Supercon 2023: Ben Combee And The Hacker’s Guide To Audio/Video Formats
Media formats have come a long way since the early days of computing. Once upon a time, the very idea of even playing live audio was considered a lofty goal, with home computers instead making do with simple synthesizer chips instead. Eventually, though, real audio became possible, and in turn, video as well.
But what of the formats in which we store this media? Today, there are so many—from MP3s to MP4s, old-school AVIs to modern *.h264s. Senior software engineer Ben Combee came down to the 2023 Hackaday Supercon to give us all a run down of modern audio and video formats, and how they’re best employed these days.
Vaguely Ironic
Thanks to vectrexer, who raised the alarm that the stream’s sound needed to be kicked into gear.
Before we dive into the meat of the talk, it’s important we acknowledge the elephant in the room. Yes, the audio on Ben’s talk was completely absent until seven minutes and ten seconds in. The fact that this happened on a talk about audio/visual matters has not escaped us. In any case, Ben’s talk is still very much worth watching—most of it has perfectly fine audio and you can quite easily follow what he’s saying from his slides. Ben, you have our apologies in this regard.
Choose Carefully
You know the great thing about MP3? The patents expired in 2018!
Ben’s talk starts with fundamentals. He notes you need to understand your situation in exquisite detail to ensure you’re picking the correct format for the job. You need to think about what platform you’re using, how much processing you can do on the CPU, and how much RAM you have to spare for playback. There’s also the question of storage, too. Questions of latency are also important if your application is particularly time-sensitive, and you should also consider whether you’ll need to encode streams in addition to simply decoding them. Or, in simpler terms, are you just playing media, or are you recording it too? Finally, he points out that you should consider licensing or patent costs. This isn’t such a concern on small hobby projects, but it’s a big deal if you’re doing something commercially.
When it comes to picking an audio format, you’ll need to specify your desired bit rate, sample size, and number of channels. Metadata might be important to your application, too. He provides a go-to list of popular choices, from the common uncompressed PCM to the ubiquitous MP3. Beyond that, there are more modern codecs like AAC and Vorbis, as well as those for specialist applications like aLaw and uLaw.
Brightness is what humans notice most! That lets you do some neat things where you spend more data on brightness levels and less on specific colors.
Ben notes that MP3 is particularly useful these days, as its patents ran out in 2018. However, it does require a lot of software to decode, and can take quite a bit of hardware resources too (on the embedded scale, at least). Meanwhile, Opus is a great open-source format that was specifically designed for speech applications, and has low bitrate options handy if you need them.
When it comes to video, Ben explains that it makes sense to first contemplate images. After all, what is video but a sequence of images? So many formats exist, from raw bitmaps to tiled formats and those relying on all kinds of compression. There’s also color formats to consider, along with relevant compression techniques like run-length encoding and the use of indexed color palettes. You’re probably familiar with RGB, but Ben goes through a useful explanation of YUV too, and why it’s useful. In short, it’s a color format that prioritizes brightness over color information because that’s what’s most important to a human viewer’s perception.
Decoding video usually means storing multiple frames in memory.
As for video formats themselves, there are a great many to pick from. Motion JPEG is one of the simplest, which is mostly just a series of JPEGs played one after another. Then there are the MPEG-1 and MPEG-2 standards from the 1990s, which were once widespread but have dropped off a lot since. H.264 has become a leading modern video standard, albeit with some patent encumbrances that can make it hard or expensive to use in some cases. H.265 is even more costly again. Standards like VP8, VP9, and AV1 were created to side step some of these patent issues, but with mixed levels of success. If you’re building a commercial product, you’ll have to consider these things.
Ben explains that video decoding can be very hardware intensive, far more so than working with simple images. Much of the time, it comes down to reference frames. Many codecs periodically store an “I-frame,” which is a fully-detailed image. They then only store the parts of the image that change in following frames to save space, before eventually storing another full I-frame some time later. This means that you need lots of RAM to store multiple frames of video at once, since decoding a later frame requires the earlier one as a reference.
Interestingly, Ben states that MPEG-1 is one of his favorite codecs at the moment. He explains its history as a format for delivering video on CD, noting that while it never took off in the US, it was huge in Asia. It has the benefit of being patent free since 2008. It’s also easy to decode with in C with a simple header called pl_mpeg. It later evolved into MPEG-2 which remains an important broadcast standard to this day.
Ben explains the nitty-gritty syncronization work he did in CircuitPython to sync audio with his custom Daft Punk word clock.
The talk also crucially covers synchronization. In many cases, if you’ve got video, you’ve got audio that goes along with it. Even a small offset between the two streams can be incredibly off-putting; all the worse if they’re drifting relative to each other over time. Sync is also important for things like closed captions, too.
Ultimately, if you’re pursuing an audio or video project and you’ve never done one before, this talk is great for you. Rather than teaching you any specific lesson, it’s a great primer to get you thinking about the benefits and drawbacks of various media formats, and how you might pick the best one for your application. Ben’s guide might just save you some serious development time in future—and some horrible patent lawsuits to boot!
8 thoughts on “Supercon 2023: Ben Combee And The Hacker’s Guide To Audio/Video Formats
  1. @Lewin Day said: “But what of the formats in which we store this media? Today, there are so many—from MP3s to MP4s, old-school AVIs to modern *.h264s. Senior software engineer Ben Combee came down to the 2023 Hackaday Supercon to give us all a run down of modern audio and video formats, and how they’re best employed these days.”
    Skip the drama… Just take a look at what codecs and packages are currently most popular and efficient on your favorite BitTorrent aggregator site. That’s your answer – quick and easy.
    Don’t worry about playback. I find no matter what codec and package it is, an up to date copy of Media Player Classic Black Edition (MPCBE) and/or VideoLAN’s VLC Media Player (VLCMP) can usually handle it just fine.[1][2]
    Media Player Classic – Black Edition (MPCBE)
    https://sourceforge.net/projects/mpcbe/
    https://www.videolan.org/vlc/
  2. In looking at my talk, my target for this is people doing things of small microcontrollers, up to the ESP32 or RP2040, not people building Linux devices. It’s much easier when you’ve got Raspberry Pi-class hardware, but also a lot more expensive, especially if your designing things to give out or sell.
    1. I’ve always loved looking at reverse engineered FMV formats from 90’s CD games, seeing the trade offs they made in space/time complexity. One of my favorite sites is the game codecs section of the multimedia wiki at multimedia.cx. I like to tinker with non-transform video compression, like Westwood VQA or MVE from Wing Commander III. An esp32 or pi pico is almost overkill for those.
  3. Why not take an image, store an area of color once, and then only store the relative change in hue and saturation, plus indexing the luminance. You don’t have index every color, really the most used color in the picture or based from apparent color temperature of the lighting…
    So if a “scanline” or “bitmap” would be yellow or orange, you’d just just store as green with the red/blue difference as an index or sort of checksum or hash combined with either the exact or average luminance for that line or bitmap pixel array and stores that as well in a checksum or hash
    So youd end up with a array of hashes and or checksum bytes for the color and how bright it should appear, and it’s array location (where in the picture that pixel goes), that you can put through a expansion function, in a double scanning way, scanning vertically up and down and side to side horizonally
    Based dpi or how many pixels in a line, and how many rows and columns
    And how much color precision 4,8,16,32,64bit?
    It’s not like common dictionary compression that just takes repeated values and just stores a pointer in a “dictionary list” of what the value it is, you literally store the value and procedurally generate the other needed data from the hash and checksums, if you got a good crypto Engine on that i7 or amd, this would be compression a gpu would be wanted for. Might get a güt file size for an hd photo but may take some extra post processing time. So a picture file would instead not included any actual picture data, just some header information and a bunch of hashes and checksums, more like a display list for a gpu than a picture file, or even audio
    You feed this display list to a library.dll and codec.dll and spit out pictures and audio just like any other compression. Just that imagine having an hour of 1080 60fps but only 100megs or so
    Kinda like using dpcm on image data
Leave a Reply to Fifty1FordCancel reply
