A Rotary Dial The 3D Printed Way
There’s a meme which may have a basis in truth, of a teenager left clueless when presented with a rotary telephone. The dial, in reality a mechanical pulse chain generator, was once ubiquitous enough that having one in your parts bin was anything but unusual. If you’re curious about their inner workings in 2026 though, you may be out of luck. Never fear though, because [Moeya 3D Designs] is here with a fully 3D printed version. It’s not as compact as the original, but it’s all there.
If you’re not put off by the anime-style Japanese voice over on the video below the break and you can enable subtitles for your language, you get the full explanation. There’s a ratchet and spring on the dial, which when released drives a gear train that ends in a cam that would operate a switch for the pulses. Another set of gears drives a very neatly designed centrifugal speed governor, and we see the effect immediately when it is removed. We’re not sure who will go for this project, but we surely like it.
There are two videos below the break, with the dial shown off in the first and the design process in the second. Meanwhile we’ve talked in the past about the networks behind the dials. Continue reading “A Rotary Dial The 3D Printed Way”
What Does Linux Need? A Dial!
It’s fair to say that there can’t be many developers who have found the need for a rotary telephone dial as a peripheral for their Linux computer, but in case you are among them you might find [Stefan Wiehler]’s kernel driver for rotary dials to be of use.
It’s aimed at platforms such as systems-on-chip that have ready access to extra GPIOs, of which it will need a couple to service the BUSY and PULSE lines. There are full set-up instructions, and once it’s in place and configured it presents the dial as though it were a number pad.
We like this project, in fact we like it a lot. Interfacing with a dial is always something we’ve done with a microcontroller though, so it will be interesting to see whether it finds a use beyond merely curiosity. We can already see a generation of old-school dial IP phones using Linux-capable dev boards. He leaves us with a brief not as to whether Linus Torvalds would see it as worthy of mainline inclusion, and sadly however much we want things to be different, we agree that it might be wishful thinking.
If you’d like to use a dial phone, there can be simpler ways to do it.
Header: Billy Brown, CC BY 2.0 .
Hacking A Rotary Phone
[Yaymukund] made an interesting observation. Old-style rotary phones were made to last and made for service. Why? Because you didn’t own them, the phone company did. There was no advantage for them for you to need a service call or a new phone. Of course, many of these old phones are still hanging around like the GPO 746 that appears in the post.
What do you do with an old rotary phone? In this case, you make it play a random tune whenever someone picks up the handset. As you might expect, you don’t need much of the original phone to do this. In particular, you need the handset receiver and the switch hook. We’d have liked to read the dial to select a tune, but perhaps that could be in version two.
All the components wire back to a D92732 circuit board. Finding the right wires was a bit finicky, but eventually, a Teensy, a battery pack, and an audio breakout board were in place. The rest is mostly trivial.
[Yaymukund] spent about £300, but over half of that was on tools most Hackaday readers will already have. The phone itself was £65. You can use these phones as a basis for many projects. Even if you want to go mobile.
Retrotechtacular: The 1951 Telephone Selector
Telephone systems predate the use of cheap computers and electronic switches. Yesterday’s phone system used lots of stepping relays in a box known as a “selector.” If you worked for the phone company around 1951, you might have seen the Bell System training film shown below that covers 197 selectors.
The relays are not all the normal ones we think of today. There are slow release relays and vertical shafts that are held by a “dog.” The shaft moves to match the customer’s rotary dial input.
Continue reading “Retrotechtacular: The 1951 Telephone Selector”
A Dial Phone SIPs Asterisk
An endless source of amusement for those of advancing years can come from handing a rotary phone to a teenager and asking them to dial a number with it. It’s rare for them to be stumped by a piece of technology, after all. [Mnutt]’s 4-year-old son had no such problems when he saw rotary phones at an art exhibition, so what was a parent to do but wire the phone to an Asterisk PBX with shortcut numbers for calls to family and such essential services as a joke line, MTA status, or even a K-pop song.
It’s possible to hook up a pulse dial phone with a SLIC module and a microcontroller, but in this case, a Grandstream SIP box did the trick. These are all-in-one devices that implement a SIP client with a physical connection, and older ones will talk to pulse dialers as well as the more usual tone dialing phones. The phone in question is a vintage American model. Writing this from Europe we were surprised to find a little simpler inside than its transatlantic counterparts of the same era.
An Asterisk install on a Raspberry Pi completed the project, and thus it became a matter of software configuration. It’s a useful run-through for Asterisk dilettantes, even if you haven’t got a 4-year-old. Perhaps you have an old payphone or two!
A Crossbar Telephone Switch Explained
There’s an old adage about waiting hours for a bus only for two to appear at once, and for Hackaday this month we’re pleased to have seen this in a run of analogue telephone projects. Latest among them is the video below the break from [Wim de Kinderen], who is demonstrating the workings of a mechanical crossbar switch with the help of a vintage Ericsson unit and an Arduino replacing the original’s bank of control relays.
It’s possible everyone has a hazy idea of a crossbar array, but it was fascinating from this video to learn that the relays are worked by metal fingers being inserted by the bars into relays with wider than normal gaps between electromagnet and armature. This extra metal provides a path for the magnetic flux to actuate the relay.
The machine itself then is an extremely simple and elegant electromechanical device with many fewer moving parts than its Strowger rotary equivalents, but surprisingly we seem to see less of it than its American competitor. The video below the break is definitely worth a watch, even if you don’t own any analogue phones.
We recently saw a similar exchange implemented electronically.
Continue reading “A Crossbar Telephone Switch Explained”
A Rotary Phone As A Computer Peripheral
It’s an age-old conundrum for anyone working with retro hardware: preserve its original condition or not? The answer depends so often on a complex mix of how rare, obsolete or unusable the device is in its original form , and what the intended use for the device will be. For [Typhon Mind] who needed a novelty method of recording best wishes at a wedding through an old dial phone there was no need for it to be entirely original, so the solution was to turn it into a USB device for a host computer.
Out went the original circuitry, and in came a USB hub, a USB audio interface, and an Arduino. The original earpiece would suffice, but the microphone was replaced with a more modern one. The Arduino will register the cradle switch, and also power a set of LED addressable lights under the unit.
The result is a phone that retains all its looks, but has a new life as a PC peripheral. We’d venture to suggest that also using the Arduino to read the dial and produce DTMF tones might make it a valid peripheral for a VOIP application and complete the transformation, but that’s something that could be done at a later date. Maybe it could even be given a GSM makeover.
