Popcorn! Light and fluffy, it is a fantastically flexible snack. We can have them plain, create a savory snack with some salt and butter, or cover with caramel if you have a sweet tooth. Now Cornell University showed us one more way to enjoy popcorn: use their popping action as the mechanical force in a robot actuator.
It may be unorthodox at first glance, but it makes a lot of sense. We pop corn by heating its water until it turns into steam triggering a rapid expansion of volume. It is not terribly different from our engines burning an air-fuel mixture to create a rapid expansion of volume. Or using heat energy to boil water and trigger its expansion to steam. So a kernel of popcorn can be used as a small, simple, self-contained engine for turning heat energy into mechanical power.
Obviously it would be a single-use mechanism, but that’s perfectly palatable for the right niche. Single-use is a lot easier to swallow when popcorn is so cheap, and also biodegradable resulting in minimal residue. The research paper demonstrated three recipes to harness popping corn’s mechanical energy, but that is hardly an exhaustive list. There’s an open invitation to brainstorm other creations to add to the menu.
Of course, if you prefer candy over popcorn, you could build a robot actuator out of licorice instead.
Either way, the robot uprising will be delicious.
[via IEEE Spectrum]
I can’t remember in what show they mocked a commercial where popcorn was used to inflate airbags…
https://www.nbc.com/saturday-night-live/video/jiffy-pop-airbag/n10202
Thanks!
Thank you.
Although I can’t remember How or when I could have seen an american show.
“Popcorn! Light and fluffy, it is a fantastically flexible snack. We can have them plain, create a savory snack with some salt and butter, or cover with caramel if you have a sweet tooth. ”
Cheap snack, and filling for the cost conscious.
But will it work on Mars?
Yes.
I don’t know how (or if) the vacuum affects the force since the heat breaks down the starch before the kernel bursts. There’s a bunch of different demos on youtube of pop corn in a heated vacuum chamber.
according to Cody’s Lab, it works better at lower pressures.
something something phase-change
something something water-into-steam
something something resistance from atmospheric pressure
(Elon Musk in a Jim Carrey voice)
“All righty then! There is a cheap way to ease landing on Mars, AND feed the colonists!”
So theoretically I’d have better popcorn at higher elevation like some western states of US than from ocean shoreline?
Next Mars probe needs to have popcorn shield to cushion landing and to tempt Martains to come out of hiding.
You thought our current space junk problem was bad? Just add more popcorn to it from a failed container.
“We can have them plain…”
Does anybody actually eat popcorn plain especially if it’s air-popped? Tastes like packing peanuts (i.e., nothing) to me. (It really does!)
Only if I want something “filling” without adding calories or salt…
Some use popcorn for packing.
Rats!
Seems a good way to get a rodent infestation.
Apropos packing peanuts: completed the “egg drop” game in high school by putting the egg inside a ziplock bag filled with popcorn (inside a cardboard box). Salted, buttered. Ate it after the landing.
If you’re shipping express, there’s no reason that it can’t be tasty too. :)
