It’s a phrase we use a lot in our community, “Drink the Kool-Aid”, meaning becoming unreasonably infatuated with a dubious idea, technology, or company. It has its origins in 1960s psychedelia, but given that it’s popularly associated with the mass suicide of the followers of Jim Jones in Guyana, perhaps we should find something else. In the sense we use it though, it has been flowing liberally of late with respect to AI, and the hype surrounding it. This series has attempted to peer behind that hype, first by examining the motives behind all that metaphorical Kool-Aid drinking, and then by demonstrating a simple example where the technology does something useful that’s hard to do another way. In that last piece we touched upon perhaps the thing that Hackaday readers should find most interesting, we saw the LLM’s possibility as a universal API for useful functions.
It’s Not What An LLM Can Make, It’s What It Can Do
When we program, we use functions all the time. In most programming languages they are built into the language or they can be user-defined. They encapsulate a piece of code that does something, so it can be repeatedly called. Life without them on an 8-bit microcomputer was painful, with many GOTO statements required to make something similar happen. It’s no accident then that when looking at an LLM as a sentiment analysis tool in the previous article I used a function GetSentimentAnalysis(subject,text) to describe what I wanted to do. The LLM’s processing capacity was a good fit to my task in hand, so I used it as the engine behind my function, taking a piece of text and a subject, and returning an integer representing sentiment. The word “do” encapsulates the point of this article, that maybe the hype has got it wrong in being all about what an LLM can make. Instead it should be all about what it can do. The people thinking they’ve struck gold because they can churn out content slop or make it send emails are missing this.
So we have an LLM, even a small one on our own computer, and looking at it in that light it’s immediately apparent that it can become a function to do almost any processing task, if you wrap the right prompt and API call in a function definition. Of course that’s dangerous, because if I may I would like to coin a new phrase: function slop.
As an example I can call an LLM to do simple numerical addition and it will perform the task, but doing so would be utterly pointless given the existence of the + operator. If you are going to use an LLM to perform a processing function it’s important that it be a function where doing so makes sense, otherwise your function is just function slop. A quick web search tells me that function slop is not yet a thing, so I would like to take this moment to apologise for what I may have unleashed upon the world.
Function slop aside though, using the LLM to do a processing task where it makes sense, shouldn’t be ignored as a useful tool. These things are very good at summarising and categorising information in the way a human might do it, a task that’s often hard in traditional programming, so if the job in hand fits those capabilities then it makes sense to use them.
This has been a three-part series, and unlike Star Wars or The Hitchhikers Guide To The Galaxy, it’s probably going to stay that way. I hope that in our explanation we’ve successfully looked beyond the hype and found something useful in all this. It’s odd though, as the one writing it you might think I would be bubbling over with new ideas, but aside from the previous article’s sentiment analysis I still find myself with not much I find the need to use an LLM for. Which is maybe the point, it’s one thing to know a bit about them, but just because they’re there doesn’t mean you have to use them.
“Please don’t hate me for this” I don’t hate you but it did make me feel sick inside. Not nice, but it does prove a point.
I see the application for sentiment analysis. I question why other, significantly smaller models are unfit for this? It’s one of those things where LLMs give a string output, the sentiment analysis models from the era prior, gave a matrix where the columns corresponded to sentimentality. The outputs had some grounding in theory too, sure it’s ML and that’s wishy washy but LLMs hallucinate and do the wrong things and are wishy washy too.
If I were doing sentiment analysis I would possibly use a truncated LLM retrained on an embedding layer, or go with the older technology to save tens of thousands of dollars in deployment to still get good enough results.
Sentiment analysis of yesteryear also ‘hallucinated’ and got the answer completely and utterly wrong.
The code snippet has a couple of errors, parameters is misspelled as “paramaters” one time, and the DoWithLLM function declaration doesn’t include the “parameter” variable that gets passed to it. Gotta do this computing/environmental atrocity properly :-P
I should add that the whole parameter variable/”paramaters_string” looks like it’s actually leftover unused cruft, and it looks like everything is done with the prompt variable now?
Oops I read it as DownWithLLM, thereby accidentally revealing a bit of biased sentiment towards LLMs! :D
It’s vibe coded, innit. So of course!
I have never heard the phrase “Drink the Kool aid” that wasn’t using it in a Jim Jones way.
When someone says you have drunk the Kool aid, they are implying you have joined the cult of [X] and are willing to ignore logic to maintain the fantasy, even if it is disastrous to yourself or others.
You aren’t just going along with it.
You are a fanatic who believes it enough to drink poison.
Indeed, same here. I was surprised to find it has a 1960s origin though.
Except that in the earlier usage, it wasn’t about blind dogmatic allegiance but still just more of a face-value narcotic consumption technique.
… …and Jim Jones used FlavorAid, not Kool-Aid.
“…and Jim Jones used FlavorAid, not Kool-Aid.”
You are suggesting, perhaps, that all the mass murders in Jonestown would not have happened, had Kool-Aid® been used instead?
…and, Ms. List: see ‘Jim Jones’; Wikipedia—
https://en.wikipedia.org/wiki/Jim_Jones
ha, aren’t we feeling cynical today? For one thing, in Tom Wolfe’s “The Electric Kool-Aid Acid Test” they actually used the brand name substance, which would at the time I imagine, horrified the marketers at the company nearly as much, but they never tried to sue Wolfe, which I find interesting. Perhaps they accepted that “there’s no such thing as bad publicity”. And, if we’re going to nitpick words, “narcotic” originally referred to opiates, but the Harrison Act included cocaine, and the term came to mean any illegal substance. Still, psychedelics are now being investigated on a “Fast Track” for medical usage, and referring to them still as “narcotics” seems old-fashioned, especially given the Greek root for “putting to sleep”.
Despite the later Jonestown connotations, “drinking the Kool-Aid” began with this 1968 book (worth a read): https://en.wikipedia.org/wiki/The_Electric_Kool-Aid_Acid_Test
I think the koolaid here is not AI use itself, but the “evangelism” of it. And there are 2 distinct threads of this 1) financial investments in AI companies and products, and 2) claims of AI capabilities. 2 is the worst since we have LLM builders making wild unsubstantiated claims like “sentience”. 1 is as old as bitcoins, this game runs on GPU cycles and Jensen actually convinced people that burned cycles are monetizable.
1 is as old as tulips… (https://en.wikipedia.org/wiki/Tulip_mania)
:D
Holy relic market lasted much longer and started much earlier.
Tulip bulbs are now rationally priced.
The fake of Turin is still venerated by fools and is ‘priceless’.
To say nothing of a certain black rock in Arabia, seriously say nothing…
Also I wouldn’t encourage people to use LLMs for summarizing information, this increasingly appears to be something LLMs are particularly bad at:
https://www.techspot.com/news/110002-ai-assistants-misrepresent-news-stories-almost-half-time.html
Personally the only thing I’ve been thinking of using an LLM for is an image search on my phone. The idea is that I can enter a prompt to “show filenames from my camera directory for any image that contains a dog” and have a free local LLM on the phone scan the files and produce that list (and perhaps store it for later reuse). Yes it’s already possible if I upload all my data to Google and become their product in return for the service, but that’s what I want to cut back on. LLMs seem to be most useful for recognition tasks where the need to work with facts and figures is kept to a minimum.
You want to use a language model to accomplish image-recognition????
Technically the part that does the image recognition would be called a VLM, but I would probably use a VLM+LLM combo commonly referred to as an “LLM”
https://www.nature.com/articles/s41598-025-04384-8
Look for immich. It’s a self-hosted ‘replacement’ for Google photos and has local LLM search.
LLMs are great for learning new things. Let’s say you know enough about a topic to ask a question, but not enough to know the correct words to use in that question. An LLM will help you learn the gaps in much less time than random internet searches.
Many such useful functions, e.g. Gemma 4 running locally, even on a machine without a big GPU card, can take an image of a receipt from a grocery store and return the SQL to build a fully relational database for it, as well as the SQL to populate it with the data in the receipt. i.e. it gets 95% of the work done for you in a single shot, sure you are obliged to do the final code approval, but how is that different from dealing with work supplied by some contract coder in the third world? It is also rather good at answering “What does this code do and how does it work?”
In some ways LLMs are better than contractors because you technically can intervene and review at shorter intervals. The downside is, you are doing considerably more work.
As far as the receipt workflow goes, I would handle that differently personally. For various reasons.
Your saying it’s as good as OCR and excel import wizard from 1995?
Impressive.
As impressive as ‘fully relational database’…for a list.
Your just typing words aren’t you?
I don’t believe you actually code.
I don’t believe you’ve ever used an LLM or Excel.
If universal only works for some things then it is no longer universal?
Sixty percent of the time, it works, every time…
It works for “small” universes… If you’re in one of those, yes, it’s universal.
Congratulations, you got the joke!
Probability programming where close matters as much as game of horseshoes and nukes.
