Vizy “AI Camera” Wants To Make Machine Vision Less Complex
Vizy, a new machine vision camera from Charmed Labs, has blown through their crowdfunding goal on the promise of making machine vision projects both easier and simpler to deploy. The camera, which starts around $250, integrates a Raspberry Pi 4 with built-in power and shutdown management, and comes with a variety of pre-installed applications so one can dive right in.
The Sony IMX477 camera sensor is the same one found in the Raspberry Pi high quality camera, and supports capture rates of up to 300 frames per second (under the right conditions, anyway.) Unlike the usual situation faced by most people when a Raspberry Pi is involved, there’s no need to worry about adding a real-time clock, enclosure, or ensuring shutdowns happen properly; it’s all taken care of.
‘Birdfeeder’ application can automatically identify and upload images of visitors.
Charmed Labs are the same folks behind the Pixy and Pixy 2 cameras, and Vizy goes further in the sense that everything required for a machine vision project has been put onboard and made easy to use and deploy, even the vision processing functions work locally and have no need for a wireless data connection (though one is needed for things like automatic uploading or sharing.) For outdoor or remote applications, there’s a weatherproof enclosure option, and wireless connectivity in areas with no WiFi can be obtained by plugging in a USB cellular modem.
A few of the more hacker-friendly hardware features are things like a high-current I/O header and support for both C/CS and M12 lenses for maximum flexibility. The IR filter can also be enabled or disabled via software, so no more swapping camera modules for ones with the IR filter removed. On the software side, applications are all written in Python and use open software like Tensorflow and OpenCV for processing.
The feature list looks good, but Vizy also seems to have a clear focus. It looks best aimed at enabling projects with the following structure:
Detect Things (people, animals, cars, text, insects, and more) and/or Measure Things (size, speed, duration, color, count, angle, brightness, etc.)
Perform an Action (for example, push a notification or enable a high-current I/O) and/or Record (save images, video, or other data locally or remotely.)
The Motionscope application tracking balls on a pool table. (Click to enlarge)
A good example of this structure is the Birdfeeder application which comes pre-installed. With the camera pointed toward a birdfeeder, animals coming for a snack are detected. If the visitor is a bird, Vizy identifies the species and uploads an image. If the animal is not a bird (for example, a squirrel) then Vizy can detect that as well and, using the I/O header, could briefly turn on a sprinkler to repel the hungry party-crasher. A sample Birdfeeder photo stream is here on Google Photos.
Motionscope is a more unusual but very interesting-looking application, and its purpose is to capture moving objects and measure the position, velocity, and acceleration of each. A picture does a far better job of explaining what Motionscope does, so here is a screenshot of the results of watching some billiard balls and showing what it can do.
9 thoughts on “Vizy “AI Camera” Wants To Make Machine Vision Less Complex
  1. Nice that it includes the Combicon (style?) connector for the digital and analog I/O. Those can be surprisingly expensive depending on who makes them.
    They say that “you can drive relays, solenoids, motors, lighting and even sprinkler valves directly.”
  2. For something that looks like a Raspb 4 and HQ camera board in a case this seems expensive. I’m not getting what I’m missing from the description.
    1. It is and it isn’t. A pi and a hq camera will total $100 off the shelf. There’s another board that ingrates a few other sensors and power management, might be another $50 off the shelf. Then there’s the lens $25 and a nice case which might cost them $1 but would cost you several hours of work to replicate. So that’s $175 plus hours of your time just for the hardware.
      Then there’s the software which saves several more hours and teaches you something.
  3. I’ve backed this, and am looking forward to scaring the crap out of the raccoons that try to get my koi. I wonder how powerful a laser would have to be to sting them through all of that fur….
