Falling Down The Land Camera Rabbit Hole
It was such an innocent purchase, a slightly grubby and scuffed grey plastic box with the word “P O L A R O I D” intriguingly printed along its top edge. For a little more than a tenner it was mine, and I’d just bought one of Edwin Land’s instant cameras. The film packs it takes are now a decade out of production, but my Polaroid 104 with its angular 1960s styling and vintage bellows mechanism has all the retro-camera-hacking appeal I need. Straight away I 3D printed an adapter and new back allowing me to use 120 roll film in it, convinced I’d discover in myself a medium format photographic genius.
But who wouldn’t become fascinated with the film it should have had when faced with such a camera? I have form on this front after all, because a similar chance purchase of a defunct-format movie camera a few years ago led me into re-creating its no-longer-manufactured cartridges. I had to know more, both about the instant photos it would have taken, and those film packs. How did they work?
A Print, Straight From The Camera
An instant photograph of a bicycle is being revealed, as the negative is peeled away from the print.
An instant photograph reveals itself. Akos Burg, courtesy of One Instant.
In conventional black-and-white photography the film is exposed to the image, and its chemistry is changed by the light where it hits the emulsion. This latent image is rolled up with all the others in the film, and later revealed in the developing process. The chemicals cause silver particles to precipitate, and the resulting image is called a negative because the silver particles make it darkest where the most light hit it. Positive prints are made by exposing a fresh piece of film or photo paper through this negative, and in turn developing it. My Polaroid camera performed this process all-in-one, and I was surprised to find that behind what must have been an immense R&D effort to perfect the recipe, just how simple the underlying process was.
My dad had a Polaroid pack film camera back in the 1970s, a big plastic affair that he used to take pictures of the things he was working on. Pack film cameras weren’t like the motorised Polaroid cameras of today with their all-in-one prints, instead they had a paper tab that you pulled to release the print, and a peel-apart system where after a time to develop, you separated the negative from the print. I remember as a youngster watching this process with fascination as the image slowly appeared on the paper, and being warned not to touch the still-wet print or negative when it was revealed. What I was looking at wasn’t a negative printing process as described in the previous paragraph but something else, one in which the unexposed silver halide compounds which make the final image are diffused onto the paper from the less-exposed areas of the negative, forming a positive image of their own when a reducing agent precipitates out their silver crystals. Understanding the subtleties of this process required a journey back to the US Patent Office in the middle of the 20th century.
It’s All In The Diffusion
A patent image showing the Land process in which two sheets are feed through a set of rollwes which ruprure a pouch of chemicals and spread it between them.
The illustration from Edwin Land’s patent US2647056.
It’s in US2647056 that we find a comprehensive description of the process, and the first surprise is that the emulsion on the negative is the same as on a contemporary panchromatic black-and-white film. The developer and fixer for this emulsion are also conventional, and are contained in a gel placed in a pouch at the head of the photograph. When the exposed film is pulled out of the camera it passes through a set of rollers that rupture this pouch, and then spread the gel in a thin layer between the negative and the coated paper. This gel has two functions: it develops the negative, but over a longer period it provides a wet medium for those unexposed silver halides to diffuse through into the now-also-wet coating of the paper which will become the print. This coating contains a reducing agent, in this case a metalic sulphide, which over a further period precipitates out the silver that forms the final visible image. This is what gives Polaroid photographs their trademark slow reveal as the chemistry does its job.
I’ve just described the black and white process; the colour version uses the same diffusion mechanism but with colour emulsions and dye couplers in place of the black-and-white chemistry. Meanwhile modern one-piece instant processes from Polaroid and Fuji have addressed the problem of making the image visible from the other side of the paper, removing the need for a peel-apart negative step.
Given that the mechanism and chemistry are seemingly so simple, one might ask why we can no longer buy two-piece Polaroid pack or roll film except for limited quantities of hand-made packs from One Instant. The answer lies in the complexity of the composition, for while it’s easy to understand how it works, it remains difficult to replicate the results Polaroid managed through a huge amount of research and development over many decades. Even the Impossible Project, current holders of the Polaroid brand, faced a significant effort to completely replicate the original Polaroid versions of their products when they brought the last remaining Polaroid factory to production back in 2010 using the original Polaroid machinery. So despite it retaining a fascination among photographers, it’s unlikely that we’ll see peel-apart film for Polaroid cameras return to volume production given the small size of the potential market.
Hacking A Sixty Year Old Camera
A rectangular 3d printed box about 90mm wide and 100 mm long.
Five minutes with a Vernier caliper and openSCAD, and this is probably the closest I’ll get to a pack film of my own.
So having understood how peel-apart pack film works and discovered what is available here in 2025, what remains for the camera hacker with a Land camera? Perhaps the simplest idea would be to buy one of those One Instant packs, and use it as intended. But we’re hackers, so of course you will want to print that 120 conversion kit I mentioned, or find an old pack film cartridge and stick a sheet of photographic paper or even a Fuji Instax sheet in it. You’ll have to retreat to the darkroom and develop the film or run the Instax sheet through an Instax camera to see your images, but it’s a way to enjoy some retro photographic fun.
Further than that, would it be possible to load Polaroid 600 or i-Type sheets into a pack film cartridge and somehow give them paper tabs to pull through those rollers and develop them? Possibly, but all your images would be back to front. Sadly, rear-exposing Instax Wide sheets wouldn’t work either because their developer pod lies along their long side. If you were to manage loading a modern instant film sheet into a cartridge, you’d then have to master the intricate paper folding arrangement required to ensure the paper tabs for each photograph followed each other in turn. I have to admit that I’ve become fascinated by this in considering my Polaroid camera. Finally, could you make your own film? I would of course say no, but incredibly there are people who have achieved results doing just that.
My Polaroid 104 remains an interesting photographic toy, one I’ll probably try a One Instant pack in, and otherwise continue with the 3D printed back and shoot the occasional 120 roll film. If you have one too, you might find my 3D printed AAA battery adapter useful. Meanwhile it’s the cheap model without the nice rangefinder so it’ll never be worth much, so I might as well just enjoy it for what it is. And now I know a little bit more about his invention, admire Edwin Land for making it happen.
Any of you out there hacking on Polaroids?
24 thoughts on “Falling Down The Land Camera Rabbit Hole
  1. I went through so many packs of film for this camera in college.
    Fake IDs were a nice side hustle.
    I ended up selling the ‘business’ (Board w. 4 names and camera) to an ex MP.
    Who got busted, fool had operated from a dorm room and kept all the bad shots.
    Many of his clients were also busted, those fools confessed because maybe there face was in the pile.
    I denied everything, but it meant the cops knew my name…Graduated and moved.
    First rule for life…Never admit to nothing.
    Picture trimability is a big advantage of this camera vs SX-70 style.
    Of course modern fake IDs are just printed.
    1. Polaroid was heavily in the business of creating systems to produce authentic IDs (not to be confused with the new Real IDs)
  2. We had a monochrome Polaroid setup at college with a custom hood which fitted over the oscilloscope screen – for instant screenshots…
    No fancy storage scopes for us!
    1. This used to be the way to get high-resolution images out of an electron microscope. At high resolution the image can only be scanned very slowly, so the output would be switched to a CRT which displayed it to a Polaroid camera. There was a project here a few years ago where a hacker who had bought his own electron microscope (!!) converted it to read the slow-scan signals directly from the electronics onto his computer.
      1. Ha I saw that one. Talk about bragging rights, found a whole electron microscope setup with an old crt monitor at auction and got it running again. I’ve never done that!
  3. One problem with the 220 conversion back is that it wastes film quality. The lens in a Land Camera is designed for the negative and print to be the same size, so it doesn’t need to be as sharp or finely color-corrected as the lens for a 220 camera whose images will be printed much larger than the negative. So yes you’ll get a print, but it won’t be as sharp as you normally expect for 220 film.
    1. Except those lenses could be absolutely sharp enough to make larger prints. People would strip the backing and create large negatives from various packfilms. MAYBE the cheaper cameras with the plastic lenses but even some of those are my favorite cameras ever made with lens as sharp as anything (looking at you, Polaroid ProPack)
      1. I used the Polaroid positive negative film, which was based on Kodak Panatomic X and used it to make 50 x 60“ prints. You could put your nose right up to it and not see any grain but the detail was amazing. I was using a Polaroid back on a speed graphic, but Polaroid sold professional grade cameras that could easily duplicate that.
        1. I’ve got a 545 back for my Speed Graphic, but haven’t seen film in 20 years. It was fun, way back then, using wide f stops to drop out the background on an up-close shot. Arrange it all on the ground glass before wasting film for a shot. There even was sepia film,, Type 56, good for working on shots of 19th-century re-enactors.
  4. Huh, Dad had one of those. Instructions said put the photo between two aluminium plates stored in the back and which doubled as the manual. For some reason dad did so then put photo and plates under his armpit but that was for cold days (which made the photo develop more slowly) but dad did so even when the sun was scorching. We made faces as we were handed the developed photos as if they smelled bad. Dad never failed to get angry = )
    1. Clever dad! Taking advantage of a convenient thermally regulated environment to remove temperature variations from the process under conditions where the temperature being too high, or too low, may affect the chemistry it needs to work.
    2. What about conductive (say gold/silver) plates polished and buffed to nanometric superflat mirror finish vs aluminum?
  5. I still own one of these, a range finder model. I cannot remember the product number, but my favorite film back produced both a positive print and a usable negative when you peeled it apart. Only a few of those negatives got enlarged, but they were glorious.
  6. I remember being a kid in the 60’s and I had a Polaroid Swinger camera. You squeezed the button a little and if you saw the word ‘Yes’ pop up in the view finder, you had enough light to take a good shot. Lol.
  7. Can we derive the bitting of your car key from that first Photo? ;-)
    I’m not entirely sure but that looks like a key beard (bit?!) sticking out below the bellows (to prop up the camera for the shot?).
  8. I have only 2x Fuji film packs left for my Polaroid Land 250 pack camera, breaks my heart!
    I mostly shoot film these days just to keep my sanity in a digital world! Analog Forever 📷
  9. When I was in college in the 70s (Illinois Wesleyan University) I studied astronomy/astrophysics. I had keys for the observatory (16 inch scope) and photo lab. I shot a lot of film on weekends and helped fix government donated used equipment. One day I found in a box a strange looking Polaroid camera. It had no lens, had a shutter cable release and a black plastic tube. I was told it never worked. I took it apart and cleaned and lightly lubed the cable release and contacted Polaroid for more info. They sent me an instruction book. The camera was a Polaroid Astrophotography camera that used black and white film packs. My instructor didn’t believe the camera was worth using but bought me 2 film packs. The following Saturday night was a good steady clear night so I was set for a solo observing session. To do a shoot with the camera first the object was centered in the eyepiece of the scope, then the black “Focusing Tube” (Polaroid term) was placed over that with the scope eyepiece inside it. Then you looked through the Focusing Tube and adjusted the sharpness of the image. When ready the Polaroid camera body was sat on the tube which was seated in the hole where a regular lens would have been. Press and hold the shutter cable for the appropriate time for the shot, pull the film out and wait the 60 seconds, peel apart and there were decent astrophotos. Grainy but decent. My best shots were of lunar crater Grimaldi (which moves in and out of the lunar terminator shadow) and Saturn and the rings. The graininess of film prevented very good definitions of the ring bands but instead of hours in the photo lab, I had shots of Saturn in 60 seconds. I found out the film pacts had previously been discontinued and were out of stock so I only got to use the camera twice.
  10. Hacked up 2 land cameras (low end plastic body and a 180 lens) with a broken Instax 210 to only utilize the rollers/ejection system. Had to do some 3d printing to get the lens and viewfinder to line up with the film then slapped it all together with some duct tape. Works great!
Leave a Reply to PerniciousSnitCancel reply
