[ashish] sent in this one via the tips line. (Ed Note: link rot. Try this one.) It’s a project to create a laser based RS-232 link. It’s based on cheap laser pointers, a MAX232 and a photo-resistor to receive the signal.
25 thoughts on “RS-232 Serial Laser Link”
Leave a Reply to MikeCancel reply
wow, this is up for a couple hours and its already exceeded bandwidth? anyone got a mirror?
down already, damn
here is the crappy google cache (no pics)
http://72.14.253.104/search?q=cache:5qi98i9sFIoJ:www.geocities.com/siliconvalley/lakes/7156/laser.htm+www.geocities.com/SiliconValley/Lakes/7156/laser.htm&hl=en&gl=au&ct=clnk&cd=1&client=firefox-a
wow only up for about 20 minutes and its bandwidth is exceeded i think his host is almost as bad as this http://www.nouptime.com/index.php
I’m saying this as nicely as possible, but wasn’t it obvious this would happen when linking to a geocities site?
PS love the site, been reading a long time (but i think this is my first comment)
http://web.archive.org/web/20051223212034/http://www.geocities.com/SiliconValley/Lakes/7156/laser.htm
archive.org has a mirror with pics.
archive.org got the whole page with pics:
1997: When red laser pointers cost $70. Now you can get a tiny one (with naked woman tip) at a gas station for $10.
archive.org works. Well..here’s a similar project I found: http://www.tkk.fi/Misc/Electronics/circuits/laserlink.html
I hope this site doesn’t go down in 20 minutes!
pm sumitgood@gmail.com and I will host the files/images.
Regards.
Chris.
do you know ronja project?
http://ronja.twibright.com/
Back in the late ’90s I built a laser link based on a design by a guy in Melbourne (Derek Weston’s UPN-LT, you can still find it with google). Roughly similar, except that it used IrDA protocols (and modulator/demodulator chip) instead of running async serial directly over the optical link. I gather they had a small city network going there for a while using these transceivers. Unfortunately the big difficulty in laser comms is aiming, not modulation. There are more things than you think that can put your link out of alignment. You really need some sort of self-adjusting optics to do this for any length of time.
EXE for the C code shown in this project:
http://www.qsl.net/n9zia/wireless/laser/laser_data/index.html
This guy has a simple analog laser pointer setup:
http://sci-toys.com/scitoys/scitoys/light/light.html
I’ve built it and it transmits sound quite well. It could also make for a good start for data transmission. For higher data rates, I think a photodiode might be a good idea.
I’ve found places (can’t find the link right now, sorry) that sell laser diodes with collimating lenses for under $3 each, although all you get is the diode, the lens, a small thermalsink that the laser’s mounted on, and a resistor soldered onto the laser leg. But they make for a cheap laser spotlight, when you get about 20 of them and drill a bunch of matching holes in a bit of metal for them to all press into.
Okay. Now, do it with ethernet!
This is cool. We made something like this for our TI-85’s using a laser LED back in the day so that we could transfer programs without linking with a cable. One of the other students tried to turn us in for cheating but the professor was so impressed that he said that if we could come up with something like that we knew enough to pass his exams anyway so he let it go.(it was an electronics class.)
Keep up the great work
Oh! Forgot to mention it. Try bouncing it off your sister’s(or whoever’s window) when she’s on the phone to her boyfriend with no modulation input and just output it straight to an audio amp. Oh wait, no don’t do that its illegal. :p
fuzzy
P.S.
By the way, we used a cheap set of mini binoculars with our sensor at the focal point mounted in our xciever box, we just cut the binoculars in half to make two trancievers.
Parts ordered. ;)
hey matt
im interested in your above projects
if you have any website with info about those projects I would appreciate to see it. if not, contact me to the following email address so we can have further conversation : hackaday@hushmail.com
thx in advance
anybody know what would be required to change this circuit to work with usb on each end?
Hah. Both the hex shmitt trigger ic, and the rs232 driver arrived today. And guess what: The rs232 ic was shipped from Germany in a envelope, pretty banged up.
But the shmitt trigger arrived from texas, usa, by priority air mail, in a big arse box! Wonder who lost the most to satisfy a non-paying customer…
Now this is cool. A shame it’s for rs232, really.
But if someone designs something like this for the usb-protocol, I’m in!
is there a USB adaptation of this?
Here is a working link of this for those just stooping by… http://web.archive.org/web/20070716043916/http://www.geocities.com/SiliconValley/Lakes/7156/laser.htm
Thank you, person from the unthinkable future where the mighty Geocities have crumbled.
Fixed.
