Hackaday Prize Entry: A Programmable Calculator With Nixie Tubes
For [Robert]’s entry into The Hackaday Prize, he’s starting off with some basic questions. What’s better than a Nixie tube? More Nixies. What’s better than a calculator? An RPN calculator. What do you get when you combine the two? A calculator that is absurdly large, even by 1970s desk calculator standards, uses a lot of power, and takes up too much space. Sounds good to us.
Nixies, at least when there are a lot of them, are tricky devices. They only draw about 50mA of current, but they only light up when above 150V. That’s only about seven watts, and it’s easy enough for the Arduino-heads out there to build a circuit to drive a few Nixies for a clock. Driving dozens of Nixies is a bit harder. For [Robert]’s RPN calculator, he’s estimating a little under 50W of power being dumped into this calculator.
With the considerable power considerations taken care of, [Robert] turned his attention to the display board. This is going to be a very impressive build, with 80 IN-12B tubes organized in four stack levels of twenty tubes each. The tubes will be controlled with the Maxim MAX6922 VFD driver. This chip has a serial interface, which means it’s relatively easy to have any microcontroller blink these tubes. And of course, it does double-duty as a clock.
The HackadayPrize2016 is Sponsored by:
21 thoughts on “Hackaday Prize Entry: A Programmable Calculator With Nixie Tubes
    1. Came here to say this – my dad (a research biochemist) had one of those in the late 1960s. I blame that machine for initiating my descent into digital nerdiness.
    1. Considering that there’s enough capacitance to drive a neon bulb and dropping resistor by holding one lead and poking the other in a wall socket, 3-5mA seems more like it. I only do it to make the wife nervous. Plus, why not?
  1. That’s it. I’m banning the word “nixie” from my RSS feed. I’m fed up with this kind of project. I understand the vogue of retro-hacking, but it’s been years now. Can we get another vogue by now?
Leave a Reply to JamesCancel reply
