Old Clock Transformed Into Mesmerizing Light Display
It’s easy to find a cheap clock at any dollar store that will manage to tell the time, but chances are that the plastic-fantastic construction won’t do you any aesthetic favors. Fear not, though, for [ROBO HUB]’s upcycled design turns a humble clock into a mesmerizing horological display of beauty.
The build starts by scavenging the movement out of a cheap plastic clock. A CD is then glued to the front of the movement to serve as a reflective backing plate. For numerals, the clock uses F3, F6, F9, and F12 keys nabbed from a keyboard.
The real party trick, though, is in the lighting. This build is elevated beyond hackneyed 90s desk clocks by the inclusion of a ring of LED strip lighting. When switched on, the LED light reflects and refracts on the surface of the CD, creating a mesmerizing shifting pattern featuring all the colors of the rainbow.
CDs are actually quite magical from an optical perspective and have all kinds of nifty uses.
4 thoughts on “Old Clock Transformed Into Mesmerizing Light Display
  1. Wow ! A cool way to make an infinity kinda mirror. Once I use up my AOL 100 Free Hours CDs (😄 ) I plan to do this…
Leave a Reply to Staple_nutzCancel reply
