Quieting That Radio
If you are casually listening to the radio, you probably tune into a local station and with modern receivers and FM modulation, the sound quality is good. But if you are trying to listen to distant or low-powered station, there’s a lot of competition. Our modern world is awash in a soup of electronic interference. [Electronics Unmessed] tells — and shows — us how much noise can show up on a SDR setup and what simple things you can do to improve it, sometimes tremendously.
According to the video, the main culprit in these cases is the RF ground path. If you have a single antenna wire, there still has to be a ground path somewhere and that may be through the power line or through, for example, a USB cable, the host computer, and its power supply. Unsurprisingly, the computer is full of RF noise which then gets into your receiver.
Adding a counterpoise makes a marked difference. A low inductance ground connection can also help. The counterpoise, of course, won’t be perfect, so to further turn down the noise, ferrite cores go around wires to block them from being ground paths for RF.
The common cores you see are encased in plastic and allow you to snap them on. However, using a bare core and winding through it multiple times can provide better results. Again, thanks to the SDR’s display, you can see the difference this makes in his setup.
None of this is new information, of course. But the explanation is clear, and being able to see the results in a spectrum display is quite enlightening. Those cores essentially turn your wire into a choke. People think that grounding is simple, but it is anything but.
22 thoughts on “Quieting That Radio
  1. The only radio I like listening to is shortwave. There is a joy in listening to random radio broadcasts from around the world. Some from Asia, some from Eastern Europe, some from Africa. I do not understand a word but its still fun.
    One of these days I plan on putting a directional antenna on a my rtl-sdr and seeing what I can pick up. I absolutely love the late nights under the stars, on my roof with a laptop and SDR, trying to pick up random broadcasts. Just love it!
    1. I too love tuning around the bands and listening to random broadcasts from all over the world, I discovered Google translate on a mobile device or tablet does a reasonably OK job of live transcribing and translating strong broadcasts too.
    2. I remember when I won a contest from Radio Taipei International(now Radio Taiwan International) and they send me a full year of a magazine called Sinorama, Half in English and half chinese, the old fashion way ,just a small pocket radio you know. Voice of America, Radio China, radio Habana Cuba, radio Mexico, and then we have the think signaling the time, ping,ping…ping..3 o”clock universal time. I even miss the #amn cristian preachers :) and the church of mary Baker Eddy. Like Mary Hopkin said: those where the times.
  2. The first link leads to a startrek fan video?
    But on topic – this is a really nice article, so often especially with RF very simple measures can be used to improve things and it’s good to keep getting reminders and other tips and tricks.
  3. Al: This may be a generational thing. Younger listeners who are accustomed to consumer electronics (no noise on the smart phone!) often object to the noise coming from a simple direct conversion (HDR!) receiver. But those of us who grew up with analog shortwave receivers knew that a certain amount of noise was a necessary part of the game, and in fact was one way to test the sensitivity of the receiver. When you connected the antenna, did the noise level go up? If so, you were hearing the “band noise.” Some of it was from thunderstorms in Brazil, some from the weed-whaker down the road, some from remnants of the big bang. Sure, you could decrease the gain of the receiver to the point that this band noise is no longer audible. You will be able to listen to Brother Stair with no noise. But that weak station coming in from far-off Ulan Bator might no longer be audible. FM was another way to eliminate the noise. Personally, on an HDR analog homebrew shortwave receiver, I like the noise. It lets me know that the receiver is working.
    Join the discussion – SolderSmoke Discord Server:
    https://discord.gg/Fu6B7yGxx2
    Documentation on Hackaday:
    https://hackaday.io/project/190327-high-schoolers-build-a-radio-receiver
    SolderSmoke YouTube channel:
    https://www.youtube.com/@soldersmoke
  4. Did you not know that End-fed half wave antennas need no counterpoise ????
    The don’t obey Ketchup’s Law
    (if needed….. /s or JOKE)
    1. The counterpoise still exists even if you use an EFHW . If you omit a physical counterpoise line(s) , it still exists as your outer surface of your coax feed line. This gets back to your receiver. It is known as the i3 current. Now no harm done if this RF current doesn’t bite you when you transmit. But, consider how much local noise you are now picking up from indoor appliances, wall warts,etc (see Bill’s comments, above).
      Does this really happen? Several of our local hams constructed EFHW ‘s with 49:1 XFORMERs . Counterpoise connected, noise dropped audibly.
    2. It’s hard to tell from your post and hopefully it’s a joke, but if you actually think an end fed antenna doesn’t need a counterpoise you are seriously mistaken. If you don’t provide a counterpoise the feedline will become one and cause all sorts of problems, particularly unwanted noise pickup. An end fed antenna without a good additional counterpoise is one of the very worst configurations possible … for either transmit or receive. And even with a good counterpoise a feedline choke is needed in addition because of imbalance.
      1. ” An end fed antenna without a good additional counterpoise is one of the very worst configurations possible”
        Tell the guy at “Myantennas.com” that. Maybe he will listen to you.
        (and the folks who buy them)
        I have given up. :(
  5. “Modern receiver” has meant digital radio (DAB+), at least in my part of the world, for the past two decades. FM is slowly dying, AM has completely died many years ago.
    I also grew up with shortwave in the 1970s, and I still remember how all the AM bands were literally bustling with life from all over the world. The vastly varying quality, from “OK” to “barely intelligible,” was part of the experience. Those were truly exciting times; shortwave radio and amateur radio was the only usable and affordable international medium. Practically nothing of that remains today – if the AM bands once resembled a jungle teeming with life, today (at least here in Europe) they are nothing more than a empty desert with a small source of water every some 100 km.
    But the idea that anyone could exchange data, voice, and even video with virtually any location in the world at any time using a global data network was pure science fiction in the 1970s ;-)
    1. The AM band is still packed in the US. At night, every single frequency is in use. Many frequencies have multiple stations coming in at the same time. Near the big cities, there are lots of FM stations too.
      1. “The AM band is still packed in the US”
        Because we are stuck in the “dark ages”
        It’s called regulatory capture….Just a fact of life in the US. ie, HD radio vs DAB or DRM.
        If someone is not making money then it’s a “bad” system.
        And don’t even talk about AMBE+2
  6. I was an Operations Specialist in the Coast Guard and we were required to monitor several bands for international hailing and distress. We’d be off the coast of Baja or Costa Rica and could hear South East Asia and India start their evening broadcasts.
    We could do all the circuit isolation in the world but Bollywood would still come through distorted and unintelligible at 0300 when you were least expecting it. Other nights it would just be the background noise of the universe and I swear I could hear voices in the static sometimes.
Leave a Reply to Puddle Pirate ExtraordinaireCancel reply
