While it may only be [ioan]’s first ‘real build’, we’re loving his DIY teardrop travel trailer built from the ground up.
The trailer started its life as a Super Duty Harbor Freight utility trailer that [ioan] managed to put together in a day. After mounting a wooden frame on the utility trailer, [ioan] fabricated the body of the trailer out of 1/2 inch plywood for the exterior, hard foam as insulation, and gorgeous 5mm plywood for the interior. To finish off his build, [ioan] cemented aluminum sheets to the exterior for a wonderful Airstream aesthetic.
[ioan] even went so far as to install a small kitchen in the back of his trailer that includes a small propane stove and (a limited supply of) running water. It’s an excellent build that really shows off his craftsmanship, and something we wouldn’t mind spending a weekend in.
[ioan] put up an Instructable of his build that showcases the construction including all the electrical work of wiring up his trailer with LED lights and 12 volt power jacks.
