Fizzle Loop Synth Does It With 555 Timers
For every project that uses an Arduino to make soup or an ESP8266 to hash bitcoin, there’s always someone out there uttering the same old refrain. I could have done it with a 555. More often than not, this is true, even if it is tangential to the discussion being had. In this case however, such a statement is moot. [lonesoulsurfer] has built the Fizzle Loop Synth, featuring not one, but three triple-nickel timers.
It’s a build that delights in both presentation and performance. The hardware is elegantly slotted into a vintage metal flashlight case, which is absolutely covered in controls. It’s an aesthetic that gives us an irresistible urge to start twiddling knobs and flicking switches. Inside, two 555s are set up as basic flasher circuits, each feeding a vactrol – essentially a resistive optoisolater. Inside is an LED, which is optically coupled to a light-dependent resistor. The LEDs are flashed by the 555s, and this creates a varying resistance which is used to feed a third 555 which generates the tones.
The final result is a fun little noisebox that’s capable of generating quite the variety of bleeps, bloops and blops. There’s an onboard speaker for noodling on the go, as well as a line-out if you need to record your work on external hardware. It would be great fun to hear this circuit hooked up to a modular synth, too.
For a history lesson on the venerable 555, we’ve got you covered. Video after the break.
9 thoughts on “Fizzle Loop Synth Does It With 555 Timers
  1. I bet those 555’s could’ve been replaced with unijunction transistors…
    …the downside to which of course is that such components are “just a little” hard-to-find these days, unless you order from one of those countries that uses the Cyrillic alphabet — which has downsides of its own. But *shrug* there’s almost always a “simpler” way… subject, of course, to how one chooses to define “simpler”… ;)
  2. every time I see someone claiming they’ve made a 555 synth, it’s just a random noise making pile of crap, and most always recorded with no amplifier, no line-out and using terrible speakers. I was not disappointed by this story at all. it’s 100% craptacular.
Leave a Reply to LeithoaCancel reply
