[Advanced Tinkering] over on YouTube has some pretty unique content, on subjects of chemistry and physics that are a little more, interesting let’s say ā anyone fancy distilling cesium? The subject of this build is the visualization of ionizing radiation tracks, with one of our old favorite physics demonstrators, the venerable cloud chamber. The build video (embedded below,) shows the basic construction and performance of a Peltier effect cooler setup. The system is used to create a layer of supersaturated (and cold) alcohol vapor in which the radiation source or other experiment can be immersed.
Peltier modules are a great solution for moving heat from one surface to another, but they are not terribly efficient at it, especially if you don’t keep the hot side temperature in check. Effectively they are a short-distance
heat pump, so you need to dump the hot-side heat elsewhere. The method [Advanced Tinkering] chose here was to use a pair of off-the-shelf water cooling blocks, mounted into a 3D printed plate. The hot side dumps into a pair of fan-cooled radiators. Four double-layer Peltier modules are wired in parallel to a 60A power supply, which seems like a lot, but Peltier modules are hungry little things. A reasonable amount of power is needed to drive the cooling fans and water pump. The vapor source is a simple pad of liquid alcohol at the top of the stack, just above a metal screen which is held at a high voltage. The vertical electric field allows visualization of the charge of emitted particles, which will curve up or down depending on their polarity.
As can be seen from the second video linked below, some really nice cloud trails are produced, so it looks like they got the setup just right!
Do you need all this complexity to visualize simple radiation paths? No, you don’t, but just temper your expectations. Peltier-based builds are not uncommon, here’s another one, but some builders say they’re not very robust, so this build uses phase-change technology instead for some serious runtimes.
Build log:
Some results:
this may just be the prettiest cloud chamber i’ve seen so far, congrats!
My grandson build a cloud chamber when he was 8. He’s 13 now, and is moving up to
bigger challenges. When he showed his video at the school science contest, they said it was too complex for an 8 year old, and refused to judge it. Sad but true. That same year he was accepted in MENSA. I was lucky enough to be able to enroll him in the “Lifetime” membership.
No he didn’t.
What a bizzare thing to lie about
https://www.youtube.com/watch?v=TUbLxQS7iy4&t=302s
I think that Bill thought of a Peltier-cooled cloud chamber, which requires quite some background in physics (basics of power electricity, heat transfer, high voltage management to bend the trajectories toward the thin sensitive zone, etc.). Although those days with internet I could even believe that such child exists, I agree that it sounds unlikely. This being said, despite justifying bill’s opinion, your grandson’s build is extremely impressive and I am certain everyone will agree on this point.
Absolutely fascinating. Thanks for sharing!
