Look! It’s A Knob! It’s A Jack! It’s Euroknob!
Are your Eurorack modules too crowded? Sick of your patch cables making it hard to twiddle your knobs? Then you might be very interested in the new Euroknob, the knob that sports a hidden patch cable jack.
Honestly, when we first saw the Euroknob demo board, we thought [Mitxela] had gone a little off the rails. It looks like nothing more than a PCB-mount potentiometer or perhaps an encoder with a knob attached. Twist the knob and a row of LEDs on the board light up in sequence. Nice, but not exactly what we’re used to seeing from him. But then he popped the knob off the board, revealing that what we thought was the pot body is actually a 3.5-mm audio jack, and that the knob was attached to a mating plug that acts as an axle.
The kicker is that underneath the audio jack is an AS5600 magnetic encoder, and hidden in a slot milled in the tip of the audio jack is a tiny magnet. Pop the knob into the jack, give it a twist, and you’ve got manual control of your module. Take the knob out, plug in a patch cable, and you can let a control voltage from another module do the job. Genius!
To make it all work mechanically, [Mitxela] had to sandwich a spacer board on top of the main PCB. The spacer has a large cutout to make room for the sensor chip so the magnet can rotate without hitting anything. He also added a CH32V003 to run the encoder and drive the LEDs to provide feedback for the knob-jack. The video below has a brief demo.
This is just a proof of concept, to be sure, but it’s still pretty slick. Almost as slick as [Mitxela]’s recent fluid-motion simulation pendant, or his dual-wielding soldering irons.
17 thoughts on “Look! It’s A Knob! It’s A Jack! It’s Euroknob!
      1. If I understood correctly, the spin control only works when the special jacknob is used.
        As soon as something else is plugged, the voltage it provides is used to control the parameter.
    1. It’s against good UI design practice though.
      Knobs and sliders should indicate their value by their positions. It’s no longer possible for the indicator to point at the value of the knob in each mode, because that would make the value jump every time you switch modes. It’s also difficult to press the button without twisting the knob at the same time.
      I.e. why just about every digital oscilloscope has a bad user interface. Changing settings with a twisty push button always ends up in “oops, not that one…. oop, not that one either!”.
        1. The knob position is marked with a white line, and the LED is there to indicate the level when the knob is disconnected.
          Of course, because it’s programmable, you could change this (and he talks about doing this in the video, making it a multi-turn fine tune knob) but the behavior he shows is very much mapping the indicator mark on the knob to an absolute position.
  1. @hackaday: As Youtube is now guessing which automatically translated annoying machine language I “want” to listen too, is there a way for you to enable the option to switch the embedded video back to its original language? Or do I always have to go to Youtube and watch it there and change the language settings?
  2. This is a cool idea, and perhaps this is the right way to do it if you want a free-spinning encoder.
    Since it’s usually going to control a parameter with a finite range, though (as that’s what a CV jack does), it might make more sense to put a potentiometer inside the knob instead. Then you’d add a pin that fits into a second hole to give the knob something to spin against, and line it up with markings on the panel. And you could also use that pin to supply a reference voltage for the pot.
    I feel like I’ve seen audio devices that build a 3.5mm jack into the knob for a similar reason, but this is better. It would be cool if it became a standard.
    1. You’re over-engineering it. If you want to limit the rotation of the knob, just [use Mitxela’s approach and] have a pin in the panel that sticks up into the bottom of the knob, and have a C-shaped track cut into the bottom of the knob for the pin, limiting the rotation.
  3. Perhaps knobs could be stackable.
    Hall effect sensors are pretty small.
    If four pin jacks were used, they could be daisy chained like an LED strip. With different functions per level, course, fine, display, input, rotary encoder, input button, etc. Maybe with a larger wheel progressing to smaller and smaller knobs, in a step pyramid design.
Leave a Reply to BobtatoCancel reply
