Adora-BLE Synth Wails Without Wires
Isn’t this the cutest little synth you ever saw? The matching sparkly half-stack amp really makes it, visually speaking. But the most interesting part? There’s not a wire in sight, ’cause [Blitz City DIY]’s futuristic rig sends the bleep boops over Bluetooth LE.
Hardware-wise, both the synth and the amp are fairly simple. Underneath each of those cute little printed keys is one of those clicky momentaries that usually come with bright button caps in primary colors — the keys themselves just press-fit over the tops. All twelve ebonies and ivories are connected up to an Adafruit Feather, which communicates over Bluetooth LE to a CircuitPlayground Bluefruit (CPB) in the amp. Each time a note is played on the synth, its corresponding color circles comet-like around the CPB’s NeoPixels, which shine through the amp’s speaker grille.
The super interesting part is that all the hard work is happening in the code. Both boards have the same array of colors in rainbow order, and the CPB has an array of tone frequencies that match up one for one with the colors. For every note played, the CPB looks up the color, swirls it, and plays the note. If you want to build one, this project is wide open — [Blitz City DIY] even made a learn guide with all the dirty details. Be sure to check out the demo and extended walk-through after the break.
More in the market for making a computer keyboard? Just grab the nearest ESP32.
Via Adafruit
4 thoughts on “Adora-BLE Synth Wails Without Wires
  1. Don’t take this as nitpicking, but would it be possible to stream digital audio from it? I mean, does any cheap Bluetooth-enabled board allow to send raw audio frames? Just wondering.
  2. If it sent audio there would a lot of lag. This seems to just send a command not a wave file. Bluetooth MIDI is an example, it’s only a few years old though MIDI is early 80’s.
Leave a Reply to Tim TrzepaczCancel reply
