If you’re writing a screenplay or novel, there will likely be points along the way at which you can’t get enough encouragement from friends and family. While kind words are kind, acts such as [scubabear]’s can provide a push like no other. By commissioning another 3D designer friend to model a character from the first friend’s screenplay so he could print and animate it, [scubabear] fed two birds with one scone, you might say.
Designer friend [Sean] modeled the mighty Braomar in Maya and Z-brush, and [scubabear] did test prints on a Formlabs Form2 as they went along to keep an eye on things. Eventually, they had a discussion about making space for wires and such, so [Sean] took to Blender to make Braomar hollow enough for wires, but not so empty that he would collapse under the stress of being (we presume) the main character.
Braomar stands upon a sigil that changes color thanks to an RGB LED ring in the base that’s driven by an Arduino Nano. A single pixel in the fireball is wired through Braomar’s body and flickers with the help of an addressable LED sequencer board.
Our favorite part of this build has to be the power scheme. Not content to have a wire running out from the base or even a remote control for power-draining concerns, [scubabear] used disc magnets in the base to switch on the 9 V battery when Screenplay Friend rotates it.
Of course, if you need inspiration to even thing about beginning to write a screenplay or novel, maybe you should lead with the maquette-building and then construct a story around your creation.
This project was an entry into the 2022 Sci-Fi Contest. Check out all of the winning entries here.
Don’t hate the player, hate the game.
Skylanders Lightcore did better than that, no batteries !
This is the greatest comment in the history of comments.
Could have used a light pipe or fibre optics, but this is fine.
Very nice build. A high power led would have looked awesome, but it may become a bit hot. What you can do is tweak a bit the picture, like they do for this https://www.ebay.es/itm/303326416624
Very cool – what a fantastic gift for a friend!
Out of curiosity I checked the maquette-building link: it’s an article published back in 2009. Wow the comment threads used to get rude…
Fancy, funny, footwork alliteration.
