Teardown Of Intel RealSense Gesture Camera Reveals Projector Details
[Chipworks] has just released the details on their latest teardown on an Intel RealSense gesture camera that was built into a Lenovo laptop. Teardowns are always interesting (and we suspect that [Chipworks] can’t eat breakfast without tearing it down), but this one reveals some fascinating details on how you build a projector into a module that fits into a laptop bezel. While most structured light projectors use a single, static pattern projected through a mask, this one uses a real projection mechanism to send different patterns that help the device detect gestures faster, all in a mechanism that is thinner than a poker chip.
mechanism1It does this by using an impressive miniaturized projector made of three tiny components: an IR laser, a line lens and a resonant micromirror. The line lens takes the point of light from the IR laser and turns it into a flat horizontal line. This is then bounced off the resonant micromirror, which is twisted by an electrical signal. This micromirror is moved by a torsional drive system, where an electrostatic signal twists the mirror, which is manufactured in a single piece. The system is described in more detail in this PDF of a presentation by the makers, ST Micro. This combination of lens and rapidly moving mirrors creates a pattern of light that is projected, and the reflection is detected by the IR camera on the other side of the module, which is used to create a 3D model that can be used to detect gestures, faces, and other objects. It’s a neat insight into how you can miniaturize things by approaching them in a different way.
Talking, Foot-Pedal-Controlled Bench Probes For VirtualBench
Developing new products can be challenging during the debug and test phases, often you have your head down trying to probe the lead of some SOT23 transistor, and just when you get it, you scan your eyes up and find that your multimeter is measuring resistance and not voltage.
[Charles] had this issue compounded on his NI Virtual Instrument. It has an interface totally driven from a PC, which may or may not be in a convenient location to mouse around. Luckily NI just released an API for the 5 in one lab test station and [Charles] quickly whipped up a python wrapper which gives him ultimate control over the instrument.
Tying the script to a USB footpedal and adding some text-to-speech capabilities using google’s API [Charles] is easily able to switch from continuity to voltage to resistance and anything else he pleases with just the tap of a foot and listening to the measurements, making sure he never takes his eyes off the work which is risking a short.
Join us after the break for a quick video demonstration.
Continue reading “Talking, Foot-Pedal-Controlled Bench Probes For VirtualBench” →
