Old Projects? Memorialize Them Into Functional Art
What does one do with old circuit boards and projects? Throwing them out doesn’t feel right, but storage space is at a premium for most of us. [Gregory Charvat] suggests doing what he did: combining them all into a wall-mountable panel in order to memorialize them, creating a functional digital clock in the process. As a side benefit, it frees up storage space!
Everything contributes. If it had lights, they light up. If it had a motor, it moves.
Memorializing and honoring his old hardware is a journey that involved more than just gluing components to a panel and hanging it on the wall. [Gregory] went through his old projects one by one, doing repairs where necessary and modifying as required to ensure that each unit could power up, and did something once it did. Composition-wise, earlier projects (some from childhood) are mounted near the bottom. The higher up on the panel, the more recent the project.
As mentioned, the whole panel is more than just a collage of vintage hardware — it functions as a digital clock, complete with seven-segment LED displays and a sheet metal panel festooned with salvaged controls. Behind it all, an Arduino MEGA takes care of running the show.
Creating it was clearly a nostalgic journey for [Gregory], resulting in a piece that celebrates and showcases his hardware work into something functional that seems to have a life of its own. You can get a closer look in the video embedded below the page break.
This really seems like a rewarding way to memorialize one’s old projects, and maybe even help let go of unfinished ones.
And of course, we’re also a fan of the way it frees up space. After all, many of us do not thrive in clutter and our own [Gerrit Coetzee] has some guidance and advice on controlling it.
3 thoughts on “Old Projects? Memorialize Them Into Functional Art
  1. Sometimes on our local ebay there are video mixers with huge handles and lots of blinken lights for cents a kg (aka less than 10 €/kg incl. shipping). Outdated stuff from commercial TV studios, remot camera controls and all that glory.
    Stuff made by “Grass Valley” like this “Grass Valley Group Mischpult – Gebraucht, Ungetestet, Für Teile/Reparatur” (396939698019)
    I’m very much tempted to buy one , hack it and use it as an home automation controll panel. But I fear inside is lots of ancient custom stuff not willing to talk to modern stuff.
    1. Not really. At least for the Tally’s, you’ll often find for example a 68HCxx controller board, but the displays and switches are often all hooked on an I2C bus with multiplexers, which makes them damn easy to interfaces. And once you remove the controller board, you have plenty of space for your automation hardware. And even sometimes a separate, very robust power supply can be reused. Go for it.
Leave a Reply to MamxCancel reply
