Stacking Solar Cells Is A Neat Trick To Maximise Efficiency
Solar power is already cheap and effective, and it’s taking on a larger role in supplying energy needs all over the world. The thing about humanity, though, is that we always want more! Too much, you say? It’s never enough!
The problem is that the sun only outputs so much energy per unit of area on Earth, and solar cells can only be so efficient thanks to some fundamental physical limits. However, there’s a way to get around that—with the magic of tandem solar cells!
Continue reading “Stacking Solar Cells Is A Neat Trick To Maximise Efficiency” →
Older Nissan Leafs Lose Their App, Are They The First Of Many?
There was a time when all you needed to use your car was a key. On older vehicles it was a traditional metal key, on more recent ones it had some kind of RFID chip for the immobilizer. As vehicles have become more and more computers on wheels though, the key has disappeared in favor of an electronic key using RF, and in many cases a smartphone application. It’s even used as a selling point: “Look how amazing our car is, you open it with an app!”
Now the obvious flaw is beginning to show in this strategy, as Nissan Leafs made before 2016 and on the road in the UK are to have their app support withdrawn. The manufacturer cites the withdrawal of 2G services, but this seems a little fishy when you consider that the older networks will continue to exist in some form until 2030.
Frankly, there’s part of us that welcomes this news. On one hand, it affects relatively few early adopters. But at the same time, it has the promise of finally educating a gullible public that while a car may last into its second or third decade, the superfluous technology with which it has been loaded probably won’t. If it makes consumers clamor for longer support, or better built vehicles, it can only be a good thing. We’re guessing stories like this will become increasingly common in the next few years — luckily for Leaf owners, its relatively trivial loss of functionality won’t be the worst among them.
If the carmakers have forgotten how to make a vehicle without the dross, we’d be delighted to remind them.
Header: Kārlis Dambrāns, CC BY 2.0.
Thanks [CampGareth] for the tip.
Fabbing A Fab New Watch Face
[STR-Alorman] is into vintage watches, particularly Omega Seamaster quartz numbers from the 1980s. Among his favorites is the Seamaster Calypso III, a precious few of which were created in a lovely and rare black-on-black colorway. [STR-Alorman] found one on online, but it had a number of problems including a scratched-up face. Having done a respectable amount of PCB design and assembly, he decided to make a new face and have it fabbed.
The one angle where you can even tell this is a PCB.
After taking scale-referenced photos with a DSLR, [STR-Alorman] created vectors in Illustrator and then ported those to KiCad. He sent two versions to the board house — one with holes at index points, and one without — because he wasn’t sure which would be better for applying the luminization compound that makes them glow. Spoiler alert: it was the one with the cutouts.
Once this was done, [STR-Alorman] reassembled the movement, which doesn’t look easy at all, and involved getting the height of a bit of CA glue just right so as not to interfere with the movement of the date wheel. He replaced the bezel insert, re-luminized the hands, and now has a beautiful timepiece.
We believe only the nerdiest of nerds could tell this is a PCB, and they would need exactly the right light to make that determination. Here’s a watch that leaves no doubt about it.
