RC Sub Built With A Water Bottle
Submarines are one of the harder modes of transport to build in radio-controlled form. Doing so involves tangling with sealing electronics from water ingress and finding a way to control the thing underwater. It’s a challenge, but one relished by [Project Air] in his latest build.
The body of the sub was built from a drink bottle, serving as a stout container upon which could be mounted all the necessary hardware. Filling the bottle with water allowed buoyancy to be adjusted to a neutral level. Twin brushless motors were used for drive, while servos were waterproofed using a combination of rubber gaskets, olive oil, and sealing spray.
Control was via a floating 2.4 GHz receiver, as high-frequency radio signals don’t penetrate water very far. The floating box also carries an FPV transmitter to allow the sub to be piloted via video feed. Rather than using a ballast system, the sub instead dynamically dives by thrusting itself beneath the water’s surface.
Unfortunately, water sloshing around in the partially-filled drink bottle meant controlling the sub in pitch was virtually impossible. To fix this, [Project Air] filled the bottle completely, and then used some plugged syringes on the outside of the body to adjust buoyancy. The long heavy tether was also replaced with a much shorter one, and the sub became much more fun to drive around under water.
The build was actually built for a friendly contest with [DIY Perks], a fellow Youtuber whose efforts we covered recently. It also bears noting that better results can be had by using lower-frequency radio gear. Video after the break.
8 thoughts on “RC Sub Built With A Water Bottle
  1. A useful long range underwater communications link appears to be hard problem to solve. Currently the practical solution seems to be drive over the area of interest in a boat and drop the sub straight down on a line that acts as control and telemetry link.
  2. I like the tethered receiver idea. Indeed, water and radio waves don’t mix super well. I really like this project and a submarine is always such a fun engineering challenge. Water is a humbling foe to battle lol. I’m enjoying this recent bout of mini subs on HaD :)
Leave a Reply to abjqCancel reply
