5 thoughts on “Simplifying The SmartKnob
  1. Very cool project from the perspective of the used technology, no doubt.
    But a better title could have been, “simplifying the most complicated knob ever”.
    I find it fascinating that the most functional piece of UI (a simple knob that does one, thing, does it very well, reliably and cheap and most of all repairable (and I mean a potentiometer with a plastic knob, that turns only 300deg. has an endstop and therefore absolute positions, you can control them even with your eyes closed and responds instantly). Why does the normal “knob” require a complete overhaul, with a motor, a display an microcontroller and ton’s of other things that can fail or be buggy or requires a development suite/compiler that is no longer supported within the next 5 years. Did I mention the power requirements for a ordinary pot-based-knob vs a smartknob? Or size?
    Why.. what happened to K.I.S.S.? What happened to beauty is in simplicity?
    Don’t get me started on touchscreen based “knobs and sliders” in cars (combined with bad UI and pop-up messages at the most inconvenient moments) but that’s a different topic.
    1. Well a normal pot can’t load a previously saved position, or record and play back an automation curve, for example. A motorised pot can of course, but you’re right back with the potential problems you mention again.
  2. Feeling or not the detents on a pot verses a switch with multiple positions, change between one and the other depending on context. Pot or switch buzzes and refuses to be put non-allowed position, like eleven. Pot can be a ten-turn pot easily, gently bumps at each full turn. Ten-turn pots! There are 2 on my Arp instead of 4 coarse and fine pots to tune the VCO’s.
    I like haptic feedback. I had a early mouse that let you feel lines in a menu as you moved the cursor down. Searching I find some are still out there but compatibility with page layout and such is a problem. This an accessibility feature that needs to be supported.
Leave a Reply to echodeltaCancel reply
