Nintendo has made many game consoles in its long history — one that famously overlaps that of the Ottoman Empire — but only one of them was ever Super. It’s that console, the Super Nintendo Entertainment System, that [Inkbox] has decided to delve deeply into as he crafts a game in assembly using all the hardware tricks he can.
Hardware tricks he’ll need, given he’s limited to the two 64 kB RAM banks and 3.58 MHz Ricoh 6502-based CPU. Even the 4 MB limit he sets for a historically-accurate homemade cartridge seems positively claustrophobic by modern standards. The game he’s after making is a top-down adventure game a la Zelda, and [Inkbox] gets right into the weeds explaining how the SNES works as he shows his work in this nearly hour long video. If you’re looking for a deep dive into the architecture, along with how it is meant to be used, you could certainly find worse sources. Everything from the different graphics modes to what registers handle sound are covered in this and the previous video in the series.
We can’t help but call out his dedication to open source — the SNES Sound Engine he has put up on GitHub looks like it could be a real asset to anyone else doing this kind of homebrew. The game itself is on itch.io and is pay-what-you-want.
[Inkbox] doesn’t just limit himself to the SNES’s 6502-esqe assembly — he’s done impressive work in x86 ASM, too.
Isn’t the SNES a 65816? It’s the NES that’s a 6502. Why limit yourself by staying in 8-bit mode? If you’re gonna do that, then why not target the old NES?
The 65816 is based on the 6502 (like the 80386 is based on the 80286). It’s basically a 6502 with 16-bit registers and a few more instructions and the ability to relocate the famous zero page from the 6502 (that is quite handy for optimizations). It’s a really crappy CPU if you compare it e.g. with the Motorola 68000, and there is no decent C compiler for it. So unless your SNES game is quite simple, assembly coding is mandatory.
BTW I have designed a SNES based cartridge and programmer that can hold up to 64 megabits (8 megabytes) using ExHiROM mode that is official, it’s in SNES official docs. Only two SNES games used ExHiROM: Tales of Phantasia and another japanese game whose title I cannot remember. But there you have it: https://gitlab.com/doragasu/xirom-cart
That “really crappy CPU” was also used in the Apple IIGS,
which basically was an multimedia Macintosh with color graphics.
Here, it ran at an even lower 2,8 MHz clock frequency.
https://en.wikipedia.org/wiki/Apple_IIGS#Hardware
For a C compiler, vbcc is available (relatively) recently. I haven’t used the ‘816 version, but I would say vbcc for 6502 is maybe 2.5 to 3 times faster than cc65’s output.
While yes, it does have a 16-bit CPU, the SNES’s 128kb of work memory is still very much “two 64 kB RAM banks” in a lot of scenarios due to the way the CPU handles memory access.
The NES only had 2k of work RAM, so even ignoring the advances in graphics and sound, there are a lot of reasons to target the SNES beyond its nominal 16-bit designation.
More broadly, this is one of the big contrasts between the SNES and other consoles of the era (as has been touched on by other recent hackaday articles) – its CPU is extremely slow and unimpressive compared to most of its competitors. But it easily made up for it by having fancier graphics and sound hardware to do a lot of the heavy lifting, and also by providing an easy transition for the developers who were already really good at coding for the 6502/NES.
He didn’t stay in 8-bit mode, the author of the article just got it wrong. In many of the code segments you can see 65816 instructions.
In late 1889, a former samurai could have faxed a flowery Nintendo hanafuda card to a cowboy, who could have then used a payphone to tell Annie Oakley about it. She’s performing at the Paris Exhibition. The conversation is overhead by a young Albert Einstein who tells Vincent Van Gough (who was perhaps sitting in the Moulin Rouge under the shadow of the new Eiffel Tower) about it. He then says ‘interesting’, goes home, and paints Sunflowers.
