Unix and, by extension, Linux, has a mantra to make everything possible look like a file. Files, of course, look like files. But also devices, network sockets, and even system information show up as things that appear to be files. There are plenty of advantages to doing that since you can use all the nice tools like grep and find to work with files. However, making your own programs expose a filesystem can be hard. Filesystem code traditionally works at the kernel module level, where mistakes can wipe out lots of things and debugging is difficult. However, there is FUSE — the file system in user space library — that allows you to write more or less ordinary code and expose anything you want as a file system. You’ve probably seen FUSE used to mount, say, remote drives via ssh or Dropbox. We’ve even looked at FUSE before, even for Windows.
What’s missing, naturally, is the Hackaday RSS feed, mountable as a normal file. And that’s what we’re building today.
Writing a FUSE filesystem isn’t that hard, but there are a lot of tedious jobs. You essentially have to provide callbacks that FUSE uses to do things when the operating system asks for them. Open a file, read a file, list a directory, etc. The problem is that for some simple projects, you don’t care about half of these things, but you still have to provide them.
Luckily, there are libraries that can make it a lot easier. I’m going to show you a simple C++ program that can mount your favorite RSS feed (assuming your favorite one is Hackaday, of course) as a file system. Granted, that’s not amazing, but it is kind of neat to be able to grep through the front page stories from the command line or view the last few articles using Dolphin.
Pick a Library
There are plenty of libraries and wrappers around FUSE. I picked one by [jachappell] over on GitHub. It was pretty simple and hides just enough of FUSE to be handy, but not so much as to be a problem. All the code is hidden around in Fuse.h.
One thing to note is that the library assumes you are using libfuse 3.0. If you don’t already have it, you’ll have to install the libfuse 3.0 development package from your package manager. There are other choices of libraries, of course, and you could just write to the underlying libfuse implementation, but a good library can make it much simpler to get started.
Just to keep things simple, I forked the original project on GitHub and added a fusehad directory.
Constraints
To keep things simple, I decided not to worry about performance too much. Since the data is traveling over the network, I do attempt to cache it, and I don’t refresh data later. Of course, you can’t write to the filesystem at all. This is purely for reading Hackaday.
These constraints make things easier. Of course, if you were writing your own filesystem, you might relax some of these, but it still helps to get something as simple as possible working first.
Making it Work First
Speaking of which, the first order of business is to be able to read the Hackaday RSS feed and pull out the parts we need. Again, not worrying about performance, I decided to do that with a pipe and calling out to curl. Yes, that’s cheating, but it works just fine, and that’s why we have tools in the first place.
The HaDFS.cpp file has a few functions related to FUSE and some helper functions, too. However, I wanted to focus on getting the RSS feed working so I put the related code into a function I made up called userinit. I found out the hard way that naming it init would conflict with the library.
The normal FUSE system processes your command line arguments — a good thing, as you’ll see soon. So the main in HaD.cpp is really simple:
#include <stdio.h>
#include "HaDFS.h"
int main(int argc, char *argv[])
HaDFS fs;
if (fs.userinit())
fprintf(stderr,"Can't fetch feed\n");
return 99;
int status;
status= fs.run(argc, argv);
return status;
However, for now, I simply commented out the line that calls fs.run. That left me with a simple program that just calls userinit.
Reading the feed isn’t that hard since I’m conscripting curl. Each topic is in a structure and there is an array of these structures. If you try to load too many stories, the code just quietly discards the excess (see MAXTOPIC). The topics global variable tells how many stories we’ve actually loaded.
// The curl line to read our feed
static char cmd[]="curl https://hackaday.com/feed/ 2>/dev/null | egrep '(<title>;)|(<link>)'";
// User initialization--read the feed (note that init is reserved by the FUSE library)
int HaDFS::userinit(void)
FILE *fp;
char buf[1024]; // working buffer for reading strings
if (!( fp = popen(cmd,"r") )) return 1; // open pipe
while ( fgets(buf,sizeof(buf),fp) )
string line = buf;
line = trimrss(line); // trim off extra stuff
if ( line.substr(0,7) == "<title>" ) // identify line type and process
topic[topics].title = line.substr(7);
topic[topics].title += ".html";
else if (line.substr(0,6)=="<link>")
topic[topics].url = line.substr(6);
topics++;
if ( topics == MAXTOPIC ) break; // quietly truncate a long feed
pclose(fp);
return 0;
The popen function runs a command line and gives us the stdout stream as a bunch of lines. Processing the lines is just brute force looking for <title> and <link> to identify the data we need. I filtered curl through grep to make sure I didn’t get a lot of extra lines, by the way, and I assumed lowercase, but a -i option could easily fix that. The redirect is to prevent curl from polluting stderr, although normally FUSE will disconnect the output streams so it doesn’t really matter. Note that I add an HTML extension to each fake file name so opening one is more likely to get to the browser.
By putting a printf in the code I was able to make sure the feed fetching was working the way I expected. Note that I don’t fetch the actual pages until later in the process. For now, I just want the titles and the URL links.
The Four Functions
There are four functions we need to create in a subclass to get a minimal read-only filesystem going: getattr, readdir, open, and read. These functions pretty much do what you expect. The getattr call will return 755 for our root (and only) directory and 444 for any other file that exists. The readdir outputs entries for . and .. along with our “files.” Open and read do just what you think they do.
There are some other functions, but those are ones I added to help myself:
userinit– Called to kick off the file system datatrimrss– Trim an RSS line to make it easier to parsepathfind– Turn a file name into a descriptor (an index into the array of topics)readurl– Return a string with the contents of a URL (uses curl)
There’s not much to it. You’ll see in the code that there are a few things to look out for like catching someone trying to write to a file since that isn’t allowed.
Debugging and Command Line Options
Of course, it doesn’t matter how simple it is, it isn’t going to work the first time is it? Of course, first, you have to remember to put the call to fs.run back in the main function. But, of course, things won’t work like you expect for any of a number of reasons. There are a few things to remember as you go about running and debugging.
When you build your executable, you simply run it and provide a command line argument to specify the mount point which, of course, should exist. I have a habit of using /tmp/mnt while debugging, but it can be anywhere you have permissions.
Under normal operation, FUSE detaches your program so you can’t just kill it. You’ll need to use unmount command (fusermount -u) with the mount point as an argument. Even if your program dies with a segment fault, you’ll need to use the unmount command or you will probably get the dreaded “disconnected endpoint” error message.
Being detached leads to a problem. If you put printf statements in your code, they will never show up after detachment. For this reason, FUSE understands the -f flag which tells the system to keep your filesystem running in the foreground. Then you can see messages and a clean exit, like a Control+C, will cleanly unmount the filesystem. You can also use -d which enables some built-in debugging and implies -f. The -s flag turns off threading which can make debugging easier, or harder if you are dealing with a thread-related problem.
You can use gdb, and there are some good articles about that. But for such a simple piece of code, it isn’t really necessary.
What’s Next?
The documentation for the library is almost nothing. However, the library closely mirrors the libfuse API so the documentation for that (mostly in fuse.h) will help you go further. If you want to graduate from FUSE to a “real” file system, you have a long road. The video below gives some background on Linux VFS, but that’s just the start down that path.
Maybe stick to FUSE for a while. If you prefer Python, no problem. FUSE is very popular for mapping cloud storage into your filesystem, but with your own coding, you could just as easily expose your Arduino or anything else your computer can communicate with.
This is a horrible idea because some OSs consider files on the filesystem more trusted than web pages. MacOS, for example.
Do. Not. Do. This.
RSS != web pages, but also don’t tell people to not do it just because you wouldn’t. This is a lovely example of how to write a FUSE filesystem and the point is less to do with the Hackaday RSS feed and more to do with FUSE.
find /hackaday -comment critical | xargs rm -f
Either
find /hackaday -comment critical -exec rm -f {} /;
or
find /hackaday -comment critical -print0 | xargs -0 -n 1 -P $(nproc) rm -f
Everything else is a waste of resources.
In that case fix those operating systems, rather than kicking the person who demonstrated the potential vulnerability.
I think it’s an interesting idea and will be looking into it, but what I’d really like is something that presented a headline list in such a way that if I’m reading something my position in the list doesn’t get messed up by new arrivals.
I’m still a year behind in my reading…
My intent wasn’t really that anyone would use this seriously other than as an example of how to use fuse. However, you could probably kick off the file system. Add the files there to a zip or tar file. Unmount the file system. Then do it all over again. Again every day or whatever. Or just copy it to an archive directory. However, you could also just do that with wget lol.
I think that at one point it was possible to scan headlines, which had obvious advantages for those easily sidetracked :-) I’ve had some success in the past pulling article titles off your server, but never found an effective way of presenting them (including the important YOU ARE HERE marker).
I might tinker and see if I can come up with anything useful. At present I’m at November ’20 and progressing marginally faster than articles are added.
Awesome article, thanks for reminding me of FUSE.
There are many very useful cases for representing stuff as files.
This is such a ridiculously bad idea. Yet, here I am, drawn in and loving it 🤣.
Great job!
