Ceiling Fan Adds CO2 Sensor
Ceiling fans seem to be an oft-misunderstood or overlooked household appliance. As such, they seem to have missed a lot of the IoT wave. Sure, you can get smart controllers for them to plug into your home automation system of choice, but these mostly rely on temperature sensors, simple timers, or voice commands. There’s a lot more to a ceiling fan than maintaining a comfortable temperature, as [EJ] demonstrates with this smarter ceiling fan build.
A big part of the job of a ceiling fan is to improve air circulation, which can help a room from feeling “stuffy”. This feeling is usually caused by excess CO2 as a result of respiration in an area where the air is not moving enough to exhaust this gas. Not only does [EJ]’s controller make use of a temperature monitor for controlling the fan automatically, but there is also a CO2 sensor integrated to improve this aspect of air quality when needed.
The entire build is based on a Raspberry Pi Zero, and nothing needed to be changed about the ceiling fan itself for this added functionality because it already included a radio-based remote control. With some monitoring of the signals produced by the remote, the Raspberry Pi was programmed to mimic these commands when the surrounding sensors captured a condition where [EJ] would want the fan on. There’s also a manual control button as well, so the fan control is not entirely in the hands of the computer.
For a little more detailed information about this build, there’s a separate project page which details a lot of the information about the RF waveform capturing and recreation. And, if you want to take your fan to the next level, take a look at this one which focuses on building a smartphone app to control the fan instead.
18 thoughts on “Ceiling Fan Adds CO2 Sensor
    1. Amen! But, still, this is an incredibly useful idea for controlling the device (fan) that would either disperse CO2 more evenly or could alert occupants to a level causing sufficient concern or alarm.
    2. The CO2 emitted by human respiration is well-mixed and warmer than the surrounding air, at about 4.5% concentration, and will not “seperate out” and accumulate near the floor.
  1. I’ve been running setup with some thresholds to turn the central furnace fan on at a low level of 650 ppm (basic occupancy detection) and then the HRV at 800ppm to bring fresh air in. Just a mh-z19c and dht22 monitored with an ESP32 controlling a pair of relays.
    Next step is better monitoring of outside dew point as I ended up bringing a lot of humidity in this summer, so balancing co2 and rh% levels is a challenge.
    A script checks the esp every minute, logs and posts a graph http://www.flyinglow.ca/furnace/co2_week.png
  2. Why do you think CO2 makes a room stuffy? I guess what do you mean by stuffy? light-headed?
    Your product would not be popular in Korea. Fan death.
    RH% is what makes rooms stuffy. The higher the RH% the more difficult it is for your body to cool itself at any particular ambient temperature.
  3. I made co2 monitoring in a both floors of a private building with huge void between floors and the conclusion was that CO2 despite being heavier, still warmer and rising up. Even though there is no-one upfloor, CO2 is higher.
    I use fan together with skylight with velux automatic that open skylight using own CO2 sensor, so fan spinning backwards to push air up to speed up air exchange. Check my geodesic.life for more details
Leave a Reply to PaulCancel reply
