Every reasonable person prepares for the future. Whether it’s matching your employer’s 401k contributions, making sure you have bread and milk before a snow storm, or saving for your kid’s college fund, planning for the future gives you a comfortable life. [Gord] has exceptional foresight; he build an awesome Louisville Decapitron for the upcoming zombie apocalypse.
It’s an urban legend that a bullet to the brain will stop a zombie. Instantaneous trepanation is devastating in the living, but we’re talking about the undead here. A melee weapon is what you’re after, and you’ve got to cut off the head. [Gord] based his project around a Louisville Slugger. The blade is a 20 inch long piece of plasma cut mild steel. It’s just a prototype to get the balance figured out; the final version will be done in carbon steel.
The tang of the blade fits into two notches in the bat. The blade is secured with two custom fabricated spacers that are perpendicular to the blade. We’re not quite sure of the nomenclature of the resulting weapon (it’s some type of battle axe, we’re sure), but we couldn’t think of a better way to decapitate the undead.
Batter up, zombie down!
This thing is liable to take one of your own limbs off with the way the blade comes down and a lack of length of the bat unless you’re holding relatively close to the blade tang.
This thing is awesome, and you know it. Losing a few fingers is nothing to losing your brain to a hungry zombie.
its a bat-tle axe
Looks like you haven’t played any zombie games in the last 10 years. Especially apparent in Left for Dead and in Resident Evil(the zombie ones), but once they are within arms length, you are pretty much screwed. Definitely need something with a little more range. Unless of course your travelin’ with me, i’d be happy to let ya’ try out your melee weapons while we’re under attack (bait is the best weapon).
Blades don’t run out of ammo. Though if you live in the US, then the odds of you running out of ammo are about the same as in any of the games you mention.
I can think of a better way. Bastard Sword. far more effective than a all for show giant blade and bat that will be heavy as hell and get stuck.
a bastard sword will cut through clean with a “pop” as the head comes off.
Using this weapon will turn you into zombie bait as you have to swing, stop, swing, stop, swing, stop… while a good old medival double edge sword can swing,and swing,and swing without any pauses to remove it from the body or change direction.
Louisville Slasher?
Ah yes, but can it make Julienne zombies?
Come on, the man just showed you how to make a survival tool, and now you want zombie recipies?
I am so damn tired of zombies. It’s a hilarious weapon, and it makes we want to build something like that, but as soon as I saw zombie I said “ugh.”
Also, needs more spikes.
There’s no point in decapitating zombies. Just destroy the brain and you’re golden.
That would be a bardiche :)
It’s basically a shorter Bardiche.
http://en.wikipedia.org/wiki/Bardiche
The only advantage I can see with going for a bat over some other handle is the relative ease you could replace it if it broke.
Mild steel is carbon steel. Maybe high carbon steel?
How long do you think that you can swing that thing? Ill give you 5 min then you are zombie food.
Now you see there is no reason to be hating on the “ZSlugger” (Zombie Slugger)The “ZS” Is in it’s prototype stage right now. The ZSlugger has many different ways that it can be used that you might not know about. Not only can it be swung like a base ball bat but the opening in the blade is intented for the user to be able to use two hands to push and slice their way through the zombie herds. The blade on the firts prototype also has the top hooked design to be able to swing in an upwards direction through the zombies jaw in to the the brain killing it instantly. There are a couple different blade ideas, a hammer faced bottom attachment meant for busting in doors and zombie heads, and also the handle will most likely be finised off with a nice old school hemp rope rap for the proper grip and badass affect. We are looking in to getting a working prototype that can be tested before it is to late…
Don’t worry about them, they wouldn’t be hating to your face if you were holding that thing.
We needed a bunch of these in wallstreet the other day. There were a bunch of zombies there!!
Problem is:-
If you miss your target, exactly where is the force from the swing going to go?
In the Zombie behind you!
That’d be a bardiche. http://en.wikipedia.org/wiki/Bardiche
infection pass thought the blood so you dont want to be anywhere near bleeding body
Gonna take a least a month to put a proper edge on that monster of a blade. At first I thought it was a Halloween prop too late for this year, but that ain’t cardboard.
“Weāre not quite sure of the nomenclature of the resulting weapon…”
It’s a bastard Lochaber Axe. It would be more effective in it’s original design; a longer haft. More haft = more heft.
OMG is that weapon legal?? :P
Does it matter? It’s a hacking forum, not a ‘legal carry discussion’ forum
Oh yeah I forgot! Who cares? I don“t!
I’d rather have a monk’s spade or a lobo from WWZ http://en.wikipedia.org/wiki/Monk's_spade though this is still a pretty neat build.
Also this forum has some great thoughts on building a lobo http://www.swordforum.com/forums/showthread.php?89040-The-quot-Lobo-quot-from-the-book-World-War-Z-by-Max-Brooks
