TinyCore Board Teaches Core Microcontroller Concepts
Looking for an educational microcontroller board to get you or a loved one into electronics? Consider the tinyCore – a small and nifty octagon-shaped ESP32 board by [MR. INDUSTRIES], simplified for learning yet featureful enough to offer plenty of growth, and fully open.
The tinyCore board’s octagonal shape makes it more flexible for building wearables than the vaguely rectangular boards we’re used to, and it’s got a good few onboard gadgets. Apart from already expected WiFi, BLE, and GPIOs, you get battery management, a 6DoF IMU (LSM6DSOX) in the center of the board, a micro SD card slot for all your data needs, and two QWIIC connectors. As such, you could easily turn it into, say, a smartwatch, a motion-sensitive tracker, or a controller for a small robot – there’s even a few sample projects for you to try.
You can buy one, or assemble a few yourself thanks to the open-source-ness – and, to us, the biggest factor is the [MR.INDUSTRIES] community, with documentation, examples, and people learning with this board and sharing what they make. Want a device with a big display that similarly wields a library of examples and a community? Perhaps check out the Cheap Yellow Display hacks!
We thank [Keith Olson] for sharing this with us!
32 thoughts on “TinyCore Board Teaches Core Microcontroller Concepts
    1. I blame the Romans, with their tenth month that they call October, and eleventh month that they call November. What should be automatic becomes, “is that right, or did I go the wrong way?” Let’s just settle on septagon.
      1. The romans got it wright, because the new year started on March the 1st. Later, Julius Caesar move it to the 1st of January, but the now last 4 months kept their names.
  1. Cool project, but ultimately nothing new. The space of education projects has become…stale I feel. This is not directed towards this creator, but in general I feel there are barely any new or interesting cognitive models, if that makes any sense? Not many truly new teaching tools or ideas etc.
    Fun fact, TinyCore is also the name of a very small (23MB) Linux distro. Its also very cool.
    1. It seems a little sad, that the biggest “innovations” these days seem to be focused on PCB geometry. But in the maker space, we still have many options:
      1) Arduino, which can mean AVR, STM32, or any other MCU that has limited memory and speed.
      2) ESP32 (which these days can be either Xtensa or RISC-V based)
      3) Tiny Linux machines, either Cortex-A or RISC-V based.
      In each of these, we have options:
      * All of them support I2C, SPI (including DSPI, QSPI, and what I like to call 8SPI), UARTs, SD cards, and bare GPIO pins.
      * All support SPI displays (whether LCD or OLED), and all of the tiny Linux machines support either MIPI DSI RGB TTL (DPI) or HDMI displays.
      * Groups 1 and 2 above can be programmed over either a UART or slightly modified UART interface, while the Linux machines generally get a Linux distro filesystem image that can be written onto an SD card, and you just go from there.
      It doesn’t seem like progress when you watch it over time, but when you look at what we have available today, we are in a time like no other, at least not since the 1980s.
      So yeah, cool project, but why would you buy one when you can customize a PCB for each project, leaving a few uncommitted I/O pins for expansion?
      I’m sure I’ve left out something important, but someone will surely point it out.
      1. Well, you forgot the “It could be done with a 555”.
        But there’s a point to it. People get so excited about doing things with modern tools that they forget new people are not well served by skipping the fundamentals. When people who have already skipped some of the fundamentals teach new people with even more abstract tools that skip even the things they’ve had to learn, we’re in big trouble.
        For example, in math education, people at the college level now have troubles solving a quadratic equation because they were given the use of symbolic solver calculators in high school. They’re ill equipped to handle college level math because they’re actually still struggling with basic algebra. That is simply masked by the tools they have at their disposal – up to the point where they would have to display understanding of the concepts and the ability to manipulate math beyond what their graphing calculators can manage. That’s where they hit a wall, and either drop out or struggle until they get a barely passing grade.
        Imagine a student showing up to do their master’s thesis involving some electronics and not knowing how to apply Kirchhoff’s circuit laws. Not knowing how to do basic circuit analysis without some simulator software. Not having a good grasp of what Ohm’s law means, or being tasked to build a signal processing system with only the faintest pedestrian level understanding of what an RC filter does let alone being able to describe it mathematically. That is actually the case these days. They may have heard of it, but they don’t have any idea on how to use it. What electrical theory gets applied is just following examples and replicating known solutions found on Google, which is cargo cult or magical engineering.
        If the point was pressed, 95% of the graduates would fail to reason and explain their theory from first principles. I’m not kidding you – they really don’t understand what they’re doing.
        1. Always been true.
          You now have a higher % that can do algebra (they’ve seen before) with a calculator.
          You have about the same % that actually understand enough to go on with math.
          Calc users might take ‘calc for business majors’ and memorize a C, but that will be it.
          Most people that ‘don’t get’ algebra lost the thread years or decade earlier.
          They can’t even add/subtract fractions using the easy common denominator method, don’t really understand the questions, it’s all wa-wa-wa-wa-wa.
          Unused brain circuit trimming in adolescence has left them permanently innumerate.
          ‘Better luck next reincarnation.’
          Knowing how to do circuits (I’m EE) means that once it gets to 3 loops, you use software tools.
          Having seen and remembering a ‘bunch of circuits’ isn’t the same as knowing how to figure them out, it’s better.
          Sure it’s sort of ‘Lego’.
          What are ‘first principles’?
          They sound kind of tedious and slow.
          I’m hoping to avoid the K domain for the rest of my years, that math sucks worse than fields.
          You can let a neural net tune it better.
          But I passed the course, a long time ago.
          Smart kids have always learned despite most teachers, HS and earlier.
          The fact that American public schools are now openly hostile to kids smarter then the teachers doesn’t change much, they just stopped hiding it.
          ‘Smarter than teachers’ is an easy standard, you know who goes to the education schools…
          Hint: they can’t add fractions, can’t ‘sound out’ words, only understand memorization.
          They are not good memorizers though, good memorizers become doctors.
          1. “innumerate” is a funny word. My brain goes to something like “indefinite”, so to my first reaction, “innumerate people” means an indefinite number of them, and therefore “permanently innumerate” is a little scary.
    2. The space of education projects has become…stale I feel.
      “Educational” is on the same list of project excuses as “Helps people in the third world”, “Assistive technology for the disabled”, etc. that get used to justify why the project exists. As long as it’s a good cause, slight shortcomings like not really addressing the point can be forgiven. A+ for effort.
      The thing about educational systems like this is that they teach a paradigm. If you teach engineering using LEGO as a shortcut and a platform to bypass the “boring fundamentals”, you teach LEGO engineering. The ideas that go across form around the blocks and what can be done with those, while other possibilities and opportunities tend to vanish because you’re given this hammer and therefore everything looks like a nail. You see a problem and the solution comes intuitively in the form of a LEGO construction, therefore the temptation is to go out and buy LEGO blocks or some other construction set pieces that serve the same point. Aluminium extrusions and T-slot nuts perhaps, expensive and clunky as they might be. What you learn is a way of thinking and looking at things.
      Likewise, what became of systems like Arduino was not so much a tool for teaching embedded programming or electronics, but teaching people to use Arduinos and other modular development board systems with ready made libraries to solve these kinds of problems – instead of actually developing the electronics and programs themselves – which made for good sales of Arduino boards. The educational aspect was always secondary to the business of helping people become dependent of the stuff you’re selling. The people who made it may not have though of it in these terms to start with, but the point of teaching anyone anything was soon ignored as the money started coming in.
      1. The point of teaching the wrong things can be summed up in the old story of Jane Goodall teaching chimps not to shit inside the house. She would scold the baby chimp and toss them out the window, after which every time they took a dump inside the house, they would follow through by jumping out the window.
        People get really excited and fixated about the systems they develop, to the point that they forget that other people see them differently.
  2. Excellent competition to the XIAO’s MG24. Was looking at buying three pack just the other day, and they do have additional GPIOs at the bottom of the board.
    Bring moar competitors.
      1. Form factor mostly. Been looking for a good compact-sized (or micro-sized) board with plenty GPIOs for some while now. I need more I2Cs so I can hook up temperature/pressure sensor, etc.
        Latest cheap/budget find that (kinda-sorta) fit my last project form factor was Attiny88 board, not tremendously good for much more beyond blinkie lights, but with unsoldered LDO it can function as uan ltralow standby command-signal generator for something else. I’d rather have the ESP32’s low-power CPU instead, but for now Attiny88 is being used for simple things (reacting to buttons and sending signals eslewhere).
        Also, for my meager/amateur needs even MG24 is a powerhouse, I don’t really use BLE or WiFI for much, and in all fairness, I could do away with some kind of low-power near-field inductive-coupled I2C thingiemabob that’s wake-up on demand. That’s why ESP32S3 I have in my other project (XIAO round display watch) is the main development platform. Unfortunately, that XIAO doesn’t have bottom board extra GPIOs that MG24 has (its only extras are taken by flash card port), so that project ended up as a standalone clock projecting clock on a ceiling. (well, there is moar, it also calculates civil sunrise/sunset and the length of the day, also moon phase, while at it, but I couldn’t find a way to hook up a temperature sensor … yet).
        Regardless, I am always eager to find another compact battery-powered board that can do moar. I like this solution, contact pads on something other than a square board.
  3. Tell me why hobbyists are so averse to soldering jumper wires. The “Stemma” or QWIIC connector is the laziest invention ever. To avoid connecting FOUR WIRES, people will pay multiple times the cost of a peripheral device for one that comes on a tiny PCB and has a Stemma connector. It’s crazy, when it takes maybe 30 seconds to warm up a soldering iron. and another 30 to cut and strip four pieces of 24-gauge, preferably in the conventional colors.
    1. Completely, unequivocally agree. In the same vein, we should also probably get rid of 220V AC plugs, there’s too many different standards, they’re all way too bulky, and honestly, harming people by de-skilling them, too. We are definitely failing people on that front – nowadays, nobody knows how to strip 1.5mm wire and put it into terminal blocks anymore, much less operate an indicator screwdriver, and people don’t even understand the significance of the earth connection! It also shows a real lack of commitment to whatever device they’re powering up, in a way, definitely reminiscent of the modern dating culture. Maybe, just maybe, if we eliminated concepts like hotplug, pre-defined pinouts and voltages, and open connectivity standards, hobbyists would become much more skilled, constantly watching out for mistakes instead of putting all this effort into connector/pinout standardization and prevention of common problems at the core!
      1. golf clap
        Though the connectors, modules, and cables are rather overpriced and pretty much unjustified unless you intend to take your project apart and re-use the pieces many times over. It is basically ripping off incompetent people.
      2. You’re the most correct when you think you’re being snaky.
        Think of bare 220V wiring as ‘evolution in action’.
        Is ‘powering up’ a new euphemism for ‘hooking up’?
    2. I second that. Pretty much all of the boards I have come un-soldered, and if I need the headers I can always solder these on myself. So far only two projects needed that, neither one was mine, helping somewhere else who demanded the headers were on.
      Other than that, I am old school, i can solder-unsolder anything on as-needed basis, and seem to work fine for my projects for the last … erm … lemme see … must be 40+ years. Probably more, I started tinkering with wires when I was ~10.
      I also do not like being forced into one or two standards – especially, if they suddenly become the industry standards AND get locked into by one or two entity/entities that jack up the price for the remaining stock. Never liked parallel ports for that matter, and there were few projects in the 1990s where I literally cut the wires from some kind of proprietary plug and just soldered them directly to the target PCB board. (i honestly don’t remember if I later returned and added a different/cheaper/non-proprietary plug so that the device can be disconnected – quite likely I did).
    3. To avoid connecting FOUR WIRES
      The main point of these connectors is the cable management and clean installation instead of solder snots and burned rosin all over.
      Most beginners cannot make a good solder joint, especially with unleaded solder that doesn’t wet or melt easily, and they don’t know the tricks and techniques, so the soldered connections become unreliable and there’s a high chance of burning the pads off the boards and damaging other components while trying.
      It’s easy to forget how difficult it was after having soldered literally thousands of components for a job. I get reminded because every year there’s new students who have never held a soldering iron in their hands, and they’re absolutely terrible at it.
      1. So then, Stemma is the AI of breadboarding. If the beginners don’t learn by starting with bad solder joints, how will they ever get good?
  4. Unfortunate name. TinyCore was there years and years before: http://www.tinycorelinux.net/
    It has a unique philosophy making it perfect for RAM-only service, still keeping the possibility of saving data when needed. It is damn fast and runs smoothly on very resource-constrained hardware. It´s also easy to tweak and extend. But it unfortunately did not gain much traction in the last 10 years.
Leave a Reply to make piece not warCancel reply
