[Erdem] sent us an update on his work with the SamyGO project. You may remember this Samsung TV firmware hacking initiative from our post back in October. Since then many more TV models have been added to the compatible list. They have also worked out a way to defeat the AES encryption and RSA signature checking on the CI+ devices. Want to lend a hand? Take a look at the compatibility table on the main page and see if you have one of the TV models they need testers for. Otherwise, read the wiki, hit the downloads page, and unlock the hidden abilities of your boob tube.
Day: March 24, 2010
ARM-based CNC Mill Needs No Computer
[Fedeortiz12] and his team are nearing completion of their CNC mill (english translation). They set out to build a standalone machine that takes G-code in the RS274/NGC format from an SD card and machines parts accordingly. At the heart of the system is an ARM LPC2148 controller with a character LCD and control pad for operation. The guys have made a teaser video showing the project being tested with a felt-tipped pen. Take a look after the break.
We’d like to see the final product milling PCBs. We’ve always been a little jealous of the PCB milling setup that [imsolidstate] has in his shop.
Theo Jansen: Like The Professor From Gilligan
[Theo Jansen] is building lifeforms that will live and thrive on the beach. He calls them StrandBeest and uses PVC electrical conduit, plastic tubing, and lemonade bottles as building material. The many-legged creations are amazingly advanced, able to count steps, sense and flee from the water’s edge, and protect themselves from high wind. He gave a TED talk back in 2007 that we’ve embedded after the break; it’s uncanny. See examples of his creations using fans and sails to store wind energy as compressed air in the lemonade bottles, then use that pressure for locomotion. He also demonstrates a binary step counter and water sensor. Continue reading “Theo Jansen: Like The Professor From Gilligan”
