IR Camera Is Excellent Hacking Platform
While there have been hiccups here and there, the general trend of electronics is to decrease in cost or increase in performance. This can be seen in fairly obvious ways like more powerful and affordable computers but it also often means that more powerful software can be used in other devices without needing expensive hardware to support it. [Manawyrm] and [Toble_Miner] found this was true of a particular inexpensive thermal camera that ships with Linux installed on it, and found that this platform was nearly perfect for tinkering with and adding plenty of other features to turn it into a much more capable tool.
The duo have been working on a SC240N variant of the InfiRay C200 infrared camera, which ships with a Hisilicon SoC. The display is capable of displaying 25 frames per second, making this platform an excellent candidate for modifying. A few ports were added to the device, including USB and MicroSD, and which also allows the internal serial port to be accessed easily. From there the device can be equipped with the uboot bootloader in order to run essentially anything that could be found on any other Linux machine such as supporting a webcam interface (and including a port of DOOM, of course). The duo doesn’t stop at software modifications though. They also equipped the camera with a lens, attached magnetically, which changes the camera’s focal length to give it improved imaging capabilities at closer ranges.
While the internal machinations of this device are interesting, it actually turns out to be a fairly capable infrared camera on its own as well. The hardware and software requirements for these devices certainly don’t need a full Linux environment to work, and while we have seen thermal cameras that easily fit in a pocket that are based on nothing any more powerful than an ESP32, it does tend to simplify the development process dramatically to include Linux and a little more processing power if you can.
14 thoughts on “IR Camera Is Excellent Hacking Platform
      1. Actually, outside of the US at least, Infiray are both cheaper and with higher resolution/FPS than expensive IR cams
        1. Bought an InfiniRay P2 Pro with Macro lens a couple of months ago from AliExpress,shipped to the UK.
          Outstanding piece of kit and indeed the frame rate is smooth.
          1. For the same price you can get a Doogee S98 Pro that wraps a phone around the InfiniRay P2 Pro.
            Well, actually both come wrapped in a block of aluminium that presents a danger to feet & tiles when dropped.
            (Battery nerds should check the specs on the just released S100 Pro.)
    1. Another issue is washout. I don’t know about the new ones but older thermal imaging sensors had a set range they could operate at. It depended on the camera and its intended use, but a single sensor couldn’t give you much granularity over a couple hundred degrees. Very much like trying to get a clear image on a bright day with the sun in the frame. A user could move that range up or down to look for specific temps in the range but the upper and lower limits washed out completely. Legacy systems didn’t let the user move that range on the fly since the sensor had to be “reset” every time the range changed.
      The only solution I’ve come across is to use a tight cluster of sensors with deep overlapping temp ranges and a digitally “stacked” feed. The setup was processor and power hungry, not to mention expensive, but it was effective. It also cut through fog and surface level sea haze a lot better than a single thermal imaging core.
      1. When I demonstrate an IR camera to students by pointing it into the classroom, the standard disclaimer is “If you see me running, it means that I found someone in the room without a body temperature…”
        1. I should add that the display is projected on a screen for the students, so they immediately start playing “Who’s a zombie” which adds to the hilarity.
  1. This sensors are spinoff of tech China have for their military seekers. ITAR is no obstacle for them, that is why you get nice 25fps with decent resolution.
Leave a Reply to ThinkererCancel reply
