We Would Not Want To Be Stormtroopers Right Now
Humanity is another step closer to a fantasy-accurate lightsaber thanks to Hackaday alumnus [James Hobson] at Hacksmith. Their proto-saber cuts through (cosplay) stormtrooper armor, (foam) walls, and a (legit!) 1/4″ (6.35mm) steel plate. For so many reasons, we want to focus on the blade and handle. (Video, embedded below.)
The blade is a plasma stream designed for glassworking and burns a propane/oxygen mix with almost no residue, but the “blade” stays in a tight cylinder shape. With a custom PCB hosting a mixing controller, the blade extends and retracts like in the movies. The handle is not a technical marvel; it is an artistic wonder and if you want to see some machining eye-candy, check out the first video after the break. The second video demonstrates just how much damage you can do with a 4000° Fahrenheit tube of portable plasma.
You won’t be dueling anyone just yet, since there is no magnetic field shaping the blade like the ones [Lucas] envisioned. Unfortunately, you can’t block anything more substantial than a balloon sword since solid material will pass right through it, but it will suffer a mighty burn in the process. Lightsabers are a fantasy weapon, but the collective passion of nerds have made it as real as ever, and the Guinness folks give credibility to this build.
Continue reading “We Would Not Want To Be Stormtroopers Right Now” →
Finally, A Working Lightsaber!
Just in time for the movie of the decade, [Allen] from [Sufficiently Advanced] has built a real working fire-based light saber. And it’s awesome.
He started out with a replica light saber and designed his own 3D printed enclosure to house a small tank with a syringe valve that goes inside the handle. This allows him to fuel it with a mixture of methanol and acetone, using butane as a propellant. He learned how to do this from [Tesla Down Under], who has some fantastic projects — most notably, flamethrowers.
A nichrome coil provides ignition for the flame, and after he got the pressure just right, it produces a pretty awesome, albeit skinny, flame-saber.
Continue reading “Finally, A Working Lightsaber!” →
