Semi-automatic Pick And Place Machine
semi-automatic-pick-and-place
This is a fascinating take on building your own pick and place machine. It does an amazing job of automating the hardest parts of hand assembly, while relying on human dexterity to achieve the hardest parts of automation. It’s a semiautomatic pick and place machine driven by an Arduino and controlled by an Android tablet.
The machine is built in two parts. The portion in the upper left feeds components from reels and is fully automated. The portion on the lower right consists of a padded arm-rest which slides smoothly along two axes. A mechanical arm with multiple articulations is attached to the end, culminating in a tip connector for some vacuum tweezers. Right handers are the only ones who will find this convenient, but oh well. The clip after the break shows it in action. The assembly technician first selects the component from an icon on the Android tablet. The reel machine then dispenses that part, which is picked up by the vacuum tweezers using the left hand to switch the vacuum on and off again. If the part orientation needs to be rotated it can done using the jog wheel on the Android app. It smooth, quick, and best of all, clever!
26 thoughts on “Semi-automatic Pick And Place Machine
  1. I’ve never really done any SMD stuff so I ask out of genuine curiosity, is this really so much easier than just using conventional tweezers? Or indeed than building a fully automated pick and place machine?
    1. This was the first stage of making a fully automated system. After looking at a lot of the DIY pick and place projects online, i found that most used a very basic feeder system which required a lot of manual work to move the component strips and clean the header tape away so I started the project from the feeders first and then plan to automate the other axis’s later.
      1. I look forward to seeing the finished piece. It’s still a pretty cool device as it stands, and I think someone below has given me the reason for the need for vacuum tweezers. All good to know.
    2. You definitely want to use some sort of vacuum tweezers for QFN or BGA packages. It’s nigh impossible to align dozens of pins at a 0.5mm pitch at the shaky tips of your fingers. I learned the hard way myself – after ruining some quite pricy chips I hacked myself a solution from a 3D printed parts, an air mattress pump and screws for XYZ translation. It really made all the difference.
  2. Ok i love HAD I really do but u guys need to proof read before posting. Its probably on 2 axis not axes i’ve never heard of a let hand so i assume u meant left. Sorry interesting article but its not just this one that has typos its most of them ever since the last redbull contest.
    1. WOAH, know your axes before you comment!
      You are correct. There is one axis:
      “We shall draw this line and call it the x axis.
      If there is more than one axis, it is axes.
      “The stress analysis was done on the x-y-z axes.
          1. Sorry for the DP but im also not writing an article that the educated minority reads i could understand if this was a thread on a forum or something but its not and takes like 2 minutes to proofread these bite sized bits of supa l337 haxzor genius
    2. Anyone who uses text shortcuts like “u guys”, along with shoddy grammar, and does not know singular from plural may want to avoid commenting on grammar, spelling, and, writing style. Phone or not, “thevac”. What does this mean: “Ok i love HAD I really do but u guys need to proof read…” FAIL.
  3. Enough speling one-upmanship already.
    Great job guys. You must have way better eyesight than me. I’d have to have my beak right in there where the tweezer tip is! And with magnifier headband on, too.
  4. Sloppy English aside, this is a well built project. To Mental2k, assembling SMT boards from tape reels rolling around on your desk, or small bits of tape, with tweezers is indeed tedious. I’d love to have a machine like this
  5. This is a really interesting compromise between a full P&P and manual placement And the build quality looks terrific.
    At work we’ve been pondering the possibility of getting a second hand P&P machine but the cost seems prohibitive, I think we might look into a semi-automatic one like this.
    Congratulations on an excellent project.
Leave a Reply to BrianCancel reply
