[Vlad-Andre] used some of his free time to build an alti-variometer. He does some para-gliding near restricted air space and wanted a backup altitude warning that would help keep him below the mandated altitude. His solution uses the SparkFun Weather Board in conjunction with their BlueSMiRF dongle to measure altitude and transmit it via Bluetooth. From there, he wrote a program to grab the transmitted data with his cell phone and display the information. His application also has the ability to set altitude warnings and log changes over time.
Using this system he is able to get altitude data with 3.5 inch accuracy. Because the capture application is written in Java it should be easy enough to make this work on other cell phone models. The project is clean and works well but we estimate the cost of the parts to be between $250-300, making it out of reach for those who don’t have a specific need for these types of measurements. This is especially true for paragliders who have much less expensive options available to them.
[Thanks Carl-Emil]
