The USB Implementers’ Forum doesn’t make things easy for anyone building a product with a USB port. To sell anything with USB and have it work like USB should, you need to buy a USB Vendor ID, a $5000 license that grants you exclusive use of 65,536 USB Product IDs. Very few companies will ever release 65,000 products, and there are a lot of unused PIDs sitting around out there.
Now, someone has finally done the sensible thing and put an unused USB VID to work. pid.codes obtained the rights to a single VID – 0x1209 – and now they’re parceling off all the PIDs that remain to open source hardware projects.
This is not a project supported by the USB Implementers’ Forum, and is more of a legal game of chicken on the part of pid.codes. The only thing the USB-IF could do to stop this is revoke the original VID; useless, because they can’t reassign it to anyone else. The original owners of the VID, InterBiometrics, licensed their VID before transferring or sublicensing VIDs and PIDs was prohibited by the USB-IF.
You can get a PID by forking the pid.codes repo, claiming a PID, and sending a pull request. Once that’s accepted, that PID is yours forever.
