Repairing An Old Heathkit ‘Scope
With so many cheap oscilloscopes out there, the market for old units isn’t what it used to be. But if you have a really old scope, like the Heathkit O-10 that [Ken] found in his basement, there is vintage cred to having one. [Ken’s] didn’t work, so a repair session ensued. You can see the results in the video below.
You can tell this is in an old scope — probably from the mid 1950s — because of its round tube with no graticle. Like many period scopes, the test probe input was just 5-way binding posts. The O-10 was the first Heathkit “O-series” scope that used printed circuit boards.
The device looked pretty good inside, except for a few dents. Of course, the box has tubes in it, so every power up test involves waiting for the tubes to warm up. [Ken] was very excited when he finally got a single green dot on the screen. That did, however, require a new CRT.
It wasn’t long after that he was able to put a waveform in and the scope did a good job of reproducing it. The unit would look good in an old movie, but might not be the most practical bench instrument these days.
These Heathkit scopes and their cousins were very popular in their day. The $70 price tag sounds cheap, but in the mid-1950s, that was about a month’s rent in a four-room house. While primitive by today’s standards, scopes had come a long way in 9 or 10 years.
8 thoughts on “Repairing An Old Heathkit ‘Scope
  1. Used to see those Heathkit units at the larger flea markets, rather often.
    I think some of them were eventually tossed by the dumpster on Sunday and then someone else just grabbed it for the next weekend. Ad infinitum. Thus I probably wasn’t seeing as many as I first thought. People wanting 50~80 dollars for them.
    Sometimes crusty/ashy, looked like they had been stored in an idled poultry barn or leaky trailer. Gotta love those Craigslist/Flea market guys that will scrub anything with “purple/green cleaner” and then spray it with tire & wheel shine.
  2. I have one sitting on my shelf. I have opened the case to look at the wiring and tubes. it needs a cleaning and there is at least one wire which needs to be replaced. It runs through the whole device and is very very corroded.
  3. I had one of those scopes. There was an optional green plastic graticle that you could fit in front of the screen. It was a friction fit into the soft fuzzy black cloth that was part of the bezel in front of the screen.
    With the graticle in place it looked like a real “professional” scope to a 14 year old hobbyist- it became really cool-looking, which of course was so important!
  4. Old scopes are my weakness, especially if they don’t work. They are my version of a mystery novel. I love tracing down the problems to get the scope working again. As long as the transformer is good, the scope is repairable.
    Just to be sure, the voltages are dangerous, so know what you are doing. Add bleeder resistors to the power lines to discharge the filter capacitors after turning off. Just to be sure, unplug and verify that voltage is dropped before going in.
    Oh! For old pieces like this, replace the electrolytics first. Some believe in slow power ups to rebuild the internal structure, but seals weren’t as good back then as they are now. If a filter cap fails short, that could blow the power transformer.
Leave a Reply to AnonymousCancel reply
