An LLM For The Raspberry Pi
Microsoft’s latest Phi4 LLM has 14 billion parameters that require about 11 GB of storage. Can you run it on a Raspberry Pi? Get serious. However, the Phi4-mini-reasoning model is a cut-down version with “only” 3.8 billion parameters that requires 3.2 GB. That’s more realistic and, in a recent video, [Gary Explains] tells you how to add this LLM to your Raspberry Pi arsenal.
The version [Gary] uses has four-bit quantization and, as you might expect, the performance isn’t going to be stellar. If you are versed in all the LLM lingo, the quantization is the way weights are stored, and, in general, the more parameters a model uses, the more things it can figure out.
As a benchmark, [Gary] likes to use what he calls “the Alice question.” In other words, he asks for an answer to this question: “Alice has five brothers and she also has three sisters. How many sisters does Alice’s brother have?” While it probably took you a second to think about it, you almost certainly came up with the correct answer. With this model, a Raspberry Pi can answer it, too.
The first run seems fairly speedy, but it is running on a PC with a GPU. He notes that the same question takes about 10 minutes to pop up on a Raspberry Pi 5 with 4 cores and 8GB of RAM.
We aren’t sure what you’d do with a very slow LLM, but it does work. Let us know what you’d use it for, if anything, in the comments.
There are some other small models if you don’t like Phi4.
32 thoughts on “An LLM For The Raspberry Pi
    1. Interestingly, Llama 3.3 70B, is the only one, of those I’ve tried, that answered a few variations of the Alice question correctly first time. GBT could do it, but only after being asked, what about Alice, some failed entirely, even after multiple hints, they just kept insisting on their own correctness.
      1. I see no point in even trying to make LLMs reason correctly. What for? Much better to force them to translate any reasoning problem they face into Prolog or SMT, offload the reasoning to a tool, then translate back the result. Even the smallest LLMs can do it well.
      2. Just tested the smallest Gemma-3, Qwen3 and Phi-4 models with Prolog on the Alice question, all managed to produce the right result (via a standard trial-and-error sandbox loop). Some took longer than the others, Qwen yapped about its own reasoning for a while until finally got to Prolog, but all got to the right answer.
    1. Yeah, check out LMstudio.
      You can use any model that’ll fit into your RAM or VRAM, but if you want anything approaching “real time”, then it really needs to be VRAM. A 4060Ti 16GB is probably the best current gen mid-low end option.
      You might be able to get Intel or AMD cards working but it may be a nightmare. CUDA is very polished: anything GTX900 series or later will run “straight out of the box”, I’ve even run stablediffusion on a 650GT without issue.
      Arm based Macs are also very popular for running LLMs since they have a unified pool of RAM which extremely high speed and low latency, while (for the higher RAM specs) costing around 10x less than a GPU with the same amount.
      1. I find lmstudio’s vulkan runtime kinda sucks. Running koboldcpp with no special tricks, literally just ./filefromgithubrepo and selecting my backend+model+context size, on amd 780m igpu minipc with Ryzen 7940HS and 2 sticks of no name ddr5 ram (64 gb total) kobold correctly realizes the igpu can take half the total ram for offload whereas lmstudio either refuses to offload at all or crashes when it exceeds the 2 gb default allocation. It also runs slow as molasses while koboldcpp zips along with input processing at 132 tokens a second and generation at just over 5 a second. It’s super usable real time on koboldcpp, it’s a ask a question and come back in 15 minutes kinda experience on lmstudio.
        On cuda though LM Studio is easily the most polished experience you can have, no argument there.
    1. This shouldn’t be surprising. AI models are physically incapable of performing mathematical operations, they only produce a sentence by selecting the next most-likely word.
      If it produces the right answer, it’s chance, and you could fairly easily “persuade” it to output the right answer – or any arbitrary answer for that matter.
  1. were are we in the bell curve regarding this ai/llm thing?
    first search engines gave correct answers to a wrong understood question, now we have a system giving incorrect answers to perfectly understood questions.
  2. Here is something interesting:
    I just asked Copilot the same question it responded three, when I pointed out the answer is four, because Alice is also his sister, it asserted I was correct. Asking ChatGPT, it took slightly longer to analyze the question but it came back with the correct answer.
  3. Fascinating. The electricity required, 10 minutes to generate a response, is a good illustration of the resources LLM’s require. Id love to see the math, but I suspect Google and OpenAI are hemorraging cash to keep this train going.
    1. This has been my thought about AI from the beginning: is it worth the electric power (largely oenerated with air polluting fossil fuels) to get a partially correlt answer a little faster than a reasonably intelligent human can do running on glucose, a very clean fuel?
  4. Although I only have a 5800XT, I do have an RTX Super.
    Will Phi4 be able to compete with Gemini 2.5 Pro as I have that as my current LLM (paid version so I use it on my Pixel 7a as well).
    I’ve seen lots of videos saying Gemini 2.5 pro is heads above everything.
    Even going head to head with ChatGPT 4, Gemini 2.5 pro just crushes it on everything.
  5. It’s impressive that a Raspberry Pi 5 can even run a 3.8B parameter LLM like Phi-4 mini, even if it takes 10 minutes to answer a simple question. While not practical for real-time use, it’s a great demo of how far edge computing has come—and a fun way to experiment with LLMs on a budget.
    1. RPi 5 is rubbish compared to an average smartphone, which can run a small LLM locally in seconds, not minutes. You can try it in web browser using Candle Phi Wasm, ONNX Runtime Web or MediaPipe.
  6. A timely post considering i just today received my order of a couple of OrangePi RV2. RISC-V seems to be the future of vector instructions. I’m not sure what 2 TOPS gets me with little LLM’s but who doesn’t love having some new tech to poke and prod. They even have multiple LLM models available for it.
  7. I did this last weekend, but with TinyLlama and a RPI3B, 2gb of swap and it was answering questions a lot faster than 10mins. Amazing what an old hunk of junk can still achieve.
Leave a Reply to combinatorylogicCancel reply
