When utilizing an SD card in your projects, you would generally buy an SD card slot to wire in. Sometimes, you just don’t plan that far ahead, or maybe you just want to play with an SD a little bit to see what you think. [Kroden] shows us how to make a fairly simple and cheap SD card dock. The result is actually pretty impressive looking. He has simply bent some header pins and soldered them together to make a simple SD slot. It can even be adapted to a horizontal layout for more permanent use.
