Adding A Netbook Keyboard Light
[Vikash] was having trouble using his netbook in the dark so he added a keyboard light. He’s got a Dell Vostro A90 which is the same hardware as the popular Dell Mini 9. We agree that the condensed keyboard layout makes it hard to type without looking; just try to find the quotation mark, brackets, and tilde keys! He added an LED to the bezel around the LCD screen in order to shed light on the situation. Now the LED can be turned on using CTRL. An ATtiny13 microcontroller monitors pins 1 and 11 of the keyboard, waiting for the CTRL keypress, then turns on the light when it receives it. This hardware solution means it doesn’t matter if you’re running a Hackintosh (like he is), Ubuntu (like we are), or that other OS.
Dell Vostro A90 Hackintosh
dell_vostro_a90
A friend recently commissioned us to install OSX on a netbook. We advised him to purchase the Dell Vostro A90. It’s essentially a rebadged Dell Mini 9, a model that has been discontinued, but is well suited for OSX. It’s only available with a 1.6GHz Atom processor, 1GB RAM, and 16GB SSD. Depending on what deals are available, it’s $250-$300. We also had him purchase a 2GB stick of RAM which is the upper limit supported by the BIOS. Continue reading “Dell Vostro A90 Hackintosh”
