tighter controls in the future, but stops short of ensuring that models under test will be prevented from accessing the Internet, and categorizes it as a test gone wrong. “These facts give us cautious optimism that with tighter monitoring and controls around evaluation infrastructure, as well as continued investment in alignment, this type of risk can be overcome.”
It remains to be seen why allowing automatic code to hack the production environments of other companies is considered acceptable. If any of us had done the same we’d be facing serious legal questions.
Hotel WiFi Pushes Malware
A threat group associated with the Russian Foreign Intelligence Service (APT29, Cozy Bear, Storm-2945, and/or Midnight Blizzard) has been identified behind an attack to push fake updates over hotel WiFi networks.
It appears that the attackers compromised the captive portal and gateway systems of the impacted hotels. The captive portal system is the typical gatekeeping system that requires you to pay for Internet access, or at least input your hotel room and name. By hijacking the DNS, users were redirected to additional fake “verification” pages that served a menu of malware using a variety of techniques.
Like previously reported activity attempting to capture Microsoft365 logins via spoofed pages, most these attacks seem very loud and obvious, counting on the end user to ignore warnings about invalid SSL certificates or run commands in the shell. Using a variant of the “click-to-fix” attacks, the user is presented with a fake request for additional verification by copying and pasting a string of text into a command shell, which then decodes to a standard malware installation script. More subtle attacks attempt to trick the user into adding a new device to their Microsoft accounts. The user is redirected to a page claiming to require a Microsoft login to access the Internet, often hosted on a copycat domain similar to a legitimate Microsoft resource. The fake login then prompts the victim to copy and paste an authentication URL, adding a new logged-in device to the Microsoft account.
Obviously, running arbitrary shell commands, accepting invalid SSL certificates, or pasting arbitrary URLs after signing in are all something nobody should be doing, and it’s unclear how many users were actually impacted by the campaign. For corporate users, the answers are relatively simple: user training, and an always-on corporate VPN that routes all traffic and DNS through the company servers.
For home users, the solution may be more nuanced. Every third video on YouTube tells you that you need to install a commercial VPN, but in many ways this simply shifts the problem. A commercial (or even worse, a free public VPN) service can also intercept DNS requests and traffic, by design. While some services are legitimately privacy protecting and respecting, many hide the true owners of the service. A better tool is Tailscale, designed for implementing personal VPN services, where your traffic stays on your own devices.
Tailscale, OpenAI, and Hugging Face
Speaking of the Tailscale VPN, we jump to their role (or non-role) in the recent Open AI “incident” with Hugging Face.
Tailscale is a zero-trust framework for connecting systems using the WireGuard VPN protocol. For end users, this is an excellent way to set up a VPN where your traffic never leaves your own systems unencrypted. For enterprises, it is often used to connect services Internet-wide, which is how it was used in the Hugging Face infrastructure. Once the Open AI agent had selected Hugging Face as a target, it found a vulnerability in a package manager, accessed a worker machine at Hugging Face, escalated to root on the Kubernetes cluster, and extracted the production key and authentication storage. This allowed the Open AI model to authenticate against the Tailscale system and directly connect to the network.
This, rightly, is not Tailscale’s problem. Once the authentication keys are available, it’s working as designed to allow new devices to register on the network. This is a pervasive problem with stored authentication tokens, and is one of the root goals, and causes, of the supply chain attacks suffered by NPM, PyPI, GitHub, VSCode plugin repositories, and more. Once an attacker is able to extract the authentication tokens, they are able to impersonate that account or system with equal privileges for as long as that authentication remains valid. Typically these tokens are not time limited, and the window of opportunity lasts until the owners of the account become aware of the compromise and are able to reset all of the impacted authentications!
Solutions to the permanent authentication token already exist, but are not widely used. Many package repositories already support restricted and dynamic authentication via OpenID Connect, where a token grants specific resources, not system-wide access. On some platforms, keys can be protected in a hardware-backed key store like a TPM or the Apple Secure Enclave chip, though this doesn’t solve the problem for most servers.
Tailscale, obviously, is looking to lean on the publicity generated from the Open AI incident, but the message is a good one: Anything that can be done to automatically and painlessly reduce the risks associated with long-lived authentication tokens will benefit everyone on the Internet. Even if you don’t run an integration pipeline, you most definitely run software built by one.
Another Set of NPM Package Compromises
The NPM package repository has suffered yet another incident where a large number of packages have been compromised.
Investigators have tracked over 400 packages infected with another variant of the same “Mini Shai-Halud” worm that ran rampant through package repositories in the Spring of 2026. While efforts have been made to reduce the attack surface of packages, few have implemented them, partly because they are not mandatory, and partly because they can greatly impact, or completely break, the build process. The packages this time include high-profile, commonly used tools, with several billion (yes, with a “b”) monthly installs during builds of other software.
Like the worms impacting the package repositories previously, packages are infected by added scripts to the pre-install commands which are executed automatically before the package is installed. The latest infection appears to have spread from a single developer of two widely used packages, keyv and cacheable. Once triggered, the worm will infect and upload new versions of all packages it can access, using stolen NPM authentication tokens. Like other variants of the “Mini Shai-Halud” family, the worm steals authentication tokens for NPM, PyPI, AWS, Kubernetes, and GitHub, the contents of env files which typically contain additional authentication keys, SSH keys, VPN configurations, and over 200 other types of credentials. These newer variants of the worms have increased the list of stolen credentials, begun modifying the instructions for AI coding assistants, added cryptocurrency theft, and added poisoned configurations for VSCode and AI tools to infect projects once the initial infection has been resolved.
Given the scope of the latest outbreak, the number of impacted packages will only increase: no effective countermeasures exist in the NPM community to prevent another wide supply chain event.
Mythos Knocks Out Post-Quantum Candidate
The Anthropic Mythos model found flaws in a candidate post-quantum encryption algorithm, HAWK. Multiple encryption algorithms have been under testing for years as part of the standardization process at NIST, with selected algorithms becoming part of the Federal Information Processing Standard requirements for systems handling secure data for government systems. Cryptographers fear that future advancements in quantum computing could break current encryption and signature methods, driving the search for new standards that will survive.
Anthropic reports that after 60 hours and approximately $100,000 in compute resources, the Mythos model was able to discover a flaw in the HAWK post-quantum signature algorithm. HAWK had previously survived multiple rounds of validation testing, but following the attacks generated by Mythos, the developer has withdrawn it from consideration. Mythos was not able to completely break HAWK, but combined multiple methods to reduce the key space by half.
Ultimately this is a case of the system working fully as designed. The proper time to find flaws in new algorithms is before they’re selected as standards!
Backdooring an Entire Linux Distribution
In 1984, Ken Thompson, one of the creators of Unix, gave the lecture “Reflections on Trusting Trust” in which he outlines the difficulties of establishing trust in tools. Thompson proposed the issue of a compiler modified to insert an invisible back door in any binary it compiled, including future versions of itself, ultimately showing the near impossibility of establishing a guaranteed clean tool chain, ultimately existing in all compiled tools and compilers without any evidence of the original code or modifications. Even if you inspect the source code, a compromised compiler could still be your undoing.
This week, a coalition of researchers published a paper demonstrating the “trusting trust” attack against a modern Linux distribution. Starting with a modified copy of the strip tool that removes debugging and other extraneous information to generate a smaller binary, the researchers demonstrated that the entire build of a NixOS Linux distribution could have a modification injected in every binary, including future builds of strip itself. While the attack starts with a source code modification of strip, after the first generation the modification exists in binary form only, built into each generation of the tool. This demonstrates that the “trusting trust” attack extends to any tool involved in the build process, not only the compiler, since the strip binary never reads source code, only the compiled results.
