MegaSquirt EFI
megasquirt
The MegaSquirt electronic fuel injection system has a completely open design to allow for easy construction and tweaking.  The project has been around for quite a while and has a well established user community with many success stories. The open design means you can construct a unique fuel injection system; You can combine high performance parts with OEM parts from various manufacturers because the device has been designed from the ground up to be flexible. The MegaSquirt is well documented and you’ll be fully aware of what you are getting yourself into before you take the plunge.
For some more auto fun check out the latest Packet Sniffers episode.
Continue reading “MegaSquirt EFI” →
Hackaday Links
Links
the podcast link is fixed. download it here.
it’s the weekend. woohoo. rock eh? we’re trying to get jolt cola to sponsor our philadelphia hackaday meeting and it looks good. it’ll be held at the holiday inn here on august 4th. more information will come later, no worries. so here’s some links to hold you over while you glee with excitement.
the xshox mod. make your xbox controller shock you! (read carefully) [camzmac]
this pez hack is pretty interesting to say the least. [bm5k]
get your “free” verizon get it now on. [robby]
portable cardboard speakers. they’re a bit um
