PJON, Open Single-Wire Bus Protocol, Goes Verilog
Did OneWire of DS18B20 sensor fame ever fascinate you in its single-data-line simplicity? If so, then you’ll like PJON (Padded Jittering Operative Network) – a single-wire-compatible protocol for up to 255 devices. One disadvantage is that you need to check up on the bus pretty often, trading hardware complexity for software complexity. Now, this is no longer something for the gate wielders of us to worry about – [Giovanni] tells us that there’s a hardware implementation of PJDL (Padded Jittering Data Link), a PJON-based bus.
This implementation is written in Verilog, and allows you to offload a lot of your low-level PJDL tasks, essentially, giving you a PJDL peripheral for all your inter-processor communication needs. Oh, and as [Giovanni] says, this module has recently been taped out as part of the CROC chip project, an educational SoC project. What’s not to love?
PJON is a fun protocol, soon to be a decade old. We’ve previously covered [Giovanni] use PJON to establish a data link through a pair of LEDs, and it’s nice to see this nifty small-footprint protocol gain that much more of a foothold, now, in our hardware-level projects.
We thank [Giovanni Blu Mitolo] for sharing this with us!
13 thoughts on “PJON, Open Single-Wire Bus Protocol, Goes Verilog
  1. I haven’t seen any bidirectional one wire bus before. I’m pretty sure I’ve heard of them but never seen one in the wild. In fact the only one wire device that I’ve seen is DS18B20 style temperature sensors
    1. It claims speeds of about 2kB/s to 3kB/s, depending on desired range, which makes it about ten times faster than Commodore’s 1541 IEC bus. Not that I’m still bitter or anything…
      I see there’s a bitbanged implementation available. They also explicitly reference radio and light-based networking, so this could be useful for very cheap infrared networking, say. I’ll admit to not being thrilled by the fact that PSON™ trademark licensing rules.
    2. Umm, Dallas Onewire, as used by DS18B20, is a bidirectional bus.
      It was very popular and likely still is in common use, many bars and restaurants use(d?) Onewire ID tags to allow staff fast logon to POS and if you’ve ever owned a Dell laptop with a genuine charger you’ve used the TO92 or SOT version of those tags.
    3. The Dallas one-wire protocol is bidirectional.
      I wanted to add a real time clock to my device, but had only one GPIO left, which is not enough for i2c. Also I needed the RTC chip to be hand solderable. So I looked around found the Dallas DS2417, which comes in a tiny TSOC6 package.
      The DS2417 is not really what you can call an RTC, though. It’s basically a 32-bit binary counter that is incremented once every second. But it has a built-in oscillator, can be easily battery backed up, it has a periodic interrupt facility, and every chip has its own 64-bit unique identifier that you can read from the microcontroller. I use it as a unique identifier for my device, meaning that I don’t have to program any myself.
      If you program the RTC chip with a UNIX time_t code, you can use all of the UNIX time api functions to manage the time. But that does give you the ‘2038’ problem. If you take 1-1-1970 0:00 as base for your time code (like UNIX does), It will roll back over to 0 in 2038.
      So I just defined my base as 1-1-2001 0:00, which is the base for Apple Core Data time stamps. That did mean that I had to take some of the UNIX time library source code and tweak it to use 1-1-2001 0:00 as base. They were actually only the mtkime and gmtime functions, as the rest of all those time functions don’t give a sh*t at all what the base of the value they’re using is. :)
      One-wire can really save your day.
  2. “Did OneWire of DS18B20 sensor fame ever fascinate you in its single-data-line simplicity?”
    Actually not, a bidirectional data bus using a single line is as old as the telegraph. Decades ago. the fascinating thing about OneWire was providing power on a baseband data line and putting all that stuff on a single chip.
  3. There are one-wire to I2C adapter chips. I had to implement support for one to use a one-wire device. It has several interesting modes – including a mode where a power hungry operation can be requested like updating flash and the chip will provide that power for the duration.
    But nowadays it’s less fanciful since things like NFC implement a similar idea where there is bidirectional communication plus power. Everytime you tap your credit card it’s doing something similar – the terminal tells the card transaction details, the card encrypts it with it’s key and then the card sends the encrypted blob back to the terminal. All in a fraction of a second powered by the NFC coil.
  4. PJON has been engineered to have a variable footprint (4.2–8.2 kB program memory)
    Oof. That’s really heavy for embedded use. I would hardly call that “arduino compatible” unless you strictly mean “arduino on ARM”
  5. As long as bitrate is not too high, you can do something similar on a uC. If it can trigger an ISR on both rising and falling edges, you also don’t have to poll the data pin.
    You can also have a look at LIN bus. It also uses a single wire.
Leave a Reply to rolenthedeepCancel reply
