Oh Nexus 5X, how could you? I found my beloved device was holding my files hostage having succumbed to the dreaded bootloop. But hey, we’re hackers, right? I’ve got this.
It was a long, quiet Friday afternoon when I noticed my Nexus 5X was asking to install yet another update. Usually I leave these things for a few days before eventually giving in, but at some point I must have accidentally clicked to accept the update. Later that day I found my phone mid-way through the update and figured I’d just wait it out. No dice — an hour later, my phone was off. Powering up led to it repeatedly falling back to the “Google” screen; the dreaded bootloop.
Stages of Grief
I kept my phone on me for the rest of the night’s jubilant activities, playing with it from time to time, but alas, nothing would make it budge. The problem was, my Nexus still had a full day’s video shoot locked away on its internal flash that I needed rather badly. I had to fix the phone, at least long enough to recover my files. This is the story of my attempt to debrick my Nexus 5X.
I hit the Internet for research. It became apparent that the Nexus bootloop was a common problem, and not just for the 5X. Other models had suffered similar issues which made searching for relevant information difficult. Just about everybody out there was saying it had happened to them just after an update. A lucky few had success by reflashing an OS image to their phone. Others made warranty claims to the manufacturer and received back refurbished units. But I needed my files and warranties weren’t an option anyway, due to buying the phone in Hong Kong and living in Australia.
After trying in vain to get the phone to boot even into recovery mode, I read whisperings on forums that leaving the phone in the freezer could help. By this point, my phone was completely unresponsive — a total brick. It wouldn’t even show signs of life plugged into the charger; nary a battery filling animation, nor a blinking LED. The freezer sounded only slightly ridiculous, so, being otherwise out of ideas, I gave it a shot. Imagine my elation when it started to boot up! I made it all the way to the home screen before it came to a dead stop, and returned to its looping ways.
The almost-success of the freezer fix gave me a glimmer of hope. It seemed to suggest that the issue wasn’t just one of software, but had a hardware component that could be manipulated thermally. I redoubled my efforts, coming across a video that appeared to solve the problem. [Tony Rednik] used a heat gun on the motherboard, before reassembling. This allowed the phone to boot and [Tony] reported using the phone for several months afterwards.
It’s Getting Hot in Here, So Take Out All the Screws
After a stop by iFixit to check out their Nexus 5X teardown, I felt confident I could disassemble the phone without breaking it. The Nexus really is well designed, using only Phillips head screws of what appear to be equal length all around (are you listening Apple?), with a modular design that makes most repairs quite easy. The only thing the guide didn’t cover was the removal of the metal shields over the main ICs. These popped right off with the gentle application of a flathead screwdriver.
Matching my timing to the video I’d seen, I gave the board a 30 second dose from my hairdryer on its hottest setting. I put it all back together and took a deep breath. Lo and behold, it booted! I was ready and waiting to snap into action, plugging the phone straight into my laptop to dump my vital data. With the video recovered, the phone then crashed after approximately 20 minutes of use.
With my primary objective completed, there was little left to lose. I decided I’d try to get the phone running properly. If I could get it operational, it’d be useful to have a spare phone around – I’d already upgraded to a Google Pixel at the first sign of trouble. It’s tough to be without a phone these days.
Let’s Try a Reflash
I gave the board a heavier serving this time: a full 3 minutes of hot air. Alas, no, the phone wouldn’t boot! My next step was to at least see if we could get into recovery mode. After reciting the sacred incanation of holding POWER and Volume Down at the same time, selecting Recovery Mode, then holding POWER while tapping Volume Up, I finally had a recovery menu, and some real options. Online wisdom said to format the cache partition, before flashing a fresh ROM using ADB (Android Debug Bridge) over USB. Easy enough, right?
Well, no. Historically, the Android Debug Bridge set of tools has been painful and difficult to install. Recent times have given us the 15 Second Installer, and I was excited — until this too failed to work. Half an hour of banging my head against the wall and I then realized the automated script was confused because, through a hamfisted backup attempt, my Desktop folder is on the E: drive. With that sorted, I was in.
With the phone ready and waiting, I fired up the command line and started the flashing process. It started at a glacial pace… 1%…2, 3… but the phone was responding in kind. It was not, however, to be. At 5% the computer reported that the connection was lost and the handset was frozen solid. This was pretty much the worst possible result — the last thing that you want to happen during an update or flashing process is for the device to crash or lose power. It literally doesn’t get worse than that.
At this point, I was tired of the whole business. I tried a few more cycles of heat and freezing, but could by this point not even reach recovery mode, let alone start to flash the device or run the phone’s own factory reset process. It was a disappointing end, for sure.
I resigned myself to editing the video of the repair and leaving it at that. But it left me scratching my head – what was the true cause of the problem? The YouTube comments turned up this gem:
The LG G4, V10, and the Nexus 5X are all affected by the bonded flipchip substrate breaking off of the BGA package under the CPU, which usually manifests in bootlooping or screen corruption, and eventually a complete brick. It’s not solder related; the only way to fix it is by completely replacing the CPU package with one that isn’t defective. – FrankTheCat
It turns out there’s a class action lawsuit against LG from G4 & V10 owners that have run into this problem. For those following along at home, LG is also the manufacturer of the Nexus 5X, despite its Google branding. Huawei handled the Nexus 6P, however that apparently has a bootloop problem as well.
This leads me to my current conclusion. The fact that the phone does respond to cooling and heating, combined with a lawsuit covering this issue with similar phones, suggests that the problem is indeed related to hardware. I think it’s possible that the community’s belief that the problem is related to software updates is due to their frequency. With Google releasing an update every few weeks or so, it’s likely that at the time your phone does fail, it will be close enough to a recent update that a human looking for patterns will identify the update itself as the cause of the problem. Can I prove this? Not really, no – but I’d love to hear your opinions and experiences. Is this solely a hardware problem, with the stress of installing an upgrade package (which usually includes reoptimization of all installed apps) pushing the failure past the red line?
why go to all the work with salt and water.
why not put it in a container or ziplock bag and shove it into the freezer with a usb hanging out? infinite cold to download data. no pesky water to make things worse
Superb, I followed what you did but used a heat gun and my phone is back to working normally ! (at least for a while)
The circuit board was so hot little bubbles appeared in places, but it doesnt seem to have done it any harm.
thanks for taking the time to do this guide
I’ve tried all online availabe bullshit for resolution, Restoring factory via flash fastboot recovery, my device state shown locked, . My device only accessible to bootloader menu, there isn’t any further display expect Google logo…. No command worked, I’ve tried from Mac terminal to access after bunches of required downloads (drivers, image, etc), but device never went further from Google logo.. i have to Restart bootloader everytime for returning boot loader, i tried for there days to make device usable . You all going to laugh & think as rubbish, however experiment made my phone alive with all data , here’s how
1) Zip bag moisture resistance, Open back cover safely, put coverless device in Zip bag, keep Zip bag in efrigerator (15-20°C,insist to keep in lower basket)
2) keep coverless device for 4-5 hours in cool Temp.
3) Remove device from bag, allow to settle dowa Temp to at 35-38°C.
4) Connect coverless device to original charger (5V,3Amp) / PC Output for minimum 4 hours, until device warm up about 45-50 °C,
5) when you Connect Charger, freezed non charging full battery display, that doesn’t mean your battery is charged, continue Charging, leave device as it is. (no Commands)
6) Battery symbol will go, Google screen appears, after a hour untouched position, Android logo Appears, That’s it… Cheers, believe or not but tried, experimented personally & succeeded.
7) in case if you not proceeding from battery to Google’s Name, again try to open bootloader directly by key combination, bootloader also becomes responsive and you’ll able to log in Recovery mode for wiping Data to reset it to factory settings…..
Acknowledge thanks if worked, it may help similar
Thanks
JD Patel
I conclude on the basis of the above entries that there are temperature sensors and voltage sensors that force the processor to run in a “economical” mode of operation, i.e. without all active cores. Thanks to this, it is possible to start the system for a short time, until the system itself switches on the remaining cores.
My Nexus 5 just bricked, just a little over a year since I bought it, so the original warranty had just expired. Spent a while chatting with Google tech support, who were aware of the problem and asked me if it happened after an update (it hadn’t, I was just taking a pic of a cute bunny). They referred me to LG tech support, who were also aware of this ongoing issue and said my only option was to send in the phone for repair. Since I can’t go two weeks with no phone, I paid the extra $30 for expedited service, which it turns out will take 9 days. They and Google both told me they’d extended the warranty on this product.
I feel pretty bitter about them not at the very least covering the expedited shipping costs when they’re aware their product is defective. After reading this forum, I’m extra pissed because they were apparently aware as they sold me the phone. Now I’m having a difficult time getting by with no phone service, but Google and LG don’t seem to care. Corporate pricks.
I have a Nexus 5 and 2 Nexus 6p’s. Both have their own share of issues. Bootlooping, batteries that shut down at 60%, you name it.
Hello Lewin day, PLEASE HELP
I had same issue with LG nexus 5x after installing an update by Google, I am able to goto the Recovery mode, but it is kind of in a loop, LG said that they can fix it but data will be lost, can you please provide more info what software you loaded into the phone at the end of video from your computer that it started working, I just want to recover data.
Ack, your video leaves out the most critical part. Right when you finally get it working after hooking it up to your PC, you say you “booted into recovery mode”, but you didn’t show what actually happened on the screen. Looks like you went into recovery mode but then what commands did you use to get it to actually boot into andriod from there?!?
Despite the lacking portion of the video, I went ahead and took my phone apart and heated it up with the hair dryer and it worked! Phone is actually working great now! I have a new Pixel 3 arriving tomorrow so I am hoping the Nexus 5x keeps limping along until I can actually transfer everything onto the new phone normally.
I’m having problems (bootloop) with a Motorola “Moto X30 Pro – XT2241-1” (original Chinese version of the Motorola Edge 30 Ultra). It won’t boot up completely. Its bootloader is locked and I can’t unlock it (I followed the instructions on the Motorola website and the command “fatboot oem unlock CODE RECEIVED” is unsuccessful because “OEM Unlock” is disabled in the settings and I can’t access it to change it, since the device is in an infinite bootloop).
Notes:
1) I have access to the Bootloader, Recovery, Fastbootd and EDL (the latter via a USB cable that I adapted myself);
2) In Recovery mode, the “Wipe data/factory reset” option DOES NOT EXIST;
3) I have the “Google Account” credentials registered on the device.
Motorola’s support is pure garbage, they don’t solve anything at all.
I have already performed several procedures and none of them managed to make the device start normally.
1) I have already performed the recovery about 5 times using the original Motorola tool (Software Fix v7.2.3.13) which correctly identifies the device and downloads the appropriate ROM (XT2241-1_EQS_RETCN_14_U1SQ34.53-33_subsidy-DEFAULT_regulatory-DEFAULT_CFC.xml). Every time, in the middle of the recovery, the message is shown: “A DEVICE WITH ENTERPRISE ATTRIBUTES WAS DETECTED, THEREFORE THE RECOVERY PROCESS WILL NOT ERASE YOUR PERSONAL DATA NOR ACTIVATE THE FACTORY RESET OPTION IN THE DEVICE SETTINGS”. At this point, there are only two options: Cancel the recovery or Continue
The software is not doing what I need most, which is to ERASE ALL MY DATA to start from “Zero”. I believe that a “Wipe data/factory reset” would solve my problem;
2) I have already burned the ROM above (downloaded by Motorola’s Software Fix) directly through “fastboot” commands, but it didn’t work. It seems that nothing can change the user data saved on the device;
3) I have used programs such as: “Halabtech Tool”, “TFTUnlock”, “MotoFlasherPro”. In the options that allowed access to the device, I changed some things but they always returned error messages when I tried things like: Factory Reset, Byspass FRP, Delete FRP, Delete MDM, etc.
I need help.
