A man's hand is shown holding a color photograph of a vase of flowers against a black background.
True-Spectrum Photography With Structural Color
Although modern cameras can, with skill and good conditions, produce photographs nearly indistinguishable from the original scene, this fidelity relies on the limitations of human vision. According to the trichromatic theory, humans perceive light as a mixture of three colors, which can be recorded and represented by cameras, displays, and color printing; a spectrometer, however, can detect a clear distance between the three colors present in a photograph and the wide range of spectra in the original scene. By contrast, one of the earliest color photography methods, Lippmann plates, captured not just true color, but true spectra.
A Lippmann plate, as [Jon Hilty] details, starts with a layer of photographic gel containing extremely fine silver halide crystals over the back of a glass plate. This layer is placed on top of a mirror, traditionally a mercury bath, and put in the camera. When light passes through the emulsion and reflects off the mirror, it interferes with incoming light to create a standing wave. The portions of the emulsion at the wave’s antinodes absorb the most energy, converting local silver halide crystals into reflective silver. The spacing of the silver particles depends on the incoming light’s wavelength, and is fixed in place during the development process.
This creates a matrix of vertically-stacked diffraction gratings, each diffracting back the original wavelength when illuminated with white light. Unlike normal diffraction gratings, the wavelength of diffracted light doesn’t depend strongly on the viewing angle; since the interference structure here is vertically-arranged, it refracts a narrow range of wavelengths across all possible viewing angles. The viewing angles, however, are limited; unlike with dye-based photographs, you can only view the colors nearly straight-on. This, along with the necessity for long exposures, the chance of producing washed-out colors, and the impossibility of creating reprints, kept Lippmann plates from ever really catching on. The basic concept lives on in holograms, which encode spatial information in a similar kind of photographically-formed diffraction pattern.
For a more conventional method of color photography, we’ve also seen a recreation of the autochrome method. Alternatively, check out this homemade silver halide photography emulsion.
Thanks to [Stephen Walters] for the tip!
ReactOS Gets Unified Installer Image And A New Storage Stack
Although the ReactOS project is in no rush to dethrone Windows as the desktop operating system of choice, this doesn’t mean that some real changes aren’t happening. Most recently two big changes got merged, the first pertaining to the separate boot- and live CD images that are now merged into a single image, and the second being a new PnP-aware ATA storage stack for ATA and AHCI devices, with NT6+ compatibility.
Although there is still a separate live CD for now, this first change means that testing and installing ReactOS becomes easier, and that the old-school text-based installer may soon be on its way out as well.
Having the new ATA storage stack in place will translate into much better compatibility with real hardware, including the ability to use more hardware to install on and boot from compared to the old UniATA driver.
Combined, these two changes should bring the ReactOS installation and usage experience a lot closer to that of Windows, as well as many Linux distros. If you had issues with the OS on real hardware, this might be just the right time to give it another shake and provide detailed feedback to the developers if any remaining issues are encountered.
Thanks to [jeditobe] for the tip.
Hackaday Links Column Banner
Hackaday Links: May 3, 2026
Software that collects public data from the Internet and uses it to provide half-assed answers to your questions might seem like a modern craze, but today we bid farewell to a website that helped pioneer pretend conversations all the way back in 1997 — as of May 1st, Ask Jeeves is no more.
Well, technically they dropped the “Jeeves” part back in 2006. Since then it’s just been Ask.com, but as the name implies the idea was more or less the same. Rather than the relatively rigid parameters and keywords required by traditional search engines, you could ask Jeeves questions about the world using natural language. Early advertisements showed the virtual valet answering arbitrary questions like “How many calories in a banana?,” which of course today seems commonplace and utterly unimpressive, but was a pretty wild for the 1990s.
It might seem surprising that a site designed from day one to offer a human-like Q&A experience should fold right as such technology is becoming commonplace. But of course, that commonality is the problem. When Google can answer your questions just as well (or poorly…) as Jeeves or anyone else, what’s the benefit for the average Internet user to seek out another service? But it’s still somewhat ironic, which is probably why the farewell message on Ask.com ends with the line “Jeeves’ spirit endures.”
Continue reading “Hackaday Links: May 3, 2026” →
IPod Nano Gets Three Monitors
Triple monitor workstations are pretty common these days, particularly for those wishing to maximise screen space for greater productivity. [Will It Work?] has put together a sillier take on this concept, however, hooking the diminutive iPod Nano up to three monitors instead.
The 6th-generation iPod nano brought forth a new form factor – it’s the postage stamp-sized one that you could clip to your workout gear. It’s not typically what you’d call a productivity device, but there is a way to get more out of it. The trick is to grab a 30-pin Keyboard Dock, which allows access to the composite video signal from the iPod. It was originally designed for the iPad, but it works with the iPad nano too with a 30-pin spacer adapter – just don’t expect the keys to do anything. This setup also allows access to the 3.5mm four-pole jack, which handles audio input and output. With a bunch of additional cables and adapters, the iPod was able to be hooked up to three screens, a set of Apple Pro speakers, and three Sharp LCD monitors.
What can you do with this setup? Fundamentally, not a whole lot. You can’t use the keyboard with the iPod Nano, so you’re limited to interacting with the tiny touchscreen. There also aren’t exactly a lot of apps to run on the platform, either. You can basically listen to music, watch a slide show, or record voice memos, while looking at the iPod’s display spread identically across three TVs. Still, it’s a fun joke build, because at a glance it genuinely looks like you’ve set up a triple-monitor workstation running off a tiny iPod from over a decade ago.
If you want to blow the mind of your next podcast guest, consider recording your next episode on this rig. Alternatively, explore some of the other hacks we’ve seen for the platform. Video after the break.
Continue reading “IPod Nano Gets Three Monitors” →
Three-Axis Camera Slider From 3D Printer Parts
There’s a great reason 3D printers are made with things like extruded aluminum rails and other commodity, off-the-shelf parts. These things are designed not only for ease of construction and prototyping, but they’re also fairly strong especially given how modular they are. And they are excellent platforms for other projects as well. [CNCDan] has been using plenty of on-hand 3D printer parts to build a three-axis camera slider to film parts of his other projects, and this video documents his build and the latest upgrades to this platform.
After sorting out some issues with underpowered motors by improving their gear ratios, he found that many of the sizes and clearances on the existing platform changed enough that he needed to redo other parts of the carrier, including the mounting plate. He cut a new plate from steel and pressed bearings in, and then started putting together the other axes including a quick release mechanism for his camera. With a camera that weighs about 1.4 kg, getting the motors to move the camera smoothly was its own challenge. He re-worked all of his driver code over the course of a few weeks and eventually got his new system working much better than the original version.
With everything said and done, the camera slider can be controlled wirelessly with a GUI on another computer. Everything runs on an ESP32, and the slider can support other cameras besides his heavier one, including smartphones. He notes that this wasn’t the easiest way to build a project like this, but worked for him eventually because he had the parts and tools on hand to make it work. He’s also put the project files up on a GitHub page for anyone interested. Camera sliders like these have some niche uses as well; take a look at this high-speed camera slider for some examples.
Continue reading “Three-Axis Camera Slider From 3D Printer Parts” →
Photographing The ISS With A Thrift Store Lens Is Challenging
There are plenty of photos of the International Space Station out there on the Internet, but taking your own from ground level is a special challenge. [saveitforparts] recently decided to attempt this feat using a $15 thrift store lens.
What a setup! The lens is so big it has its own tripod mount.
The cool thing about the digital photography revolution is that there is a lot of old film gear that can be had for cheap. In this case, [saveitforparts] found a 400 mm Sigma XQ lens with a 2x teleconverter for just $14.99. Paired with an adapter, it sat nicely on a Sony NEX-3 digital camera, ready to try and capture the ISS as it passed overhead.
But as you might imagine, aiming at the space station is not a point-and-shoot job. N2YO.com was used to figure out the best time to try and capture it. [saveitforparts] was able to capture the ISS as a white dot as it passed over, but couldn’t quite get enough zoom to really see the Station in detail. He was able to repeat the feat with a Canon camcorder, but the image was still pretty blobby and didn’t show much. Later attempts involved capturing transits as the ISS passed by the Sun, though the orbiting complex mostly appeared as a small speck.
[saveitforparts] did technically capture the ISS, just not closely enough to see much beyond a dot. It’s not the first time we’ve seen this attempted, though! If you try and capture the ISS with something truly ridiculous, like a Game Boy Camera or Kodak Charmera, you are honor-bound to tell us on the tipsline. Continue reading “Photographing The ISS With A Thrift Store Lens Is Challenging” →
Squeezing Fluids With The Right Peristaltic Pump For The Task
Peristaltic pumps are a very simple and effect device for transferring fluids without said fluid ever coming into contact with any part of the pump mechanism. At their core they involve a mechanism squeezing fluids through compressible tubing, but there are various implementations of such a mechanism that all have their pros and cons. In a recent article by [T. K. Hareendran] over at EDN these types are discussed and when you’d want to pick one over the other.
Also known as a roller pump, these positive displacement pumps have been known since the 19th century, finding uses in industrial, medical, research, agriculture and many other fields. Each of these fields have different requirements with the use of a peristaltic pump as a dosing pump being a specific application whereby e.g. a stepper motor can be used to provide exact dosing.
For industrial settings the typical rollers that compress the tube are replaced with shoes that provide higher pressures and endurance, with overall a bewildering number of motor types and tubing materials available. Depending on what your project needs, you may opt for continuous flow, fine control over dosing, the ability to reverse the flow, etc.
Unless your project is particularly rugged, a roller-based mechanism should be fine, while silicone tubing is great for biocompatibility and PVC is a cheaper tube material option. If you intend to transfer certain kinds of chemicals that will react with each of these there are some more exotic tubing options available as well.
We have previously covered projects that use a peristaltic pump for rather interesting things, such as DIY pharmaceutics, in a home-grown flow battery, not to mention creating DIY peristaltic pumps from first principles.
