Digging Deeper Into The Apollo Saturn V LVDC
LVDC-NAND-proto
[Fran] went all-out with her reverse engineering of the Apollo Saturn V LVDC board. Regular readers will remember that she was showing of the relic early this year when she took the board to her Dentist’s office to X-ray the circuit design. Since then she’s been hard at work trying to figure out how the thing functions using that look inside the board and components. When we say ‘hard at work’ we really mean it. Not only did she explore many different theories that resulted in dead ends, she also built her own version of the circuits to make sure they performed as she theorized. Above you can see her version of the NAND/AND gates used on the hardware.
We find her explanation of how the logic devices were originally fabricated to be very interesting. They started with a ceramic substrate and used additive processes to form the traces and add the gates. We’ve embedded her video explanation after the jump.
http://www.youtube.com/watch?v=Y0HC8bBCdgk
11 thoughts on “Digging Deeper Into The Apollo Saturn V LVDC
  1. I see lots of automotive modules made in the 70’s and 80’s that were made using this technique. We have a *lot* to thank the lunar programs for as far as technology advancements.
  2. An excelent example of [and how to] reverse engineer[ing].
    These circuits are discreet logic examples of what at the time
    became TTL [transistor-transitor Logic {7400 series}]
      1. Correct. TTL logic was just becoming available when these great spacecraft were being launched so minor tweaks to the later ones were in fact that kind of circuit design. But all, and I do mean all of them were designed that way. Bitsavers, a site dedicated to saving documentation on everything computer contains some manuals on it, and also some IBM manuals which’re perfect for what the lady is doing…..
        IBM simply directed their successes at building the S/370 modules to the ones for the Big Bird, and indeed everyone later, Space Shuttle included.
      2. Yes, the AGC was RTL, but the circuits in this article are clearly TTL, built from individual transistors since they pre-date 54/7400 series chips.
