Putting A Teensy To Task As A Transputer Link
One downside of working with the old Inmos Transputer devices is the rarity and cost of the original silicon. Obviously, you can’t sidestep the acquisition of the processor—unless you emulate—but what about replacing the IMS C011/C012 link chip? You need this (expensive) part to interface the transputer to the programming host, but as [Erturk Kocalar] discovered, it’s perfectly possible to coax a Teensy to do that job for you just as well.
The unusual two-bit start sequence differentiates a data packet from an ACK. It’s simple to emulate if you use the LSB of a 9-bit word as a dummy start bit!
Transputers work by utilizing an array of bit serial interfaces to connect a network of devices, allowing for cooperative computation on tasks too large to fit on a single device. This protocol is, at its link level, a simple asynchronous bit serial affair, with 11-bit data messages, and a raw two-bit frame for the acknowledge. The C011 device at its heart is just a specialized UART—it takes 8-bit parallel data from the host, dealing with handshaking, and pushes it out to the first transputer in the chain at 5, 10 or 20 Mbps, but inverted and with two start bits and a single stop bit. In parallel, it performs the same task in the reverse direction.
[Erturk] realized that the Teensy UART has an inverted mode and, crucially, a 9-bit data mode. This allows the second start bit to be generated as bit 0 of the word, with the remaining eight bits forming the payload. Simple stuff. Additionally, the Teensy UART is capable of the maximum transputer bitrate of 20 Mbps, without breaking a sweat.
There is a slight issue, however, in that there is no way to send or receive the two-cycle acknowledgement frame directly. Since the protocol stop bit is a low, it is possible to implement this by simply sending a dummy data word with all 9 data bits low (since the acknowledge is a ‘1’, ‘0’ pattern). In one specific corner case, that of a direct memory PEEK operation, the command is clocked into the transputer, which sends back a two-cycle ACK—almost immediately followed by the 11-cycle data packet with the result. But, since the Teensy UART is still busy ‘fake decoding’ the full 11-bit dummy ACK message, it will miss the data packet entirely.
It turns out that the easiest way to get around this is to speed up the link and run at the maximum 20 Mbps rate. That way, the Teensy will have fully received the overly-long ACK long before the transputer has completed the PEEK command and started to send over the result. Why you would voluntarily run the link slower escapes us, once you’d got the design dialled in and reliability was a given, anyway.
We like transputers, a cool technology that died too soon. Here’s a quick guide to these innovative devices. Some people are really into transputer hardware, like this person. Finally, with the genuine hardware finicky to work with, expensive and hard to find, you could play along with your trusty web browser, and tick it off your nerdy bucket list.
8 thoughts on “Putting A Teensy To Task As A Transputer Link
  1. The Teensy4.1 is really good at this kind of stuff. Its peripherals are so full of options you can often configure them just right for more exotic uses. Like i needed something to decode a 16-bit address buss from a 6502 and do stuff. Turns out that with a tweak to the portmux settings it was possible to get 16 pins of a port exposed on a t4.1 and that i could hook the entire port to a single interrupt vector.
    Only had to get used to the different clock between processor and peripheral. Easy to end up with the processor waiting for the peripherals. Stuff like reading/writing a port in one single go has a big impact.
    1. Most people don’t know but 6502 was one of the most popular CPUs ever created. Pretty much everyone played Super Mario Bros – it’s compiled to run on Nintendo 6502 implemented in NES console. In some countries (for example China and Vietnam) 6502 was also used as general-purpose programmable logical controler (PLC) in industrial factories.
  2. Note that transputers can be bought at DigiKey. They aren’t called transputers, of course, but are called the XMOS xCORE devices.
    Occam has been reincarnated as xC.
    The xCORE+xC ecosystem has one currently unique advantage: the IDE tells you how long a piece of code will take to execute. That enables the 4000MIPS 32 core processors to do things that otherwise require an FPGA.
    Unsurprisingly one of the INMOS architects, Prof David May, is a key player in XMOS.
    1. Wish no more. Realise that the modern descendents are commercially successful…
      INMOS Transputer => XMOS xCORE, 32 core, 4000 MIPS
      Occam => xC, but xC is better.
      xTimeComposer IDE, which states the exact number of cycles between here and there in the code => hard realtime programming.
      They are halfway to being FPGAs :)
      So find a use for them doing something embedded. Perhaps come cores doing USB/ethernet comms, others doing front panel i/o, others doing the core processing with predictable timing.
Leave a Reply to Charles SpringerCancel reply
